Driving in the rain - Scary
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikeyDo, Nov 8, 2010.
  1. Nov 8, 2010 at 9:20 AM
    MikeyDo
    MikeyDo [OP] Active Member
    North Little Rock
    98 Tacoma 4WD
    I love my '98 4x4 but it is almost scary to drive in the rain. I have a hill in our neighborhood called "Snake Hill" by the locals. Getting up this hill in the rain is almost like trying to get up a hill in the snow. 3/4 of the way up the hill and the rear finally breaks loose and I do nothing but spin.
    Rear end has broke loose on moderate turns and entry ramps.
    I have 31 x 10.5 15 Cooper Discover ATR tires. What do you guys do to overcome the hazzards of driving in the rain?
  2. Nov 8, 2010 at 9:26 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Is this a paved road you can't get up in the rain? The Cooper's are great tires, I've got the same ones, are they in good shape? Otherwise, just use a light foot, once you start spinning, you lose a lot of traction. You're better off letting off and letting the tires catch.
  3. Nov 8, 2010 at 9:30 AM
    Mod
    Mod Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Drop the air pressure a bit, and add some weight to the back.
  4. Nov 8, 2010 at 9:30 AM
    MikeyDo
    North Little Rock
    98 Tacoma 4WD
    Paved road, lot's of tread on the Coopers. Age may be a factor. Babying the throttle going up the hill doesn't seem to help.
    It just seems that it takes an incredibly light foot not to slide even taking off on flat surfaces.
  5. Nov 8, 2010 at 9:31 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    You can also put some sand bags in the bed
  6. Nov 8, 2010 at 9:32 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Ummm... are you putting it in 4WD??? That should do it... Next would be to add some weight in the back. If the paved roads are slippery like that, you have no problem using the 4WD... as long as slipping can occur... it is no different than snow, ice, mud as far as using 4WD.
  7. Nov 8, 2010 at 9:33 AM
    Pugga
    Massachusetts
    F-150 Mod
    How old are the tires? the compound hardens over time and even though there is tread left, the rubber won't grip nearly as well. Cooper tires have very good grip on the wet/snow, you shouldn't be having this issue. Did it just start recently or been getting worse? Might be a sign it's time for tires.
  8. Nov 8, 2010 at 9:33 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I want to see pictures of this road from hell.
  9. Nov 8, 2010 at 9:37 AM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    x2 on the 4-wheel...give that a try. Besides tread, age of tire, and adding weight, how's your suspension? If it's old, it may not be keeping your tires sufficiently planted to the ground.
  10. Nov 8, 2010 at 9:48 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    X2!!
  11. Nov 8, 2010 at 10:00 AM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Mike use 4-hi-that's what it's for:) my '01 came originally with those BF goodrich knobby offroady tires-SCARY on the freeway in rain-I dumped tham and went with Michelin Xs with street tread and solved that little hazard. Having your front tires do some of the pulling will even up your traction
  12. Nov 8, 2010 at 10:15 AM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_ಠ
    17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    X2
  13. Nov 8, 2010 at 10:17 AM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    x3
  14. Nov 8, 2010 at 11:23 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    Get them siped
  15. Nov 8, 2010 at 11:30 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    x2, this road must be insane! I have driven up to the Sandia crest (5k vertical feet in a pretty short amount of road so its pretty steep) in the winter with snow/ice and did fine in 2wd on bald pathfinder A/P's.
  16. Nov 8, 2010 at 11:31 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Hydroplaning in the rain at 180kmph. Thats scary
  17. Nov 8, 2010 at 12:34 PM
    MikeyDo
    North Little Rock
    98 Tacoma 4WD
    Guys, it's not that the road is that insane, but it is twisty and relatively steep which makes it hard to sustain any kind of speed or momentum in a Tacoma. Miata MX-5? No problem, and very fun. Taco? Not so much.
    I've tried to find an online image but it is Avondale Road near the Old Mill in North Little Rock, AR if you want to explore Google Maps. I just went up and down the hill on street view. :)
  18. Nov 8, 2010 at 12:44 PM
    HawaiianTaco18
    HawaiianTaco18 Well-Known Member
    Josh
    Hawaii
    2003 Tacoma Double Cab
    use your elocker if you have :D
  19. Nov 8, 2010 at 1:02 PM
    Pugga
    Massachusetts
    F-150 Mod
    The Cooper's are siped.
  20. Nov 8, 2010 at 4:15 PM
    NumNutz
    Virginia Beach, VA
    Lots.
    Ok... I see this as a perfect opportunity to get better at drifting. J/K goodluck man.
