Driving with manual transmission questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nuova, Aug 6, 2021.
  1. Aug 12, 2021 at 7:41 PM
    #201
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    Sounds like you guys figured it out, but brake and clutch are totally independent systems so you can do either/or as you please. I don't recommend downshifting and slowly letting out the clutch - that's not engine braking, it's just rapidly wearing the clutch. I do recommend revmatching while downshifting and then allowing the engine to slow you down while braking, which will reduce wear on your brakes without creating excess wear on your clutch.
    This is what I was taught. Always ready to accelerate if you have to, and if you're hit and your feet come off the pedals you won't continue rolling until you hit something else. There are a lot of reasons to leave it in gear, and the only reasons not to are leg fatigue and a bearing.
    I don't recommend coasting, one for the reason given above, and two because you're not saving fuel. DFCO - as long as you're off the gas for a couple seconds and above 1500 RPMs, your fuel injectors are cutting off. If you have no reason to slow down, just throw it into the highest gear you can while staying above 1500 RPMs.
    33, owned 8 cars, 5 of which have been manuals, and have driven dozens of manuals in various settings.
    I believe someone else mentioned engine load but I think they had it backwards - your engine's most efficient when the load is the highest, which is at lower RPMs. Think bicycle gears. If you're in the lowest gear riding really fast, you aren't working very hard but you're spending a lot of energy to maintain speed. Contrast that with the highest gear at low speeds - it's really difficult to move the pedal, but you're not really using a lot of energy to do it. There are exceptions, but generally speaking, get into higher gears earlier - so long as you're not lugging the engine.
    TRD75 and Nuova[OP] like this.
  2. Aug 12, 2021 at 7:58 PM
    #202
    Nuova
    Nuova [OP] Well-Known Member
    Ashley
    Petawawa, Ontario
    2021 6MT Sport
    OTT7 Tune, 3" lift and a cracked windshield
    Cool girl? I identify more as a room temperature potato who wanted a truck with a mt. We might have to keep looking.
    Oh nooooooooo
    Thanks! Been trying to run it up around there. Getting smoother day after day.
  3. Aug 12, 2021 at 8:05 PM
    #203
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Mine feels high too. 45k miles
  4. Aug 12, 2021 at 8:19 PM
    #204
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    uh oh, she identifies as a potato
  5. Aug 12, 2021 at 8:22 PM
    #205
    Nuova
    Ashley
    Petawawa, Ontario
    2021 6MT Sport
    A humble potato?
    Toyko Joe, tacotoe and CygnusX191 like this.
  6. Aug 12, 2021 at 8:47 PM
    #206
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Potato, eh? Do not worry - You fit right in here! (Despite avatars, trucks modded sufficiently to survive a zombie attack, and keyboard bluster; I'd bet most of us here look like the odd potato!
    :rofl::rofl::rofl: :crapstorm:
  7. Aug 12, 2021 at 8:51 PM
    #207
    6 gearT444E
    Deep South
    Herculiner Hootus
    the engine load is ratio of mass air flow. It has somewhat to do with what rpm you’re at, but mostly about how far the throttle body is open. If you’re shifting too early, to accelerate you’ll have to hit the gas harder in a given higher gear than lower, hence it will read a higher engine load.
  8. Aug 12, 2021 at 8:58 PM
    #208
    6 gearT444E
    Deep South
    Herculiner Hootus
    Perform a VE test in different gears and you can watch the correlation of engine load to efficiency. Lugging a compression ignition engine can sometimes even lead to worse things besides crappy gas mileage, such as overheating of injectors.
    SilverBulletII and tacotoe like this.
  9. Aug 12, 2021 at 10:20 PM
    #209
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    Guess I needed to add a little more sarcasm or a sarcasm emoji :cool:
    CygnusX191[QUOTED] likes this.
  10. Aug 12, 2021 at 10:40 PM
    #210
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The catch point on my truck is a little on the high side too but nowhere near as bad as my old 2015 Tacoma, that one didn't catch till the absolute very top.
  11. Aug 13, 2021 at 1:58 AM
    #211
    Angel96
    Angel96 Member
    Angel
    Sheesh I still just broke mines in. I just wanted to see if it was normal to catch high being new :confused:
  12. Aug 13, 2021 at 3:47 AM
    #212
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
  13. Aug 13, 2021 at 3:50 AM
    #213
    RustyGreen
    sleeping in a chair
    Pavement Princess
    Wanting a truck with a manual transmission fully qualifies you as a cool girl. :thumbsup:
  14. Aug 13, 2021 at 6:03 AM
    #214
    ret42
    VA
    Allow me to preface with this: I am oversimplifying and making generalizations. There are simply too many variables to be able to say, "shift at x RPM for the best fuel economy."
    Sure, but throttle being open doesn't equate to more fuel consumption. A WOT doesn't pull in as much air at 2000 RPMs as it does at 4000 RPMs, and if you're not pulling as much air, the injectors aren't sending as much fuel. This is both exaggerated and proven by Turbos. At 2000 RPMs with WOT in my Supra, the turbo is still spooling up - I'm no longer at a vacuum, but I'm only getting a couple pounds of boost or so. WOT at 4000 RPMs, the turbo is completely spooled and it's bringing in ~25 lbs of boost. That's because the engine is producing a lot more exhaust at higher RPM, which it can only do if it's using a lot more fuel.
    100% agree, and I do not advocate for shifting into a situation where you're lugging the engine. My general advice is keep your truck in a higher gear. If you find yourself losing speed going up a hill or you need to accelerate and hammering it doesn't produce the results you want, downshift.
    CygnusX191 likes this.
  15. Aug 13, 2021 at 7:13 AM
    #215
    6 gearT444E
    Deep South
    Herculiner Hootus
    For sure. I think there are way too many variables such as engine type (diesel, NA, turbo), weather (altitude, temperature, dewpoint), road type (gravel, smooth, hill climb/descent), vehicle weight (towing a trailer, loaded up to max GVWR, etc). Again the best thing I've found is to get to know the feel of your vehicle, you'll know when it's in the wrong gear for your scenario. From what I've seen in my experience, given a same set of conditions, engine load will be higher if you are trying to accelerate at the same rate in a numerically higher gear. If you are in too high of a numerically numbered gear, the throttle flies open and injectors fire, engine is "lugging" to get you up to speed due to being in the wrong gear.
    CygnusX191 and tacotoe like this.
  16. Aug 13, 2021 at 9:45 AM
    #216
    cryptolyme
    Virginia
    nice. i've had some manual cars in the past that spec'd GL-4 or GL-5 and they would come factory filled with GL-5 and it would shift like crap...too slippery. Put some redline gl-4 in and shifted like a dream.
  17. Aug 13, 2021 at 12:17 PM
    #217
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    2020 TRD PRO // 2010 VETTE ZR1
    Did you remove the accumulator yet ? You said the new one feels slower to react ?
  18. Aug 13, 2021 at 12:36 PM
    #218
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Lol that's only been mentioned about 12 times in this thread :D
  19. Aug 13, 2021 at 1:00 PM
    #219
    TACOTRDPRO1
    TACOTRDPRO1 TOM S
    ROCHESTER NY
    Sorry didn't take time to read the 9,000 post. MY BAD >>>:annoyed: DON"T BE MAD AT ME
  20. Aug 13, 2021 at 3:15 PM
    #220
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    You didn't read all 9217 posts? For Shame..... It's almost like you have a life or something :D
    Nuova[OP] likes this.
