Driving in snow 2wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Luckyshot80, Jan 21, 2022.
  1. Jan 21, 2022 at 10:00 PM
    Luckyshot80
    Luckyshot80 [OP] New Member
    2006 Silver AC Tacoma
    Working late and my truck is covered in snow. Drive through Charlotte was slow and steady.Only hairy situation was leaving lot and my tires not getting traction. Up hill exit in 2WD not great. Way too many vehicles on side of the interstate. Stay safe out there.
  2. Jan 21, 2022 at 10:08 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    I hope you cleared all that snow off your truck before driving.
  3. Jan 22, 2022 at 12:25 AM
    shift957
    shift957 Well-Known Member
    Cacapon River, WV
    11 AC OR
    2 things you can do to help gain traction: fill the bed with snow for extra weight and air down the tires. I dropped my pressures today to 19f, 15r just to get out of my icy, twisty, hilly driveway. I have a significantly harder time at full tire pressure.
    DG92071 and steelcity2 like this.
  4. Jan 22, 2022 at 7:46 AM
    Luckyshot80
    I did clear all that snow. I used my snow gloves and a cane to clear top of my truck. Sat a while with heater on. I did put some bags of fertilizer in my bed. Hoped the camper shell added weight would of helped.
    RedDemolisher and Just_A_Guy like this.
  5. Jan 22, 2022 at 7:51 AM
    DG92071
    DG92071 Well-Known Member
    Does your truck have limited slip?
  6. Jan 22, 2022 at 7:55 AM
    Luckyshot80
    No. It is a California truck. Didn’t need a 4x4 then. It is first time in Carolinas where I had to drive in snow. Been here ten years and first time I have said I wish I had 4x4.
    FastEddy59 likes this.
  7. Jan 22, 2022 at 8:07 AM
    DJR81
    DJR81 Well-Known Member
    2013 5 lug 4 speed auto
    I plan to get a set of winter tires
    You must have decent tires if you made it home in that. I’m in central Va and plan to get blizzacks for next winter- same truck as yours
  8. Jan 22, 2022 at 9:31 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I drove in Minnesota for years with only a 2 wheel drive truck. Nothing you can't get used to doing. Be light-footed and trying to anticipate stoplight changes, you know red to green, you get good at it. You sometimes piss people off behind you, but you get used to it.
    Even some FWD cars with wide tires struggle in the snow. Wide tires may look nice but in snowy icy conditions, they have their limits.
    Now I sure like the option of having 4H when things get slippery. I just have to keep reminding myself I still can't stop any faster.
    RedDemolisher and RedWings44 like this.
  9. Jan 22, 2022 at 9:42 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    There are very few situations in snow where lowering the pressures will help. You're losing ground clearance and contact patch in the center.
  10. Jan 22, 2022 at 9:44 AM
    RedWings44
    Michigan
    I was following a live stream of the storm. 4x4 is good in a lot of situations but nothing is great in ice. Glad you made it safely.
  11. Jan 22, 2022 at 9:51 AM
    dtaco10
    Dave
    I would think you would lose psi as the contact patch would be larger. I know of cases where light small cars with narrow tires have better traction in the snow than mid to full-size cars with wider tyres.
  12. Jan 22, 2022 at 9:54 AM
    RedWings44
    Michigan
    The tire deforms when you air down. That's great for mud and rock where you need the tire to deform around obstacles or float, but snow is different. In deep snow it may be good but most of the time you're just starting to lose contact in the center of the tire which is not great for normal driving on the road, even in snowy conditions.
  13. Jan 22, 2022 at 10:10 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Common sense, experience and snow tires mounted on all 4 corners even with a 2WD have served me fine over the years. Always turn on the LSD, which turns off the dreaded traction control. It helps a lot.
    I use Firestone WinterForce mounted on my OE steelies.
    Junkhead likes this.
  14. Jan 22, 2022 at 11:27 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It is the outside edges of the tires that do the work in snow/ice, not the center. Airing down does help in snow. You don't have to go as low as you would off road, but just enough to make the tires softer
  15. Jan 22, 2022 at 11:30 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Looks like a mere dusting to me lol
  16. Jan 22, 2022 at 3:02 PM
    DJR81
    Do you have any problems getting up inclines? I’m getting ready to order a set of alloys and blizzacks for my 5 lug access cab from tire rack ($950 for whole set mounted). There a a couple hills I gotta get up on my commute which changes the game a little
  17. Jan 22, 2022 at 3:08 PM
    Plain Jane Taco
    USA
    Nope....at least with the inclines I deal with. Make sure to turn on the LSD if equipped. Winter tires make a huge difference vs all season or all terrain. And I say that from personal experience over the years.
  18. Jan 22, 2022 at 3:15 PM
    DJR81
    ok thanks. Do you add any weight to the bed?
  19. Jan 22, 2022 at 3:20 PM
    Plain Jane Taco
    USA
    Never have.
    I commute 50 miles a day to work. So getting there safely is important. That's why I have winter tires. It just makes for a more capable and secure vehicle....especially as a 2WD.
    Just recently made the 25 mile journey home in 9" of snow. I took the back roads because of some accidents on the highway. I was moving effortlessly where other 2WD pickups were seriously struggling....or even off the road stuck.
    DJR81[QUOTED] likes this.
  20. Jan 22, 2022 at 3:44 PM
    DJR81
    That’s good for hear. A little hesitant to drop a grand and it still not do well I’m the snow. Or trade it and get a 4wd truck or a Subaru - but I’m in central VA where it’s usually not too bad. But ice was an issue this week
