Driving unaligned
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NorthernMinnesotan, Feb 16, 2021.
  1. Feb 16, 2021 at 8:53 AM
    NorthernMinnesotan
    NorthernMinnesotan [OP] New Member
    2021 TRD OR DC
    Question:
    I am putting a 3" lift on my 2021 TRD ORDC. My dad has a heated shop with a lift. I'd really like to do the install there over the weekend, but I wont be able to get it aligned until I get back home. Roughly 160 miles. Is this too far to drive without an alignment?
    Thanks.
  2. Feb 16, 2021 at 9:26 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    Personally, I wouldn’t drive it that far after a 3” lift. You might get lucky and it’ll drive straight and be ok or you might need two front tires by the time you get home.
    A while ago I replaced a tie rod end on one of my Dodge 3500’s and misread my tape measure (fast and nasty ‘Farmer’s Alignment’) Within a day it wrecked an almost new $250 dollar tire.
  3. Feb 16, 2021 at 9:27 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Should be fine...it’s not like your changing the tie rods.
  4. Feb 16, 2021 at 9:57 AM
    Northerntaco69
    Northerntaco69 Well-Known Member
    2023 TRD Offroad 6MT dcsb
    Trd pro grill, blackout overlays, black tailgate inserts
    Say bye bye to for tires if you do. You'll have to do a rough alignment before you drive that far. Hell unless you change for uca's it may be so far out of alignment that the shop might not be adore to do the alignment.
  5. Feb 16, 2021 at 10:00 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    For 160mi it won't hurt anything. Might drive a little squirrely but just be careful.
  6. Feb 16, 2021 at 10:02 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Depends on what the alignment looks like afterwards. Make sure steering wheel is centered and no pulling while driving and you should be fine. I did a 2" lift and it drove fine afterwards. Spoke to local shop who said there was no point in an alignment. Dealer checked the alignment after when I was in for my first service and said it was in spec.
  7. Feb 16, 2021 at 10:02 AM
    TacomaDad18
    TacomaDad18 overlanderrr asf
    1uz 2018 SR5
    Hard round things Soft round things Metal bouncy things Shifty thing Locking thing
    You’ll be fine. I’ve been driving for months out of alignment.
    but get it done when you can.
  8. Feb 16, 2021 at 10:07 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Yep, you’ll be good. You should always put some miles on the truck after lifting but before alignment. Stuff settles, fasteners need to be retorqued, and aligning too quickly after install usually means doing it again anyway.
    It’s especially good to do if you’re putting on new/bigger shoes.....let things settle on your old tires, get it aligned when you get new ones.
