Driving with manual transmission questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nuova, Aug 6, 2021.
  1. Aug 13, 2021 at 4:08 PM
    #221
    Chickenfarmer
    Chickenfarmer Well-Known Member
    Greg
    21 OR MT, 85 PU, 99 PR
    I would like to. I haven’t really looked into how much trouble it will be.
    CygnusX191 likes this.
  2. Aug 13, 2021 at 6:33 PM
    #222
    manncura
    manncura Well-Known Member
    2020 DCSB 6MT Sport
    This guy is my MT hero....
  3. Aug 13, 2021 at 7:20 PM
    #223
    philth
    philth .
    VS
    FOR ULTIMATE MANUAL SUPREMACY
  4. Aug 13, 2021 at 7:30 PM
    #224
    Nuova
    Nuova [OP] Well-Known Member
    Ashley
    Petawawa, Ontario
    2021 6MT Sport
    OTT7 Tune, 3" lift and a cracked windshield
    How i feel shifting to 4th lmao
    Oh my
    philth[QUOTED] and CygnusX191 like this.
  5. Aug 13, 2021 at 7:41 PM
    #225
    JStarr
    JStarr Life Off the Road
    Jonathan KH6X
    Kaupo Southeast Maui, Hawaii
    Tacoma 3rd Gen 2017 quicksand TRD OR, T4R 5th Gen TRD ORP silver , Tundra 2000 TRD OR silver, Deere 5300 4wd, Wrangler 1994 ARB air lockers, 1998 BMW R100RTL.
    Making smooth shifts takes some conscious effort and practice. Use your ears and your feet to get the right combination for upshifts and downshifting, and after a while you will be good to go in any manual vehicle or bike or piece of machinery.
    Double clutching, once to leave a gear, then adjust the engine rpms, and then clutch a second time to enter and mesh with the new gear, makes it all smoother and was necessary in non-synchromesh transmissions. It's all a good challenge, and fun to get it really perfect every time.
    I wish my Taco was MT, cause I enjoy driving MT, but they are difficult to find on Maui since Servco the Hawaii distributor doesn't usually order them for stock.
  6. Aug 14, 2021 at 7:45 AM
    #226
    wolf2600
    wolf2600 Well-Known Member
    San Jose, CA
    2021 TRD-OR 6MT-SOLD
    Coyoza Tuned
    In 1st, accelerate up to around 4k.
    Foot off the gas, then depress the clutch fully.
    Now your shift should be two parts, not a single motion from 1 to 2, but two separate steps: Out of 1st, and then into 2nd. "click, click". Then release the clutch as you're adding a tiny bit of gas.
    You'll need to *feel* for the clutch release, you can't just let it out all in one go or it'll be jerky.
    Mostly it just takes practice. See if you can find an empty parking lot (office parks and community colleges on weekends are usually empty) and practice.
    Nuova[QUOTED][OP] likes this.
  7. Aug 14, 2021 at 7:49 AM
    #227
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    4k.is pretty high if you're on flat ground
    Redeemed and Nuova[OP] like this.
  8. Aug 14, 2021 at 7:49 AM
    #228
    wolf2600
    San Jose, CA
    Coyoza Tuned
    But it's a racecar.
    And shifting at higher rpms keeps the engine in the powerband so you have that 2nd gear acceleration.
    CygnusX191[QUOTED] and Nuova[OP] like this.
  9. Aug 14, 2021 at 11:51 AM
    #229
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    Racecars rev to 9k and have VTAC.
    wolf2600[QUOTED] and CygnusX191 like this.
  10. Aug 14, 2021 at 12:20 PM
    #230
    su.b.rat
    su.b.rat broken truck
    and trucks have big displacement motors so they can lug along at low rpm. so, now what to do?
    Nuova[OP], CygnusX191 and MOC221_ like this.
  11. Aug 14, 2021 at 4:41 PM
    #231
    ret42
    VA
    JZ Swap?
    CygnusX191 and su.b.rat[QUOTED] like this.
  12. Aug 14, 2021 at 4:50 PM
    #232
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Minimum 4.0 liters, apparently.
    That's where the stump pulling starts.
    I heard that on here.
  13. Aug 14, 2021 at 6:38 PM
    #233
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Dodge 225 slant 6 (3.68 liters) and a compound low 4 speed pulled plenty of stumps back in the day. :thumbsup:
    MOC221_[QUOTED] and CygnusX191 like this.
  14. Aug 15, 2021 at 1:20 PM
    #234
    MOC221_
    Frank
    Leaning tower of power with 3-speed plus OD, D100 step side.. that's what I learned on.
  15. Aug 15, 2021 at 1:39 PM
    #235
    RustyGreen
    sleeping in a chair
    Pavement Princess
    That was actually a fairly fuel thrifty package back in the day.
    Be a nice ride to fix up and cruise around with, they aren't around too much any more.
    CygnusX191 and MOC221_[QUOTED] like this.
  16. Aug 15, 2021 at 6:29 PM
    #236
    MOC221_
    Frank
    IIRC, it had the 1bbl "miser" carb setup. Well, until my father decided he wanted to make "Warlock" out of it a few years down the road.
    383 big block, 727TF and rear axle were taken from a Chysler Newport donor, and shoehorned in there with a set of glass packs. Good job it was only a 2bbl.
  17. Aug 16, 2021 at 6:48 AM
    #237
    wolf2600
    San Jose, CA
    Coyoza Tuned
    Same, except in a 74 Dodge Dart with an automatic
  18. Aug 16, 2021 at 6:50 AM
    #238
    wolf2600
    San Jose, CA
    Coyoza Tuned
    I bought a 2bbl intake for the /6 and a used Weber DGEV carb... but never installed them.
  19. Aug 16, 2021 at 8:58 AM
    #239
    RustyGreen
    sleeping in a chair
    Pavement Princess
    1978-79 Super Six package was the highest performing slant six. Factory aluminum intake and the best stock cam without too invasive of an emissions package. A mid size car with the Super Six engine, 2.94 axle running a 14" tire was both a snappy and thrifty performer.
    Cars were a lot more fun back then.
  20. Aug 16, 2021 at 9:06 AM
    #240
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Was it one of the ones with a push button automatic?
