driving a RWD 2002 regarding cab tacoma in bad weather
Discussion in '1st Gen. Tacomas (1995-2004)' started by jemidawes, Dec 21, 2014.
  1. Dec 21, 2014 at 1:21 PM
    jemidawes
    jemidawes [OP] Member
    mike
    North Carolina
    2002 2wd base 2.4 cyl
    I am suppose to buy a 2002 base model tacoma next week. I'm having 2nd thoughts due to possible bad weather. Will it handle ok in snow or icy roads?
    I've been driving a civic for years with little trouble.
    Whst can I do to help it do better?
  2. Dec 21, 2014 at 1:21 PM
    jemidawes
    mike
    North Carolina
    Regular can that is. Lol
  3. Dec 21, 2014 at 1:26 PM
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    Those reg cab 2wds are really light in the rear. I used to put 3-4 50lb bags of sand in the back right over the axle. Bonus to that is if you get stuck you have sand to get unstuck.
    If you don't drive like a tool you'll be fine.
  4. Dec 21, 2014 at 2:13 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    It snows in North Carolina? Only thing you can do with something like that is weight in the rear. Civic is a front wheel drive and they handle quite a bit better than rear wheel drives in the snow so it will take some getting used to.
  5. Dec 21, 2014 at 2:17 PM
    Broke Okie Ty
    Ty
    OP can you run studded tires?
  6. Dec 21, 2014 at 5:46 PM
    C Malson
    C Malson New Member
    Charlie
    Cedar Hill, MO (USA)
    02 PreRunner Double Cab
    ARE Contractors Topper
    I've got a PreRunner, I just put about 200lbs of sand in the bed and it does fine.
  7. Dec 21, 2014 at 6:41 PM
    Deere9798
    Deere9798 Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    Snow tires make a world of difference. When I changed from all season to snow tires the traction in Ice/Snow increased greatly.
    Thanks and good luck,
    Charlie
  8. Dec 21, 2014 at 10:06 PM
    HenryG
    HenryG Well-Known Member
    Washington State
    Snow tires, bags of sand, canopy... Basically anything to add weight or increase traction in the rear.
  9. Dec 21, 2014 at 11:21 PM
    jemidawes
    mike
    North Carolina
    Thanks for input
  10. Dec 22, 2014 at 12:52 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I ran a 2wd five lug toy pickup for 12 years...a decent set of traction tires in the back, good rib tires on the front and a few hundred pounds of sandbags over the axle...
  11. Dec 22, 2014 at 2:28 AM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    put some weight in the back, practice in a parking lot, drive responsibly and you'll be fine.
  12. Dec 22, 2014 at 8:42 AM
    ttaM
    ttaM 4.8.15.16.23.42
    Kentucky
    2002 Tacoma 2.4L 5 Lugger
    I've got a reg cab 2wd like you're talking about - I put about 200 lbs of sand bags over my rear axle and that helps a lot.... main thing is not punching either pedal too hard or too sudden.
  13. Dec 22, 2014 at 8:50 AM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    what everyone said- I concur. weight and good tires, you will be fine.
  14. Jan 2, 2015 at 8:33 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    I'm in an an xtracab 2wd. I feel that it handles fine. I have never lost control of it, even in the snow. Doing donuts and crazy crap like that doesn't count, because it was intentional, ha ha.
    Just don't punch it, use the brakes too hard, or steer too sharply, and you'll be fine as Georgia peaches.
