Driving lights on with headlights on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sandygrullon, May 1, 2016.
  1. May 1, 2016 at 4:17 PM
    sandygrullon
    sandygrullon [OP] Member
    sandy
    Hamilton NJ
    2018 Tacoma Limited
    LED lights, Roof Racks, undercover color bed cover, K&N Cold Air Intake, Badass Audio System
    Does anybody know of a kit or how to keep your driving lights on with the headlights on at the same time?
  2. May 1, 2016 at 4:36 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    What driving lights are you referring to? The DRL led, side amber parking, or the inside turn signals?
  3. May 1, 2016 at 4:52 PM
    sandygrullon
    sandy
    Hamilton NJ
    2018 Tacoma Limited
    Regular led driving light, they turn off when headlight comes on. Would like it o keep it on all the time.
  4. May 1, 2016 at 4:55 PM
    MESO
    State of Jefferson
    The white DRL LED's stay on when headlights turn on.(they just dim down a little)
    YDCtaco likes this.
  5. May 1, 2016 at 4:57 PM
    sandygrullon
    sandy
    Hamilton NJ
    2018 Tacoma Limited
    Didn't realize it did...I still like to see it fully lit with the headlights..
  6. May 1, 2016 at 5:08 PM
    MESO
    State of Jefferson
    pop the hood, look for the 3 wire harness on back of headlight going to the DRL's.
    drivers side:1)white/black 2)red 3)green
    Pass. side: 1)white/black 2)blue 3)green
    -white/black is ground for both.
    -When power is applied to Green(DRL circuit) they light up bright
    -When headlights turn on, power goes to the red and blue and dims them.
    To keep them bright all the time, cut the red(drivers) and blue(passengers) side and tap it into the green wire right next to it. Make sure to diode isolate.
    CHeers:cheers:
    arkywally likes this.
  7. May 1, 2016 at 5:44 PM
    sandygrullon
    sandy
    Hamilton NJ
    2018 Tacoma Limited
    I'm going to try this tomorrow...it would cause no damages right...witch wire gets the negative side of the diode? Did you do it on yours.
  8. May 1, 2016 at 5:52 PM
    MudLovingFJ
    MudLovingFJ Do it right the first time or don't do it at all
    OC, CA
    16 F150 / 16 M3
    I didn't build it hoping for your approval, I built it because it meets mine!
    Forgive my ignorance, but what kind of diode would be required?
    Thank you for the info, by the way
  9. May 1, 2016 at 6:01 PM
    MESO
    State of Jefferson
    any small diode will work. Just go to a local stereo shop or radio shack. they area few cents.
    here is how I would do it;(both sides have to be done).
    No I did not do it on mine, but I had to wire my DRL's off both wires, so I have tested and verified them.
    If you wire it up like this -shouldn't have any issues. (Both sides will need it done). Make sure diode is how picture shows.
    MudLovingFJ and tomwil like this.
  10. May 1, 2016 at 6:06 PM
    sandygrullon
    sandy
    Hamilton NJ
    2018 Tacoma Limited
    Thank you very much..
  11. May 1, 2016 at 6:08 PM
    Drifter16
    Drifter16 Well-Known Member
    Eric
    Shenandoah Valley Area
    2016 Blazing Blue Pearl TRD O/R, DCSB 4x4,Prem Tech JBL
    Offensive stickers and stuff the wife doesn't know about.
    Interesting, didn't really ever realize that the DRLs dimmed when the headlights came on. Just figured that they didn't look as bright due to the headlights being on. OP if you do this do a quick write up and let us know how it goes.
  12. May 1, 2016 at 6:12 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    If you are having problems with this is.It would be because the diodes are installed reversed.
  13. May 1, 2016 at 6:27 PM
    MudLovingFJ
    OC, CA
    16 F150 / 16 M3
    Thanks a lot! :cheers:
  14. May 2, 2016 at 1:49 AM
    Qwack
    Qwack Well-Known Member
    Oahu
    2016 TRD Sport 4x4 2017 4Runner
    I think you might have to measure the amount of current the drl draw.
    if you use any small diode, like the 1n4148 the peak forward current is 400mA
  15. May 2, 2016 at 6:18 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    unsafe and illegal (excessive glare)
    DRL's dim when headlights on by design and by FMVSS regs
    you could be busted, but will you be busted? 99.9999% sure no way but
    from a lighting engineering perspective you should leave it factory
  16. May 7, 2016 at 7:08 PM
    sandygrullon
    sandy
    Hamilton NJ
    2018 Tacoma Limited
    Maybe I will leave it as is, I looked at those wires and they are not easy to get to. I already mess up today installing my cover on. One of the bolt broke and could not get it out, not happy.
    Back when I had the xrunner I installed an autostart to it my self, left it at a shop and somebody hit the start while still in gear. Garage door was destroyed. Also when doing the install somehow I shorted the light control which also does the door lock, that cost me $1200 at the dealer.
