Driving around with locked hubs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by blackra1n, Sep 16, 2012.
  1. Sep 16, 2012 at 5:35 PM
    blackra1n
    blackra1n [OP] Member
    I'm sure this question has been asked a hundred times already but I have never owned a 4X4 vehicle so I am asking. My truck will be sitting for at least half a year and wont be driven much. I plan on starting it every week to keep the fluids circulating and all that stuff, my question is, when I drive it through bad weather or go wheeling or even normal driving, is it okay to leave the hubs locked so I can switch from 2H to 4H anytime? Will it hurt anything in the long run or is it better just to manually get out every time and lock and unlock?
    Thanks!
  2. Sep 16, 2012 at 5:37 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    I left my hubs locked on my '88 yota thru the winter months, had no problems except steering was tighter.
  3. Sep 16, 2012 at 5:38 PM
    joes06tacoma
    Joe
    Central Coast, CA
    It won't hurt anything. Might lose a little MPG and feel a little bit more vibration from the front driveshaft. I used to leave the hubs locked if I planned on using 4WD during a trip on my last 4X that had hubs on it.
  4. Sep 16, 2012 at 5:55 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yea you can.
    I wouldn't do it if you plan on going faster then like 55..but thats just me.
    other then that, just leave locked isn't going to hurt much.
  5. Sep 16, 2012 at 6:15 PM
    blackra1n
    Even if you were just in 2H?
  6. Sep 16, 2012 at 8:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea, well you'll get better mpg with them off at that speed. And the logic to me is that you shouldn't do 4x4 higher the 55..then the hubs shouldn't be locked either. But thats just me
  7. Sep 16, 2012 at 9:16 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Used to do it all the time in my 86 Toyota. The transfercase would not shift from 4hi to 2hi while driving over 50MPH. If I wanted out of 4hi, I had to slow below 50MPH. Not a problem, the only time I used 4 wheel drive on the highway was just to see if it would do it. But no issues running around at 70MPH with locked hubs. I could feel a little extra vibration, but nothing real noticeable.
  8. Sep 16, 2012 at 10:24 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I would never do that. It is lots of unnecessary wear and tear on the cv joints boots and differential.
