Driving on HIGHWAY.. TRUCK SHUT OFF!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mkon334, Jan 18, 2020.
  1. Jan 18, 2020 at 5:39 AM
    mkon334
    mkon334 [OP] Well-Known Member
    CT
    2015 Toyota Tacoma SR5
    What's up Tacos,
    I was driving to work today and all of a sudden I see my abs, slippery roads condition, maintenance required, and air bag light pop up. Next my radio shuts off... so I start to panic lol NEXT, my speedometer kept on moving up and down and the engine started to choke. Lastly, I moved over to the side of the highway and the truck shut off. I tried starting the truck and nothing. The battery works. Overall got a Uber to work luckily I was an exit away from work but WHAT CAN THIS BE?
  2. Jan 18, 2020 at 5:47 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Radio shutting off by itself sounds like an alternator failure.
  3. Jan 18, 2020 at 6:08 AM
    c212
    c212 Well-Known Member
    First thing I'd be looking for would be loose or corroded battery connections and/or an internal battery short. Then whether the battery cables are tight at the other ends. Then ground connections, especially ones that are screwed into the frame, 'cause those are super corrosion-susceptible. If you can find the one the main computer relies on for its ground point, take a real close look at that.
    mkon334[OP], grrck and TacomaUSA like this.
  4. Jan 18, 2020 at 6:17 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Please define.
  5. Jan 18, 2020 at 7:13 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Does it crank normally or do the dash lights and such just work? All newer vehicles, if voltage drops past a certain point, will shut down the computer to protect it from damage.
  6. Jan 18, 2020 at 7:17 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Yea, just because the battery seems okay, doesn’t meant there’s not a bad cell or isn’t sulfated. Wouldn’t be a bad idea to have it tested if there is a charging system problem.
  7. Jan 18, 2020 at 8:49 AM
    mkon334
    CT
    Thanks everyone. Its luckily just the alternator. The lights would be on but the truck would not turn on.
  8. Jan 18, 2020 at 8:49 AM
    mkon334
    CT
    it is -_- thanks man
    fixnfly[QUOTED] likes this.
  9. Jan 18, 2020 at 8:49 AM
    mkon334
    CT
    Thanks man
  10. Jan 18, 2020 at 8:50 AM
    mkon334
    CT
    Cranks normally and dash lights work.
  11. Jan 18, 2020 at 8:50 AM
    mkon334
    CT
    very true
  12. Jan 18, 2020 at 8:52 AM
    Too Stroked
    Tom
    Glad you found the root cause and glad we could help. I'd still get your battery checked. When the alternator went, the truck ran off the battery until it didn't have enough voltage to run critical circuits. Then the truck shut off. Dragging an old battery down that much may have damaged it.
    Greenedmc and Muddinfun like this.
  13. Jan 18, 2020 at 9:03 AM
    mkon334
    CT
    hmm good to know. I got it towed home by my uncle and its at his shop. So far its the alternator.
  14. Jan 18, 2020 at 10:42 AM
    Muddinfun
    Muddinfun Well-Known Member
    Next post.
    “I bought an alternator from Autozone and the battery light on the dash is on. My voltmeter shows 14V.”
    Hint: Don’t buy an alternator from Autozone. Or Oreilly. Or knecht’s
    TnShooter and Too Stroked like this.
  15. Jan 18, 2020 at 11:29 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    FYI: Denso rebuilt from Carid $117 or Rockauto $123 comes in 2-3 days - same as the dealer rebuilt but not $400-700.
    Muddinfun likes this.
  16. Jan 18, 2020 at 1:12 PM
    fixnfly
    S.W.PA
    Yeah, don't cheap out on the alternator. It's important!
    Too Stroked and Muddinfun like this.
  17. Jan 18, 2020 at 1:21 PM
    c212
    Well, I sure was wrong on THIS one...
    :annoyed:
    whatstcp likes this.
  18. Jan 19, 2020 at 4:40 AM
    daytrader2
    daytrader2 Well-Known Member
    mw
    2" suspension lift/wheel spacers.
    I don't know if any of you guys have ever tried it, but you can "make new" an old battery by dumping out the acid, flushing it out real good, and then filling it up with a water/Epsom salt mixture and trickle charging it for like 24hrs. I've done it before, it seems to work. I tried it on a bud's kid's Camry and as far as I know, its still working. And that thing was completely dead and wouldn't take a charge. I also did it on my riding mower last spring and it worked all summer. There's videos on YouTube about it... its a $3 battery rebuild if you're "not cheap" but "frugal" as I like to say. Plus its fun. Wear eye protection!!!!!
  19. Jan 19, 2020 at 5:16 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    And capture all of the waste for proper disposal!
    Jimmyh likes this.
