Driving on Ice
Discussion in 'Georgia' started by Early B., Jan 18, 2018.
  1. Jan 18, 2018 at 10:01 AM
    Early B.
    Early B. [OP] Well-Known Member
    Brad
    metro Atlanta
    2014 2.7L, 5 lug Tacoma
    18" tires and rims, 2.75" Procomp lift, Fox shocks in rear.
    You guys will have to forgive my simple questions, but I'm from the south and never go off road, so I didn't feel the need to spend the extra money for a 4x4. This is my first truck. I learned today that a rear wheel drive truck is horrible for driving on icy conditions. I barely got out of my subdivision this morning! Aside from adding several hundred pounds to the bed, what are some other techniques for driving on ice?
  2. Jan 18, 2018 at 10:03 AM
    Bullnettles
    Bullnettles Well-Known Member
    Jared
    Houston
    2017 OR DCSB
    Ice is dangerous unless you have studded tires. 4x4 will help in conditions where you still have traction, but all four regular tires on ice, you're along for the ride.
  3. Jan 18, 2018 at 10:07 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Don't drive on ice...period. Unless you have studded tires.
    Being from Atlanta, I wouldn't worry about it too much as it's so rare.
  4. Jan 18, 2018 at 10:08 AM
    Zuba987
    Zuba987 Well-Known Member
    Enola PA
    2006 ACLB V6 auto 4x4
    Fully armored, STT Pros and Methods.
    Just don't give the truck too much throttle.. once you have momentum and on the road or highway, and there is icey conditions, too much gas can cause the tires to spin and loose control. Just take it slow haha
  5. Jan 18, 2018 at 10:11 AM
    WarrenG
    WarrenG Well-Known Member
    Spin tires until ice melts.
    crisanalex likes this.
  6. Jan 18, 2018 at 10:12 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
  7. Jan 18, 2018 at 10:14 AM
    crisanalex
    crisanalex Well-Known Member
    Alex
    Sac, CA
    17 Taco sr5 4x4
    stock (for now)
    Damn, imagine accidentally driving over someone's foot or some critter running across the street.
    scottalot likes this.
  8. Jan 18, 2018 at 10:16 AM
    Eric NJ
    Eric NJ Well-Known Member
    New Jersey
    ok to the OP, I am glad that you posted your question. People have the false idea that a 4X4 helps when it comes to STOPPING on ice OR snow... it doesn't. I was down in Birmingham two years ago when that huge ice storm ripped through the southeast. I was the only guy who was able to drive through it while everyone else was off the road in the ditch. *if you know how to drive off road in the mud, then you dont have any idea how to drive on ice..
    OK so here is what you need to know...
    1. Go slow because stopping is the problem
    2. 4WD will not stop you. If you are in icy conditions, downshift to a lower gear and let your transmission slow you down. Brakes will make it worse. So if you feel yourself sliding you lift off of the gas and dont touch the brake
    3. You should be driving in a lower gear from the start if you know there is ice.
    4. going down a hill with ice... first DONT. If you have to then do the following...
    A. Keep your truck in the lowest gear (1)
    B. Drive on the side of the road with your two right wheels on the grass. You will have grip there.
    5. Shoveling snow into your bed only helps you to get moving but will not help you to stop.
    TacoTRD78, Kyitty, medic2230 and 2 others like this.
  9. Jan 18, 2018 at 12:22 PM
    Early B.
    Brad
    metro Atlanta
    When I moved to Atlanta 25 years ago, I didn't have to worry about snow and ice because it was so rare. With global warming, the winter season has changed dramatically. I bought a snow shovel last year!!! It came in handy yesterday because I had to shovel my driveway which has a steep slope.
  10. Jan 18, 2018 at 12:23 PM
    Early B.
    Brad
    metro Atlanta
    Great response. Thanks.
  11. Jan 18, 2018 at 12:29 PM
    TacomaUSA
    TacomaUSA Cross Country Tacoma
    PA
    2007 Tacoma TRD Sport 4x4 Access Cab- 6 speed
    Wow that's awesome. Emo, but awesome. lol
    Well said. Ice on the road has no friends. No one wins with ice.
  12. Jan 18, 2018 at 12:30 PM
    medic2230
    Murph
    Bama! Roll Tide
    ^^^This.
  13. Jan 18, 2018 at 12:35 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    In the winter months it's truly all about traction. Your biggest improvement in traction is TIRES. The TYPE of tire and the specific rubber compound are critical. Bridgestone Blizzak tires for example are amazing in the winter (but terrible in summer).
    Blizzaks on a hockey rink. Literally.
    https://www.youtube.com/watch?v=_Rms9B45clg
    That said, on sheer ice even the best snow tire can't prevent all issues. Speed is your next biggest determining factor. Slower is better. Torque is the next issue. Too fast/heavy acceleration will causes a spin and loss of traction. Sudden braking causes loss of traction. As mentioned above use your transmisison/engine to help you decelerate when possible. Avoid heavy brake pressure.
    Time is your biggest ally. Give yourself lots of time/space to react to things.
    TacomaUSA likes this.
  14. Jan 24, 2018 at 12:10 PM
    Toyko Joe
    Toyko Joe Here for the pictures
