Driving without a bump stop. Bad?
Discussion in '1st Gen. Tacomas (1995-2004)' started by scaliusmaximus, Jun 24, 2021.
  1. Jun 24, 2021 at 10:26 AM
    scaliusmaximus
    scaliusmaximus [OP] Well-Known Member
    pascal
    Los Angeles
    2001 Tacoma Prerunner XtraCab 3.4l
    none
    Realized i am missing the rear bump stop on my passenger side LCA. Only drove it for a few days like this. How much damage could this have done?
  2. Jun 24, 2021 at 10:29 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The bump stop is there for when you're close to bottoming out your suspension. It gives a rubber cushion rather than metal on metal contact. Unless you're out there jumping your truck, doing some serious wheeling or hitting insane pot holes, you did no damage because in every day driving, you're not using the full range of the suspension . You would know if you bottomed out your suspension.
    the.sight.picture and Wulf like this.
  3. Jun 24, 2021 at 10:30 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    None, unless you were towing, hauling, wheeling, heavy/hard enough for the stops to get in the game.
    Wulf likes this.
  4. Jun 24, 2021 at 10:37 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I was on a trail in Moab last year and lost a bump stop. I can tell you first hand, smacking the LCA without a bump stop when coming down off a ledge is not a fun feeling. You would definitely know if you did it.
    As long as you're just cruising around town I don't see the harm. Don't hoon it over speed bumps
  5. Jun 24, 2021 at 10:41 AM
    scaliusmaximus
    pascal
    Los Angeles
    none
    I took it up to joshua tree but wasn’t by any means wheeling. Took it slow on the dirt roads to get to the place i was staying. Unfortunately LA has very bumpy roads but i can’t recall an unusual or unpleasant feeling when driving without it this time.
  6. Jun 24, 2021 at 10:44 AM
    eon_blue
    Azusa, CA
    yeah when I lost mine on the trail, I got by without it by taking everything slowly and for the most part I was fine. But a couple ledges were just too big to avoid feeling it even by crawling down them. I would imagine on a fire road or easy trail you'd be OK, as long as you're not hitting big ruts and whoops at speed.
    How did you lose it? Did it back out of the LCA or did it break off? The weld nut that it holds it in place inside the LCA snaps off easily, that's how mine first broke off. Once that happens you can't thread another one back in. Mine is currently JB welded onto the arm haha. Works fine as long as nothing knocks it from the side.
  7. Jun 24, 2021 at 10:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Even got video proof of it too
    *wait until the end when Todd runs up to grab that bumpstop*
    https://youtu.be/6Rq7pNliYSU?t=32
    Pretty sure I had to grab it at one point a second time while on the trail :burp:
    eon_blue[QUOTED] likes this.
  8. Jun 24, 2021 at 10:46 AM
    eon_blue
    Azusa, CA
    yeah after the second time is when I decided to just finish without it, zip ties are no match for the forces a bump stop sees on the trail.
  9. Jun 24, 2021 at 10:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hey, as long as you had your lights on :laughing:
  10. Jun 24, 2021 at 10:49 AM
    eon_blue
    Azusa, CA
    I hadn't turned those on in probably 2 years, I doubt they even worked still lol. Part of the reason they're gone now
