Driving on Pavement
Discussion in 'Technical Chat' started by luk8272, Oct 30, 2008.
  1. Oct 30, 2008 at 9:05 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I don't do this but am curious as of to why.
    Back in the day we had vehicles with spools and posi rears that were almost always locked due to changing spring and clutches. Why is it so dangerious to drive today with your rear locked and not above 5mph?
    I know the idea as I am mechanically inclined and know what the book says. I have a 72 chevelle with over 600hp, my rear end is worked over very much so, I baby her on turns to guarantee not to harm anything but still drive everyday on the streets. Is there a difference in the rear ends. Basically they are the same as much as I can tell. Thanks just curious.
    It is my opinion that you can drive with your rear locked as long as you are mindfull. Especially in a straight line.
  2. Oct 30, 2008 at 9:07 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Maybe cas alot of people don't know how to drive these days??? just a thought!
  3. Oct 30, 2008 at 9:17 AM
    Radelix
    Radelix Runs with Scissors
    Los Angeles
    Silver 05 PreRunner
    Debadged, Satoshi, and a light foot
    I think the reason is that you have 2 drive wheels that are locked at one speed hence they scrub in turns. And when you take a tight turn it will tend to want to push the car straight since neither wheel will want to give up its traction. Not to mention it puts a lot of stress on your axle which could then unwind in a very unkind way
  4. Oct 30, 2008 at 9:20 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    That's the same as it has been since vehicles have come out. Why are they telling us not to do it now but older vehicles are still rolling around without any troubles? Also why do they tell you not to go over 5mph? I understand the philosophy, but don't have the answers.
    You are absolutely correct on what you have said.
  5. Oct 30, 2008 at 9:23 AM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    a posi rear end will still allow some slippage due to the clutches and gear oil. The locker in the TRD slides a pin through make the rear axle truly solid, no slippage (except for the tires hopping).
  6. Oct 30, 2008 at 9:25 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Bauer are we related??? haha
  7. Oct 30, 2008 at 9:26 AM
    Radelix
    Los Angeles
    Silver 05 PreRunner
    Well I think the answer to that is that most people are used to an open rear end and any difference on that would cause problems. If you can drive with an LSD or a locked rear end go for it. The not going over 5mph is a safety thing since most people would not know how to handle it. Ever watched a locked rear truck try to park in a snowy lot with someone that cant handle it...well hilarity insues.
    Generally spools and such are now for just offroad. Most roads are paved now generally negating the traction benefits of a locker or LSD for most. In addition most cars are not performance minded and dont really need them.
  8. Oct 30, 2008 at 9:31 AM
    P. Bauer
    San Jose
    Radelix, I understand what you mean. I completed the locker-mod on my TRD Off-Road and use it all the time in 2WD, and well above 5 mph too. I just make sure to engage/disengage it at lower speeds and not make tight turns.
    =D
  9. Oct 30, 2008 at 9:32 AM
    P. Bauer
    San Jose
    I don't know. Bauer is a pretty common name. Me=CA You=PA, don't know if I have family in PA.
  10. Oct 30, 2008 at 9:32 AM
    Radelix
    Los Angeles
    Silver 05 PreRunner
    Alright, I guess to answer your other question....people are idiots
  11. Oct 30, 2008 at 9:33 AM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    haha im just messin.... alot around here to!!
  12. Oct 30, 2008 at 9:33 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    Buddy has driven a 67 camaro with a spool in it for years no ill affects.
    Thus far I have gathered that it is most likely to protect themselves.
  13. Oct 30, 2008 at 9:36 AM
    Radelix
    Los Angeles
    Silver 05 PreRunner
    He probably doesn't drive it like a damn fool either
  14. Oct 30, 2008 at 10:05 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    No we don't cause we don't wanna fix it. It is a 10 sec car, so she does get used.
  15. Oct 30, 2008 at 10:06 AM
    Radelix
    Los Angeles
    Silver 05 PreRunner
    She must be a blast to take down the track. But back to topic, that car is purpose built and is used it specific circumstances. Then again maybe i didn't understand the question
  16. Oct 30, 2008 at 10:21 AM
    bvalistic
    bvalistic Well-Known Member
    long beach ca
    trd sport
    just for safety...racers know what's the benefit pro/con of posi diff...regular drivers don't :)...
  17. Oct 30, 2008 at 10:23 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    He drives it every day, makes someting like 11-13mpg. I was just wondering why they act like the rear ends are so fragile. I think we put his rear in around the end of 2001. Hell we go to sonic and the grocery store in it. Way more fun to drive than his silverado. The rear ends just aren't that fragile, unless our trucks are, thats what I wasn't certain of. But at the dealerships they have the members on a peg board and they look pretty damn heavy duty.
  18. Oct 30, 2008 at 10:39 AM
    Radelix
    Los Angeles
    Silver 05 PreRunner
    I dont think they are that fragile but its more the flesh and bone thing behind the wheel that they are worried about
  19. Oct 30, 2008 at 11:16 AM
    camsbored
    camsbored Well-Known Member
    Raleigh, NC
    08 PreRunner DC/Sport/LB
    Kenwood DNX8120, Homelink mirror, Valentine One hardwire
    If you know what you're doing then go for it... around here most probably know how to drive and how various diffs work so it's not an issue.
    If Mrs. Butterworth buys a Tacoma, on the other hand, Toyota has prevented unnecessary trouble by telling her not to engage the locker on the way to Bingo.
  20. Oct 30, 2008 at 11:23 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Kaplan, Louisiana
    I like that, overall I was curious to see if others felt the same way or if there was something else that I could learn. The more you know the better prepared you are. I don't even have a locking rear diff.
