Driving in Snow/ 4wd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brinastaco, Jan 3, 2020.
  1. Jan 3, 2020 at 12:30 PM
    #61
    Tripod1404
    Tripod1404 Annihilator tripod
    Thanks for the information! Didnt know the brake systems were different. That makes sense
    tonered[QUOTED] likes this.
  2. Jan 3, 2020 at 12:32 PM
    #62
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome. :cheers:
    It is one of the nice things about those models. It does have a different feel compared to a standard vacuum system, but it is easy to get used to. If only we got the ACLB MT OR, I would have gone that route. No real regrets though.
    Hercanstein and BigWhiteTRD like this.
  3. Jan 3, 2020 at 12:33 PM
    #63
    Tripod1404
    How? On ice/snow the friction limit is at tire level. So increasing the friction at the drive-train level should not improve braking. I mean you can even slide with engine breaking under certain conditions.
  4. Jan 3, 2020 at 12:35 PM
    #64
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You have to separate snow and ice here. In that vid, they were in snow. 4WD locked both axles together and let them bulldoze the snow. That greatly assisted the braking.
    Toynado and BigWhiteTRD like this.
  5. Jan 3, 2020 at 12:45 PM
    #65
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Just to clarify a little
    VSC is the stability control portion, and is separate from traction control.
    In many modes of the truck, you may have VSC ON while Trac is off, or vice versa.
    4hi on all known 3rd gens defaults to VSC ON, but it can be turned off.
    VSC will 100% attempt to make the truck go where you are steering by firing brakes off on one side, calculated from yaw gyro, accelerometers longitudinally and laterally, as well as steering wheel input.
    Fun test, jack all 4 wheels up and put truck in drive. Turn steering wheel and truck will fire off brakes on one side to correct the skid it thinks you are doing.
    [Edit, VSC testing on bench
    https://www.tacomaworld.com/posts/16983967 ]
    Two4Runner, Superdave1.0 and tonered like this.
  6. Jan 3, 2020 at 12:45 PM
    #66
    Brinastaco
    Brinastaco [OP] Active Member
    Sabrina
    Northern California
    2018 Cement TRD OR Tacoma
    Thank you!!!!
  7. Jan 3, 2020 at 12:53 PM
    #67
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Crap! Editing my posts for VSC not TCS and 4Hi defaults. :D
    @BigWhiteTRD You gotta give me a hard one of these :smack: next time! Sorry for the confusion.
    BigWhiteTRD[QUOTED] likes this.
  8. Jan 3, 2020 at 1:06 PM
    #68
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Nice thank you.
    If that is true, how did my truck spin near 180 degrees?
    - 4hi, did not manually disable TC or vsc
    - Moving slow 5-10mph
    - Sun was setting, snow became slippery
    - Was a slight decline/downhill
    - I stayed on the brakes, did not pump (I probably should have pumped or gassed it).
  9. Jan 3, 2020 at 1:10 PM
    #69
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Maybe get back on topic for Sabrina . You know what I mean .
    StayinStock likes this.
  10. Jan 3, 2020 at 1:13 PM
    #70
    Superdave1.0
    SoCal
    That was 2 or 3 pages ago. Sorry OP didn't mean to derail your thread.
    :hattip:
  11. Jan 3, 2020 at 1:20 PM
    #71
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Available traction. The system can only do so much with what is available. With the weight up front, there is a tendency to swap ends.
    Edit: Shit! I was confusing the 4Hi / 4Lo defaults when talking about the OR / Pro. Sorry! :cheers:
  12. Jan 3, 2020 at 1:44 PM
    #72
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    It's hilarious how little flaming is going on. Only one rtfm, wonder why :rolleyes:
  13. Jan 3, 2020 at 1:52 PM
    #73
    VUIguy
    VUIguy Well-Known Member
    2019 TRD Off-Road 4x4
    That's my truck but I couldn't find a manual transmission V6 TRD OR anywhere in NC. :-(
    Nw_nomad[QUOTED] and tonered like this.
  14. Jan 3, 2020 at 1:57 PM
    #74
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    What tires are on it?
  15. Jan 3, 2020 at 1:59 PM
    #75
    VUIguy
    Any issues just call Obama and he will figure it out for ya. LOL :ohsnap:
  16. Jan 3, 2020 at 2:01 PM
    #76
    Kennyluu611
    Kennyluu611 Well-Known Member
    Kenny
    SoCal
    2010 Tacoma DCSB Prerunner 4x4
    King 2.5 JBA HD UCA Dakar Rear Leaf US Off Road Bumper Winch 4x4 Converted TRD Supercharger
    Below is a link of the digital users manual. On page 299 is where the 4 wheel drive procedure starts. I would start there on how to engage and disengage the system correctly. Regarding driving in snow as stated from other members drive slow and distance yourself. This is the safest way when you're in a snowy road. When you're on the highway follow the tire pattern of the vehicle in front of you. Be careful in dark areas that look wet. Melted snow overnight becomes black ice which becomes slippery.
    https://www.toyota.com/t3Portal/document/om-s/OM04017U/pdf/OM04017U.pdf
    EDIT: guess I didn't read post 17. Thank @GreyBaldTaco.
    VUIguy likes this.
  17. Jan 3, 2020 at 2:02 PM
    #77
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    You know exactly why, muh lady.
    Skydvrr[QUOTED] likes this.
  18. Jan 3, 2020 at 2:02 PM
    #78
    GreyBaldTaco
    2019 F150 5.0
    See post 14
    tonered likes this.
  19. Jan 3, 2020 at 2:04 PM
    #79
    fence666
    fence666 Active Member
    Dylan
    2010 Magnetic Grey Double Cab TRD Short-Bed
    Every bro on here is going to act like they're super smart relative to you. You're not going to ever need to use 4L it sounds like, unless you're completely stuck or going off-roading. Generally, if there's snow on the ground (or ice) you should put it in 4H. Before you go driving far, test your car in 2WD, you'll feel your car not gaining traction and slipping. Put it in 4H and you'll notice you're now getting grip and driving with ease.
    You'll be fine! Have fun.
    SilverBulletII likes this.
  20. Jan 3, 2020 at 2:22 PM
    #80
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    If it's slippery outside, throw it in 4hi. If you get stuck, stick it in 4lo.
