Driving on the beach...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Xewkija631, Dec 1, 2010.
  1. Dec 1, 2010 at 7:51 AM
    Xewkija631
    Xewkija631 [OP] Well-Known Member
    LI,NY
    2011 BLACK DC TRD OFF ROAD
    This is my first 4x4 and I just got it last night and love it! I will be posting up pictures soon. However my question is as follow.
    1) do you need a permit to drive on the beach? I always see trucks on their but never knew the laws...?
    2) when driving on the beach do you need to deflate your tires a little bit or no? And so you put it in hi4 or lo4?
    Probably some dumb questions but I have noooo idea.
    Thanks
  2. Dec 1, 2010 at 7:56 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Permits for beaches depend on where you live. Some require them, some don't. Use 4-Hi, 4-Lo is for more extreme uses where you need slow speeds and precise movements (crawling for example). You may not need to deflate your tires (depends on the sand) but it will make it easier to make it across the sand since it spreads your weight better. It just means you need a way to inflate your tires when you go back to the road.
    http://www.tacomaworld.com/forum/of...a-beach-4wd-32-psi-15-psi-see-difference.html
    Check out this thread about lowering tire pressure and the advantages. It's a great illustration!
  3. Dec 1, 2010 at 7:57 AM
    Firetech
    Firetech Well-Known Member
    Ralph
    Maryland
    2010 SR5 Off Road
    Need to check local laws about permits, It helps to lower pressure to 15psi., 4 hi will be ok, 4 lo when you get stuck.
  4. Dec 1, 2010 at 12:42 PM
    97T
    97T Resident T100 guy
    Melt
    Littleton, CO
    97 T100 xcab 5spd 2wd
    soundstream 550.2 amp, 2 eclipse 10" subs, 4% tint rear window, 20% sides, 6" sunstrip, clear bumper lenses, avital 4103 alarm with keyless, BF Goodrich Rugged Terrain T/A 235/75/15, 15X7 6-5.5 0C Unique 298 rims
    x2
  5. Dec 1, 2010 at 12:46 PM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    Live on the beach and I go all the time. No lower pressure. 4-HI works. It's fun to pull people out of sand. Made lots of gas money. Where do you live?
  6. Dec 1, 2010 at 1:16 PM
    97T
    Melt
    Littleton, CO
    for some reason this thread makes me want to throw this pics up ... from summer 07 at daytona beach, fl ..... rental ftw!!!
    Uploaded with ImageShack.us
    wasnt buried yet but a guy with a tacoma offered to pull us out before it got bad ... tide was coming in ... had tried turning the traction control off but that just seemed to dig it in more
    on another note .... id never buy a rental from florida just cause of the dumbass shit we did in that thing, drove it thru the salt water .. etc
  7. Dec 1, 2010 at 1:18 PM
    Xewkija631
    LI,NY
    I live in NY, Long Island
  8. Dec 1, 2010 at 1:19 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    lol the sand at daytona is practically asphalt.
  9. Dec 1, 2010 at 1:36 PM
    97T
    Melt
    Littleton, CO
    yea but with the high tide we were having to get into the soft stuff .... we were making a uturn and that happened .... i think my buddy has another pic of it stuck from the side, already emailed him to get it ... wasnt into wheeling then so didnt know about airing down
  10. Dec 1, 2010 at 3:01 PM
    NamBam
    NamBam Member
    Birmingham, Al
    2014 DBSC SSM Off-Road
    Leave your tires alone, and in 4H. Should do just fine.
  11. Dec 1, 2010 at 3:12 PM
    surfrat
    surfrat Well-Known Member
    LI, NY
    icon coilover, total chaos UCA, allpr expo, icon 2.0 rear,wet okole
    theres about a zillion different permits here...state 4x4 access is for fishing only..suffolk county passes are for recreation as well as fishing...air down..our sand isnt like FL sand..the beaches arent for wheeling..tread lightly
  12. Dec 1, 2010 at 5:21 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Wow... you need to understand that maybe Florida has concrete for sand, other places do not. It depends on the sand, moisture in the sand, humidity/ temperature, tires, limited slip (traction control) and 4WD.
    However, the one true rule in sand driving... IF you get stuck don't gas it and spin the tries any more once forward movement stops... Because the only movement left is DOWN.
    Get out, clear away any built up sand from in front of the tires (and the bottom is you burried it)... and DEFLATE the tires so they look nearly flat... 10 psi should do it. If you dropped to 15 psi before going into the sand, you probably wouldn't be stuck.
    2WD or 4WD doesn't matter... let the air out of all 4 tires. If the ocean is close and you have a bucket... pouring water in front of the tires makes it easier to drive out... Wet sand is firm and stays... Dry sand is like tiny ball bearings and traction is difficult.
    Deflating greatly increases the tire's surface area in the sand... You want to FLOAT on top, not dig in... Mud tires and 3 ply sidewall tires are harder to use in sand and require more deflating than highway tires.
    Example... take a pencil (or pen) and push it in to the sand. Now use the same downward force with your open palm hand. One buries itself and the other floats on top. This is an exaggeration of course, but helps you to see the difference between a narrow or fully inflated tires and a wider, deflated tire.
    Because conditions change the sand, I will first drive onto it fully inflated. In the winter, on the San Felipe, Baja beaches my 2010 with Traction Control drove with ease. A return in the summer and it struggled, as you could see in those photos I took of before and after deflating to 15 psi.
    Bring a precision tire pressure gauge that reads below 10 psi and an electric air pump that clips onto the battery instead of one that plugs into the lighter... It is just the battery clip models can fill 3 times faster (2-3 minutes per tire vs. 6-9 minutes for 15 psi added).
  13. Dec 1, 2010 at 5:28 PM
    97T
    Melt
    Littleton, CO
    yea i figured youd chime into this thread eventually
  14. Dec 1, 2010 at 5:40 PM
    JTP
    JTP Active Member
    Long Island, NY
    '11 DCSB Off-Road
    Xewkija631 welcome to the 4x4 Tacoma. Anywhere you go on LI requires a beach driving or surf fishing permit. State, county, or town it depends where you live. To drive on NYS beaches it's for fishing only, about $60 year. Suffolk is for recreation, maybe $75 a year (its been a while). Town of E. Hampton is recreation, free for residents.
    Don't forget to air down please. 12-15psi is good in our trucks on this sand. Its not only easier on your truck but helps keep ruts to a minimum thus not as bad on the erosion.
    DEC, Marine patrol, or PD can and will ticket if you give them a reason. Some locals may also become unfriendly too.
    Tread lightly, :)
    JTP
