Driving on pavement with 4x4 question!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ssjtitanx, May 10, 2024.
  1. May 10, 2024 at 5:54 PM
    Williston
    Williston Unknown Member
    2014 Tacoma DC 4x4 V6 040 [SL] SR5 4x4 [ED] Entune Audio Plus [TO] V6 Tow Package
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) MSRP: $27,885 Retail Price As Equipped: $31,845
    Anti-lock brakes, VSC, sway control, roll-over control, rev limiter, electronic trailer sway control when you have the trailer plug connected, keep you from doing a 56+ mph shift to 4H, Lock-out prevention with the key still in the ignition?.... Yada Yada Yada?:
    > Yes <
  2. May 10, 2024 at 7:16 PM
    ConantTaco
    ConantTaco Well-Known Member
    Dave
    2019 Tacoma TRD Off-road
    Theoretically yes. Practical or advised no!
  3. May 11, 2024 at 4:31 AM
    willie2
    willie2 Well-Known Member
    Nova Scotia Canada
    4 Banger 5 spd
    All this hubbub about 4x4 "do this, don't do that" pavement driving procedure brings up a question. If occasional driveline loading and scrubbing of tires caused by turning in 4wd on a high traction surface can cause damage then spinning and grabbing in low traction conditions such as spinning one wheel on ice and then suddenly hitting dry pavement must cause real havoc. Wouldn't the driveline be more durable than that?
  4. May 13, 2024 at 8:30 AM
    AMMO461
    AMMO461 TACO/FJ/FJ
    SoCal Hi-Desert
    2021 TRD Off Road DCSB OD
    I Understand what the manual says and I read it. Real world operation in a 2021 TRD OR with 285 tires was 55 MPH per the dashboard speedo. YMMV.
  5. May 14, 2024 at 2:26 PM
    Cl9kev
    Cl9kev New Member
    Kevin
    2019 white SR 4x4 Dcsb
    According to the manual you can engage 4H up to 62mph nothing above or it will not engage and beep.
    AwesomeLaw68[QUOTED] likes this.
