Driving in Snow/ 4wd
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brinastaco, Jan 3, 2020.
  1. Jan 3, 2020 at 2:47 PM
    #81
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
  2. Jan 3, 2020 at 2:55 PM
    #82
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    Nice bullhead!
    verynearlypure and Shelf Life like this.
  3. Jan 3, 2020 at 2:56 PM
    #83
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    That's good advice right there. If you're trucken along on a snow packed road, or one that goes from a bit of snow/ice to hard dry pavement just keep in in 2wd since there's little chance of getting stuck. If you're in a parking lot that has a lot of ruts in the snow or hasn't been plowed, switch to 4High and take it slow. I can't think of a situation where you would need 4low due to snow unless maybe if you are stuck and want to try crawl control to get you out... but that's a whole different deal.
    elmontemike likes this.
  4. Jan 3, 2020 at 3:28 PM
    #84
    Brinastaco
    Brinastaco [OP] Active Member
    Sabrina
    Northern California
    2018 Cement TRD OR Tacoma
    Good year all terrain
  5. Jan 3, 2020 at 4:39 PM
    #85
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Cant absolutely guarantee in your case obviously, but basically if you are already utilizing all available traction, additional traction attempts on one side will do nothing except activate ABS probably... I dont know if the truck is smart enough to REDUCE your attempts at braking on one side, but probably not except for ABS
    (I dont know enough to know if a little gas would help in this situation, but I definitely think letting off brakes will likely help initially in this situation...)
    tonered and Superdave1.0[QUOTED] like this.
  6. Jan 6, 2020 at 8:05 AM
    #86
    VUIguy
    VUIguy Well-Known Member
    2019 TRD Off-Road 4x4
    Same here. As soon as I wear mine out I'm going for BFG AT KO2s. Great on and off-road.
  7. Jan 6, 2020 at 10:46 AM
    #87
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  8. Jan 23, 2020 at 9:58 PM
    #88
    Link master
    Link master Well-Known Member
    2016 Tacoma inferno trd off road dcsb
    Arb summit bumper. Morimoto led headlights and new grill. Grill and lights have sequential turn signals.
    It sound like this is your first time driving with a pickup and in possible bad weather.
    When you can pull into a snow covered lot and stomp it in a safe area, get your feel of how it breaks traction, after that you should have a good idea of when you will need 4 high.
    80-100 lbs up against the tail gate does help in snow and ice.
    SR-71A likes this.
  9. Jan 24, 2020 at 7:25 AM
    #89
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    So how did the trip go?
  10. Jan 24, 2020 at 9:38 AM
    #90
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    There is no way I can fit chains without some damage. I guess I can get some to carry so I can say yes, but they won't be going on.
  11. Jan 24, 2020 at 12:46 PM
    #91
    NMBruce
    SW Colorado
    the rear tires should be able to handle chains or is you truck modified where they will not work?
  12. Jan 24, 2020 at 12:53 PM
    #92
    Garab
    Garab Well-Known Member
    2018 TRD Sport MT6 DCSB
    OVtune 2.0 TRD Sema wheels 265/70/17 Falken Wildpeak AT/3 SL ADM BAKflip mx4
    SOME people like scenery Golfindia. :annoyed:
  13. Jan 24, 2020 at 1:06 PM
    #93
    Pilsner
    18 TRDOR
    That's a good point. Rears should be ok.
  14. Jan 24, 2020 at 1:21 PM
    #94
    Hercanstein
    Hercanstein Well-Known Member
    Bryan
    State of Jefferson
    1999 2.7 SR5 4x4 5MT XC, 2020 3.5 TRD Sport 4x4 6MT AC
    ('99) Offset Aluminium Wheels, 31" BFG All-Terrains, Bushwacker Fender Flares, Window and Hood Wind Deflectors ('20) Stock
    If you are in the snow and your back end is slipping more than you like, pull over in a safe spot with plenty of snow around and shovel a bunch of it into the bed of your truck for extra weight.
    If you are planning a trip into an area you might think is sketchy, put extra weight in your bed beforehand (sandbags etc.) to help with extra traction.
    My 2 cents.
    Happy Trails!
    : )B
    Round the world likes this.
  15. Jan 24, 2020 at 2:13 PM
    #95
    Link master
    Um, you in a low car or Tacoma pickup ??
    Because even the basic taco has more then enough room to run chains.
    There are alternatives also that are flat.
  16. Jan 24, 2020 at 2:15 PM
    #96
    Pilsner
    18 TRDOR
    There is currently ZERO room in the front with 255/85s
  17. Jan 24, 2020 at 2:38 PM
    #97
    Link master
  18. Jan 24, 2020 at 4:14 PM
    #98
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Toyota needs to make an AWD Tacoma.
    GreyBaldTaco likes this.
  19. Jan 24, 2020 at 4:42 PM
    #99
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    I wonder how hard/expensive it'd be to swap in a 4runner or gx 460 center diff?
