driving the 5speed on the beach
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eman5pt0, Aug 1, 2011.
  1. Aug 1, 2011 at 10:15 AM
    Eman5pt0
    Eman5pt0 [OP] Well-Known Member
    E
    NY
    took my truck out on the beach yesterday, was awesome though i did burn the sh*t out of the clutch at one point and stalled it out. I think my issue was i stopped behind someone mid turn. when i tried putting it in gear i wasn't moving but reving. at first i thought my clutch was slipping but after i got out of it and parked i realized i might have had a hard time because i was mid turn and from a dead stop it would be easier to get it in gear with the tires straight.
    any advise ?
    i have been driving a 5 speed for about 7 years now so im not a n00b. just a n00b at 4x4 in sand
  2. Aug 1, 2011 at 1:22 PM
    HuntnTruk
    HuntnTruk Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    Yea I burned my clutch a little in the sand. I was pissed but it was hardly at all. Air down your tires and keep momentum. I have little experience in sand but your driving habits should probably be similar to when in snow.
  3. Aug 1, 2011 at 1:30 PM
    2girlsdad
    2girlsdad Active Member
    Garner, NC
    V6 4x4 TRD Off Road Sport
    4 Hi or Lo? My guess is in high....try low range
  4. Aug 1, 2011 at 1:32 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    go into 4 low or you will burn it alot. if in deep sand
  5. Aug 1, 2011 at 1:43 PM
    sutherlandan
    sutherlandan Member
    I recently towed a trailer w/ seadoo and a bed full of gear camping with my 5 speed, had to do some maneuvering around hilly terrain at the camp site to park/launch it. At one point I could definitely smell come clutch a roasting, would 4lo be better in these situations? Wish I thought of it at the time. Also, what's the general consensus on downshifting? Is it worth it? I've gotten good at rev matching for downshifting coming to a stop and to accelerate, this technically shouldn't wear the clutch at all, right? I'd rather replace pads then the clutch any day though.
    Also, does anyone else find 2nd gear absolutely uselss with the 5 speed? What was Toyota thinking??
  6. Aug 1, 2011 at 2:33 PM
    stangkeip10
    stangkeip10 Well-Known Member
    Cincinnati
    '10 Magnet Gray 4x4 Access Cab SR5
    BHLM, Black OR TRD wheels, BFG Mud terrains, yellow wire mod, 5100s @ 2.5, toytec tsb aal
    if it is soft sand just throw it in 4lo and you shouldn't need to clutch hardly. not sure what tires you have but airing down made a big difference as well.
  7. Aug 2, 2011 at 5:11 AM
    kb1jop
    kb1jop kb1jop
    Rick
    Webster, MA
    2020 Magnetic Gray Metallic SR5 Double Cab
    Factory Towing Package OEM Bed Mat Hard Tonneau Tacoma All-Weather Floor Mats
    Like others have said. Many places it's required and it works great. The tires roll wider and flatter across the sand and you don't dig in so much. I go down to 18psi in RI. Also agree with using 4LO. You can still shift into the higher gears if necessary but it's better starting out because you go slowly and minimize wheel-spin.
  8. Aug 2, 2011 at 7:21 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Best tip: never stop in the sand! Other than that, air down and use low range.
  9. Aug 2, 2011 at 9:28 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If you must stop in sand, take off slow and have your wheels straight.
  10. Aug 2, 2011 at 10:53 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    The less resistance, the faster you go in sand.
    Wheels straight, let it out slow till it starts grabbin then roll throttle on.
    4WD has nothing to do with sand, sure it's easier..but if you air down, a 2WD open diff will float through the sand...I'm talking air down to like 8-10PSI.
    and a 2WD locked will even be better..
    I've seen 6000 lb trucks make it through anything on the sand in 2WD..but they were air downed to 8-10PSI.
  11. Aug 2, 2011 at 1:29 PM
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    If you are in the sand often, think about what tires you have on the truck.
    An M/T that is put on because it looks BA is not good for sand!
  12. Aug 2, 2011 at 5:19 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Air pressure is everything in sand!
    4WD 15-20 psi typical
    2WD 7-10 psi (or those 4WDs with mud or multi ply tires)
    I find high range to me superior for sand driving... Low range increases the torque so much the truck tries to dig in. However, as I am in an automatic, it may be different.
  13. Aug 2, 2011 at 10:43 PM
    Eman5pt0
    E
    NY
    Thanks for the input everyone. I was on a trail that lead to the beach and the sand was a bit deeper than the beach itself. I was in 4w hi so next trip maybe ill use 4w lo. My tires were down to about 25 psi. I guess I can afford to let a little more out. Thanks again
    Eric
