Driveshaft vibration? What to replace?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kotayota, Dec 7, 2015.
  1. Dec 7, 2015 at 10:56 AM
    Kotayota
    Kotayota [OP] Well-Known Member
    Sean
    Charleston, SC
    04 White DC
    Bilstein/Eibach combo, 1.5 rear shackles, 33/12.5/15 Duratracs wrapped around MT Classic IIIs, flowmaster 40, K&N intake, 4way pioneer speakers, mini d2s headlight retrofit, satoshi grill, interior leds
    I'm sorry I know there are threads about this already but I just need questions answered directly. I have a some "chirping" coming from under the truck I notice under 30 mph on or off the gas or on the brakes or not. There is also a good amount of vibration at higher speeds and its hard to say exactly because its not always the same but id say anywhere from 50-65 it can start. I jacked the rear axle up and put it in neutral and checked all the ujoints for play and could get any. The carrier bearing has some play about 1/2" but from what I understand thats normal. Am I missing anything? Thanks for the help
  2. Dec 31, 2015 at 3:40 AM
    Cdm1707
    Cdm1707 New Member
    Carden joint possibly, I'm going through it now. Could be the carrier bearing
  3. Dec 31, 2015 at 9:33 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Sounds like a dry u joint going bad.
  4. Dec 31, 2015 at 9:43 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    no that is not normal, it should have no more then 1/4" play at best or its bad.
    not saying that's your noise problem but with that much play I would think its causing the vibration issues for sure. the chirping might just be it rubbing on something as it wobbles.
    take a good look around the u-joint seals for signs of damage or rust indicating bearings got dried out and are rusting
  5. Dec 31, 2015 at 9:48 PM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    I'd have to say your carrier is bad. Mine is too, on jack stands and in gear I can watch my driveshaft moving up and down with every rotation. The rubber is so worn out in the carrier that it just squishes up and down constantly. Mine also chirps. Not that bad of a fix but I've been putting it off for months.
  6. Jan 1, 2016 at 8:23 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Bad carrier. You can grease all the joints on your driveshaft. It will get rid of most of the noise. But you really should swap the carrier
