Drivetrain, driving RPMs question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wildwest, Mar 29, 2017.
  1. Mar 29, 2017 at 8:48 AM
    wildwest
    wildwest [OP] Do you best and to Hell with the rest.
    Littleton, nc
    Tacoma
    Ome 887's, ome shocks, fj rims, cooper tires, dakars, TAG bumper, custom steps, LR UCAs, CARHARTT seat covers, husky liners
    When driving on cruise control 60 mph if I run into any incline the truck will drop into overdrive into high rpms and then return to over drive rpms. ANY type of incline. Didn't notice it before the lift 3 in OME, bigger tires 285s 70, Steel front bumper TAG and home made (heavy) step bars. Is it just the strain of the power train from all the weight and lift or is there a solution to the problem.
  2. Mar 29, 2017 at 8:49 AM
    wildwest
    Littleton, nc
    Tacoma
    outta overdrive
  3. Mar 29, 2017 at 8:55 AM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
    You added more weight and larger, more aggressive tires, for both more weight and higher rolling resistance. And the larger tires essentially changed your gearing to a higher ratio (lower, numerically). Your truck is working harder because of these factors, so it's downshifting. Really the only way to 'fix' it is to regear to a higher numeric ratio so that the truck isn't working as hard.
    Kyitty likes this.
  4. Mar 29, 2017 at 11:38 AM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Normal.
    As mentioned above you added weight, bigger tires, and changed your gear ratio. Only solutions are to regear and or add horsepower.
  5. Mar 29, 2017 at 1:06 PM
    wildwest
    Littleton, nc
    Tacoma
    I thought I would have to do that (re gear). So when you regear how bad are you effecting mgs./the trucks performance. Is it honestly as easy as changing the gears in the rear end or is there reprogramming of the transmission needed. I mean I'm not a mall crawler but I'm also not a rock climber or off roader either. I use it as a truck when I need to.
  6. Mar 29, 2017 at 1:07 PM
    wildwest
    Littleton, nc
    Tacoma
    Other than super charging it what other adding HP options do I have.
  7. Mar 29, 2017 at 1:11 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you will have better performance, mpgs will likely remain unaffected... while its easier for the motor to move the truck, it would be spinning faster at the same speed so its a wash.
    If you are 4x4 you need to do both front and rear diffs. No reprogramming needed.
    Supercharger is your only legit HP adder..... "cold air intakes" etc wont help.
    About the only other thing would be something like the XTP intake MANIFOLD spacer. I caped MANIFOLD as it is NOT the same as a throttle body spacer.
    Kyitty and Noelie84 like this.
  8. Mar 29, 2017 at 1:13 PM
    Noelie84
    Noel
    Wales, Maine
    This. Beat me to it.
  9. Mar 29, 2017 at 1:39 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    None really.
    I did Long Tube Headers and gained 16HP. Cost of about $700.
  10. Mar 29, 2017 at 2:24 PM
    wildwest
    Littleton, nc
    Tacoma
  11. Mar 29, 2017 at 2:25 PM
    wildwest
    Littleton, nc
    Tacoma
    Thank you, I am going to look into regearing front and rear diffs. Any suggestion on ratio and brand name
  12. Mar 29, 2017 at 2:37 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    The cruise control has always been a bit touchy. It's trying to keep the exact same speed on flat ground as it is on an incline. It is always going to down shift. I always see this complaint on this forum but this is how cruise control works.
    As a test: keep the pedal depressed to 1800rpm and hit the same hill. Your speed will slow down. Your natural reaction is to give it more gas, yes?
    That's the same thing the cruise control does.
    edit--
    Seriously. Don't regear for 285s on 17s. Especially not for cruise control.
  13. Mar 29, 2017 at 4:21 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    I totally agree with this, it's the cruise on these trucks that sucks, try driving the same stretch without the cruise and you'll find the truck acts much different.
    Second on don't bother to spend all that money to regear, I run 285's in the summer with no problems, I just don't use the cruise much.
    digitaLbraVo[QUOTED] likes this.
  14. Mar 30, 2017 at 1:45 PM
    wildwest
    Littleton, nc
    Tacoma
    So regearing because of low power would be a good reason?
  15. Mar 30, 2017 at 1:48 PM
    digitaLbraVo
    Regearing to cure transmission seek or poor acceleration after going to larger tires is a great idea. Regearing to fix your cruise control down shifting is fullretard.
    Kyitty likes this.
  16. Mar 30, 2017 at 2:27 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    I never use cruise control on this truck. It's terrible. Toyota did a horrible job programming it. I can do a better job myself.
    digitaLbraVo and sparkystaco like this.
  17. Mar 30, 2017 at 3:57 PM
    digitaLbraVo
    If it makes you feel any better every vehicle I've driven has this behavior. And I've been in a lot of rental cars in the last couple years due to work.
  18. Mar 30, 2017 at 4:51 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    My 2005 Camry SE did just fine....
  19. Mar 30, 2017 at 5:00 PM
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    mine does the same thing, it is especially bad if i use cruise control on a highway with a lot of elevation change.
    Ive learned to adapt my driving style to gradually ease off the pedal while going up hill. This usually causes me to drop 5-10 mph, but the truck stays in the same gear.
