Driving vibration. Where to look?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trapt1nTheSystem, Jan 16, 2023.
  1. Jan 16, 2023 at 7:53 AM
    Trapt1nTheSystem
    Trapt1nTheSystem [OP] Active Member
    Iowa
    2019 MGM SR5
    Fox 2.0 suspension RCI skids Cali Raised roof rack and lights
    Well to get down to it I recently started having some vibration/ shutter sensation from about 25-32 mph. Annoying to say the least but also wondering if this may be a serious problem in the future?
    2019 with 74000 miles. Suspension was replaced with Fox 2.0 coilovers on front and Fox 2.0 shocks in rear. No lift in back and at best "leveled" in front.
    I've checked lug nuts and all are tight. Tires don't seem to be wearing funny.
    I know it's extremely hard to diagnose with a brief run down but people here are far more knowledgeable than I.
    Potential transmission issue or should I check u joints and driveline?
  2. Jan 16, 2023 at 7:55 AM
    WarBeard_Actual
    WarBeard_Actual Well-Known Member
    Inspect your driveline - U-joints, mainly. Have you serviced your transmission?
  3. Jan 16, 2023 at 7:56 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    U joints first,maybe check the torque on your rear axle u bolts.
  4. Jan 16, 2023 at 7:58 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Put it in 4wd, drive in a straight line, see if the vibration stops.
    Chew and na8rboy like this.
  5. Jan 16, 2023 at 8:05 AM
    Trapt1nTheSystem
    Iowa
    2019 MGM SR5
    I have not serviced the transmission. I will look into that. Appreciate it.
  6. Jan 16, 2023 at 8:08 AM
    Trapt1nTheSystem
    Iowa
    2019 MGM SR5
    I will try that. Curious what is the theory behind that?
  7. Jan 16, 2023 at 8:12 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Needle bearing.
    71tattooguy and JJ Customs like this.
  8. Jan 16, 2023 at 8:13 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    If it goes away it would most likely be the needle bearing in the front dif. Check the carrier bearing in the rear driveshaft and the angle to the rear end. These are often axle wrap from worn springs and can be compensated for with axle shims.
  9. Jan 16, 2023 at 8:14 AM
    JJ Customs
    Jay
    NV
    Always worth it to get your tires rotated and balanced too though. Before you go chasing stuff.
  10. Jan 16, 2023 at 8:16 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Toy_Runner likes this.
  11. Jan 16, 2023 at 8:16 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Needle bearing
  12. Jan 16, 2023 at 8:31 AM
    Trapt1nTheSystem
    Iowa
    2019 MGM SR5
  13. Jan 16, 2023 at 8:48 AM
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    Road force balancing got rid of 50% or more of my vibration
    Gfenza89 likes this.
  14. Jan 16, 2023 at 8:49 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The needle bearing would be the most common to just pop up as a Tacoma specific vibration. See if it goes away in 4HI. If that's not it start simple first: tires, rear driveshaft, wheel bearings, transmission.
  15. Jan 16, 2023 at 9:00 AM
    Trapt1nTheSystem
    Iowa
    2019 MGM SR5
    Appreciate the responses! Going to look into the needle bearing 1st. I do vaguely recall going down the rabbit hole and seeing it was a common issue.
    Next question I have is vaguely, vaguely what would be someone's guess as to how long before it really grenaded? If that is what it turns out to be i would try to replace it in a timely manner but it is unfortunately my daily driver and also January....
  16. Jan 16, 2023 at 9:27 AM
    JJ Customs
    Jay
    NV
    LOL, odds are you would be fine for 10-20k miles or so. Imagine all the trucks with spacer lifts and people who are not a member of this cult. Plenty of them vibrating around out there with no one caring at all.
    22Coma6MT likes this.
  17. Jan 16, 2023 at 9:27 AM
    ShimStack
    Ben
    NC
    Not really a grenade situation, just more vibration. At worst it would wear on the driver side cv shaft where it rides in the bearing as it spits out needles. There's been front diff/gear failures, but not one I've seen stemming from this. And this happens a lot.
    JJ Customs likes this.
  18. Jan 16, 2023 at 10:35 AM
    Trapt1nTheSystem
    Iowa
    2019 MGM SR5
    Very good point!
  19. Jan 16, 2023 at 10:48 AM
    Brian 0blivi0n
    Brian 0blivi0n Well-Known Member
    Wisconsin
    2018 TRD OR
    This.
    Had the annoying vibration. Replaced the needle bearing, checked drive line, torqued to spec, changed fluids...none of it eliminated the vibration. I thought I was just gonna have to just live with it. Put brand new tires on last week, mount and balanced with an alignment...vibration gone.
  20. Jan 16, 2023 at 12:37 PM
    WarBeard_Actual
    Nah, it was definitely the needle bearing bro.
