Drivetrain ticking
Discussion in '1st Gen. Tacomas (1995-2004)' started by SIK99Tacoma, Oct 5, 2017.
  1. Oct 5, 2017 at 11:43 AM
    SIK99Tacoma
    SIK99Tacoma [OP] Well-Known Member
    Taylor
    Big Sur
    2020 OR DCLB
    FOX IFP front 2nd clip 1/2" spacer, FOX 2.0 adjustable resi rear, RXT leaf pack, SSO slimline front w/ baricade 9500lb and amber light bar, ARE Cap, allpro steps, TRD pro style wheels w/ Kenda Klevar skins
    Hello all,
    Have a '99 2.7L 4x4 manual trans.
    I'm having a ticking under load that I cant figure out. only happens under load/accelaration, nothing in neutral, weight in bed does not aft noise. ticking speeds up as I speed up. don't notice it when slowing down even under compression.
    Already replaced carrier bearing (center support bearing on drive shaft), replaced CV half axel, took apart and inspected bearings in knuckles and 4x4 lockers and everything is good. related repairs last six months for other issues, replaced clutch, changed fluid in trans/transfer case/both diffs, replaced upper and lower ball joints, inner and outer rods, UCA and LCA bushings, sway bar end links, steering rack bushings. Noise was there before all repairs and still present is same volume and intensity.
    Any Ideas??
  2. Oct 5, 2017 at 11:45 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    Check your u-joints in driveshaft.
  3. Oct 5, 2017 at 12:58 PM
    SIK99Tacoma
    Taylor
    Big Sur
    2020 OR DCLB
    Drive shafts and u joints are all good 4x4 and main. Checked when I did the clutch and center support bearing. Didn't replace so omitted from list. No play and look good. Greased them too.
    Thanks though
  4. Oct 5, 2017 at 1:37 PM
    Kleenax
    Ray
    Michigan
    Crazy! I hate that when you hear something like that and can't find it.
    Only other time I've something like that was something inside a rear brake drum "ticking" when it turned, but that wouldn't explain it doing it only under load.
  5. Oct 5, 2017 at 1:40 PM
    SIK99Tacoma
    Taylor
    Big Sur
    2020 OR DCLB
    Thought that too. Pulled both drums off and nothing out of the ordinary.
    Transmission?? But why a tick and only on acceleration / drivetrain under load. Not on compression, at least noticeably. And nothing if I'm just cruising at speed. But if I gas to pass I notice it again. Might be there and just not noticeable at speed but if I'm coming to a stop nothing.
  6. Oct 5, 2017 at 2:36 PM
    Kleenax
    Ray
    Michigan
    Yep, I also thought of the tick that you hear sometimes with a tiny leak at the exhaust manifold, but that usually ticks all the time. How bout something like the torque convertor? That would engage during acceleration.
    EDIT: Crap! just noticed that you had a manual trans!
