Drivetrain noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NorthWitaco, Jan 5, 2024.
  1. Jan 5, 2024 at 11:40 AM
    NorthWitaco
    NorthWitaco [OP] Well-Known Member
    2014 access cab 4wd
    The truck is a 2014 4x4 automatic, no mods. In cold weather when the truck shifts into high gear there is a thud. Sometimes more noticeable than other times. But after I have driven a couple of miles, when things get warmed up it does not do this. To avoid this thud, when I start off I put the gear selector in 4, then when the truck warms up I shift into D. After that there is no noise. Do I have a concern or is everything ok? 89K on odometer, new fluids in tranny, transfer and diff. at 75,000. It made this noise before the servicing too.
  2. Jan 5, 2024 at 1:26 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    That's fairly typical for auto transmissions when it's cold outside. Usually more noticeable the colder it gets because the fluids are going act like higher viscocity until it warms up, and that makes the TC lockup (overdrive) kick in harder if that makes sense. Probably nothing to worry about. You could always pull a fluid sample and send off for testing if you are real worried about things but I doubt it's much of an issue. Just drive it more gently until it gets up to temperature.
  3. Jan 5, 2024 at 8:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  4. Jan 7, 2024 at 9:08 AM
    NorthWitaco
    2014 access cab 4wd
    Thank you for your replies, now I can resume worrying about things that need concern.
