Driveshafts: 4 cyl vs 6 cyl
Discussion in '1st Gen. Tacomas (1995-2004)' started by 53Jeeves, Sep 4, 2019.
  1. Sep 4, 2019 at 3:37 PM
    53Jeeves
    53Jeeves [OP] New Member
    2003 Tacoma
    I'm looking to replace the driveshaft on my 2003 Tacoma. A u-joint on the double-cardan went and the yoke on the rear propeller shaft is worn. I've read that double-cardan u-joints can't be rebuilt so I'm looking to buy a used part on E-Bay. I noticed that driveshafts on E-Bay specify 4 or 6 cyl and I was wondering if there's a difference?
  2. Sep 4, 2019 at 8:07 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    There are about 14 different drive shafts for your model year truck. You'll need to give us more information: 4Cyl/6Cyl, Auto/Manual transmission, 2WD/4WD, single cab/extra/double cab. Or you could take a look on this site and apply the appropriate filters. There are a few of us running drive shafts from that company and I haven't seen anyone report a problem yet.
    Welcome to TW!
    GQ7227 likes this.
  3. Sep 7, 2019 at 11:43 AM
    53Jeeves
    2003 Tacoma
    2003 V6 manual extended cab. Thanks for the info; I’ll check out that site!
  4. Sep 7, 2019 at 11:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Don't forget the 4x2 or 4x4 option either.
    GQ7227 likes this.
  5. Sep 7, 2019 at 11:47 AM
    53Jeeves
    2003 Tacoma
    Right - 4x4
  6. Sep 7, 2019 at 8:52 PM
    1997tacomav6
    Denver
    This site has all the sizes, 17 different sizes.
    https://www.wholesaleimportparts.com/Toyota_Tacoma_Driveshaft_2003.php
