driving lights behind satoshi
Discussion in 'Lighting' started by goride, Jun 20, 2009.
  1. Jun 20, 2009 at 12:19 PM
    goride
    goride [OP] Well-Known Member
    Josh
    UTAH
    09 trd sport dbl cab lb
    Tinted windows,Upgraded stereo system,satoshi grill with piaa lights behind,dash light color mod to blue,mag light holder,OME dakar leafs,Toytec ultimate lift,LR uca's, BFG AT's 285/70/17 on Pro Comp 7089s,weather techs, leer shell,CBI sliders and rear bumper w/tire gate,soon DTLT w/ wicked flow catback exhaust
    I need some help mounting some PIAA driving lights behind my satoshi grill,also was wondering if anybody knows where to hook up the wire so they come on with the high beams any advice would help.Just got my satoshi done and love it.
  2. Jun 20, 2009 at 12:54 PM
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
    Just mount a seperate switch for the PIAAs. So you can use them whenever you want.
  3. Jun 20, 2009 at 12:59 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    lets see the grill!
  4. Jun 20, 2009 at 1:40 PM
    goride
    Josh
    UTAH
    Can I make it so I can use the switch any time and also make them turn on automatically with my high beams.I havent taken any pics of grill yet I will try here shortly.Thanks
  5. Jun 20, 2009 at 3:27 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Use the same relay that you use for the switch. The switch activates the normally-open relay coil which applies power directly from the battery. That allows you to use them when you want. If you want them on when the high beams are on, connect the highbeam power to the same terminal that the switch connects to. When the high beams are on, it'll energize the coil in the same way that the switch would. Note that you won't be able to turn them off when the high beams are on.
    It'd be best to tap the switch wire to a circuit that's on when the key is on so that you don't accidently turn them on when exiting the truck (bump the switch).
  6. Jun 20, 2009 at 4:48 PM
    goride
    Josh
    UTAH
    Do you know which is the best circuit to tap for this.Thanks Got the lights mounted where I want them and have the wires half way ran, cant wait
