Driving me Nucken Futz!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Biff, Aug 31, 2010.
  1. Aug 31, 2010 at 7:30 PM
    Biff
    Biff [OP] What could go wrong?
    Winnipeg
    07 SR5 Doublecab
    Bilstein 5100's all around, fronts set to 1.75, 18" Method Race Wheels, 285/60/18 Cooper Zeon LTZ
    ....First off i searched.
    I guess this is a kind of strange one, but....
    Has any one or does anyone have a seat belt squeak? My drivers seat belt squeaks and creaks right where the seat belt loops through the connector when it is latched in. It drives me crazy!
    If anyone has had this, what did you do for a solution? One solution is to buy a new seat belt, but i imagine that is not the most cost effective repair and i know that we have some great - do it yourselfers here, so i thought I'd ask.
  2. Aug 31, 2010 at 7:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    My first gen did this, and I dis assembled the retracting mechanisim, and sprayed WD-40 into it.....It still made noise, but about 2 months later, it stopped, and never made noise again.....
  3. Aug 31, 2010 at 7:36 PM
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    Fixed that for ya Chris.
  4. Aug 31, 2010 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!! Nope....Im guessing the lube worked its way into whatever was making the sound.
  5. Aug 31, 2010 at 7:40 PM
    Range 44
    Range 44 Well-Known Member
    Georgia
    2008 FJ TTE
    Just bought a 2011 and it rattles right by my ear!
  6. Sep 1, 2010 at 5:23 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    My '10 does the same .... just a little bit ..... letting it run its course for now.
  7. Sep 1, 2010 at 5:27 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    My passenger side seat belt hits against the side pillar when nobody is sitting there. Drives me crazy!!!! Oh....my rear springs squeak enough, dont need more.
  8. Sep 1, 2010 at 5:53 AM
    JTO
    JTO Well-Known Member
    San Diego
    PreRunner Sport
  9. Sep 1, 2010 at 6:20 AM
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    Mine did in my jeep. I got rid of it and put a harness in. 
  10. Sep 1, 2010 at 6:23 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    yup, my 07 did that too. it was super annoying when I was out in the country on rough roads or had the windows down.
    I also had the squeak but it sounded like it came from where you click the buckle into...maybe try some wd40 or some kind of teflon lube.
  11. Sep 1, 2010 at 6:33 AM
    pinktaco808
    pinktaco808 Hot Steppa
  12. Sep 1, 2010 at 6:40 AM
    Biff
    Winnipeg
    07 SR5 Doublecab
    Blowing it up sound good but....i was talking about the part that clicks into the locking mechanism by you lap. The part that you grab in your hand and pull down to connect. The seat belt material seems to creak in where it passes through the male connector part (best way i can describe this). It creaks when it is connected on there is tension over your lap.
    I have thought about trying to lube it up some how, but i feel that that lube would then get on your clothing as you retract the seat belt. It is the friction of the material and the tension going through the buckle. If i pull on the seat belt while it is connected it will creak.
  13. Sep 1, 2010 at 7:36 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Try to see if you could lightly sand the area making contact with the lap belt. Maybe there is a little catch there that is causing this annoyance for you.
  14. Sep 1, 2010 at 7:39 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    turn the radio up to about 25-30 and it will go away :D
  15. Sep 1, 2010 at 7:43 AM
    Biff
    Winnipeg
    07 SR5 Doublecab
    That's how i fixed my rear leaf spring squeak!
  16. Sep 1, 2010 at 10:53 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    For the rear leafs you can buy some grease from the dealership or do as I do. When I change my oil I rinse (with the hose) my leaf springs then spray a healthy amount of WD40 between the leafs. That works for a while and when it does return it is almost time for an oil change. Depending on how often you pass on a dusty road.
  17. Sep 1, 2010 at 3:17 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The rear seatbelts on my AC drove me nuts banging against the walls for a while until I realized I should just buckle them up and leave them that way. No more noise from them. Took me a while to realize what the noise was.
  18. Sep 1, 2010 at 6:36 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    2010 here, and I've never noticed a rattle but now that you have put the idea in my head I'm sure I'll here it now. Thanks! :)
  19. Sep 1, 2010 at 6:41 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    lube can work wonders:D
  20. Sep 1, 2010 at 6:42 PM
    middiedefense
    middiedefense like a boss
    Joe
    GA, MD
    09 Access Cab. V6, 6spd, sr5, 4x4, OME 3" kit
    OME 3" Complete kit, TRD O/R Wheels (rattle can flat black), Black Badges, Ultra Gauge
    Maybe its because I've only ever had POS vehicles but I hardly ever notice any of the little nuances with my Tacoma until I read about them on here. Damn you TW a blessing and a tragedy
