Driving without rear driveshaft
Discussion in '1st Gen. Tacomas (1995-2004)' started by 96_taco, Feb 1, 2016.
  1. Feb 1, 2016 at 10:11 AM
    96_taco
    96_taco [OP] Well-Known Member
    Clayton sandgren
    Northern va
    1996 Tacoma 2.7 4x4 extended cab
    33" bfg mud terrains, cold air intake, flowmaster with side exhaust, manual swapped, manual hub swapped, lifted on bilsteins
    Dropped my driveshaft off at a shop to get a one piece shaft made and the finish time is looking like it won't be till Wednesday, problem is I have work on Wednesday through Saturday and wouldn't be able to pick up till Monday. Would it be ok to drive to work (15 miles, 40-50 mph) with just the front shaft if I don't drive it hard?
    MTopp and jimsmithrn like this.
  2. Feb 1, 2016 at 10:16 AM
    jimsmithrn
    jimsmithrn Well-Known Member
    Jim
    2016 Quicksand Tacoma TRD Off Road
    Great question. I cannot wait for the answers. I wonder if it would be the first front wheel drive Tacoma.
    TacoTuesday!! likes this.
  3. Feb 1, 2016 at 10:17 AM
    96_taco
    Clayton sandgren
    Northern va
    I really don't see why it wouldn't be alright, other than maybe all the torque going through the chain in the t-case but still shouldn't be a problem
  4. Feb 1, 2016 at 10:19 AM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Lol to the last post above. It wouldn't hurt but don't forget you get axle bind when your taking corners. Which might destroy your front axle if you continue to do this.
    Edit: I meant the second message on this forum.
  5. Feb 1, 2016 at 10:20 AM
    jimsmithrn
    Jim
    Rentals can be pretty cheap if you shop online. Might end up being cheaper than any damage that might happen to the truck. Risk management!
  6. Feb 1, 2016 at 10:21 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    No don't do that
    tacoguy88 and 12TRDTacoma like this.
  7. Feb 1, 2016 at 10:36 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    ^this, your rear axle allows for turns, the front is "locked" when activated. you'll shred the pinion/gears if you're on dry ground
    tacoguy88 likes this.
  8. Feb 1, 2016 at 10:41 AM
    96_taco
    Clayton sandgren
    Northern va
    I'm well aware of axle bind, but I also don't drive the truck like a race car and trying to take sharp corners all the time. Just wondering if anything could happen to it just from having no rear drive
  9. Feb 1, 2016 at 10:44 AM
    Indy
    Indy Master of all I survey.
    The front axle is only locked if you have a locker in the differential. If you have an open, which almost everyone does, there's no lock. It's exactly 0 difference between the front and rear differential action. With no rear driveshaft there's no binding involved in the tcase as there's no forced being applied by a difference between the 2 driveshafts. Driving on full traction roads in 4wd is an issue in the tcase, not in the diffs.
    Driving without a rear dshaft is no problem, it's a time honored way to get your butt out of the nowhere when you blow out something on the rear end.
  10. Feb 1, 2016 at 10:45 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I would say only do it in emergency situations. A cheap rental car should run you in the neighborhood of $150 or so. The rental car places charge more once you hit the weekend days.
    MTopp likes this.
  11. Feb 1, 2016 at 10:46 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    hmm, good point :)
  12. Feb 1, 2016 at 10:53 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    I did it with a front locker talk about torque steer lol. It's been done many times.
    musher likes this.
  13. Feb 1, 2016 at 10:57 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Perfectly safe to do it, as posted before your front diff is open from the factory and you can drive around like that, you'll have torque steer with heavy acceleration but no damage.
  14. Feb 1, 2016 at 11:03 AM
    96_taco
    Clayton sandgren
    Northern va
    Alright cool that's what I was wondering cause I've driven 4wd on dry roads before (forgot to put it in 2wd after coming out of a trail) and it would bind on turns but 4 wheeling It would only spin 1 front tire at a time so kinda didn't make since to me. Also I only make 370 a week so rental car isn't worth it to me. I'll only be driving it lightly cause everything is pretty local
  15. Feb 1, 2016 at 11:15 AM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Should be fine. At that point, it's basically just a front wheel drive truck.
    whopper likes this.
  16. Feb 1, 2016 at 2:06 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    I drove mine like that for a few days while my rear driveshaft was being balanced. No problem.
    musher likes this.
  17. Feb 1, 2016 at 2:11 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    This :thumbsup:
  18. Feb 1, 2016 at 2:22 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Wut.
  19. Feb 1, 2016 at 4:37 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I drove home 3hrs from wheeling on the highway in fwd after bending my rear driveshaft. This was ironically my last trip IFS and i was trying to destroy that....
    You will be fine if you have an open front diff, no different than a front wheel drive car. The binding in 4wd comes from the tcase, the front and rear axles dont have a diff in the tcase so thats where it binds.
    You get some crazy torque steer!!
  20. Feb 1, 2016 at 11:37 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    I drove my truck on front wheel drive while i took the rear shaft in to replace the carrier. Binding only happens at the transfer case, not the differentials. And our trucks dont come with diff lockers stock without some way of disengaging it. So unless you put a permanent locker in the front, you have absolutely nothing to worry about.
    Only thing i noticed on my truck is the front wheel drive seemed a bit "loose". If i was slowing down and going while in 2nd lets say, it woud seem there was a little play in the gears somewhere. Im assuming the front diff. Wasnt a problem though.
    MTopp likes this.
