Driving your 3rd Gen Tacoma When the Low Fuel Light is On -
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hiPSI, Mar 8, 2018.
  1. Mar 9, 2018 at 8:02 AM
    #61
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I would like to note that all pumps have internal bypasses for pressure exceeding what the fuel regulator is set for. For example, the Ducati / Ford pump has an internal 5bar (75psi) bypass and a 3bar (45psi) FPR. So, the pump 'working hard' is really a non-issue since it is always working between 45psi and 75psi.
    Beyond that, with a return line, the height to the motor, bends in the fuel rails, the 18in difference between the top and bottom of the tank is negligible.
  2. Mar 9, 2018 at 8:07 AM
    #62
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    This is fun!
  3. Mar 9, 2018 at 8:18 AM
    #63
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    We're saved! But its TW so somebody is still going to fight you.
    PHLinPHX and hiPSI[QUOTED][OP] like this.
  4. Mar 9, 2018 at 8:23 AM
    #64
    hiPSI
    hiPSI [OP] Laminar Flow
    South Carolina
    2024 Long Tundra
    There are two sides to the pump, for simplicity. There is the input (suction side) and output (flow side). That bypass you speak of is on your output side, it has nothing to do with the suction side. The suction side is ALWAYS where damage will occur, and that damage will ALWAYS be contamination, cavitation (air) or material defect.
    The pump can "work hard" even at just a few psi if there is not enough head pressure.
    Dirty Harry and tonered[QUOTED] like this.
  5. Mar 9, 2018 at 8:24 AM
    #65
    hiPSI
    South Carolina
    2024 Long Tundra
    I know. This won't be my first battle.:rolleyes:
  6. Mar 9, 2018 at 8:37 AM
    #66
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The chart in the OP's link for Tacomas is correct when on the E line (3 gallons left). However, some of you like to use the low fuel light as the E point... there, you have 4 gallons still in the tank. Of course there will be some variance so say 1/2 gal. +/- due to temperatures and how long before you actually fill the tank after the light comes on (or your needle is on the E line).
    A tank is 21 gallons (a bit more). You are not really "empty" until you run out of gas! Don't let that happen, on purpose, anyway.
    Gauge Points = GALLONS in tank (this is a 2nd Gen, but may be the same??)
    FULL= 21.1 GAL (factory figure)
    3/4 = 16 GAL (down 5 gallons)
    1/2 = 12 GAL (down 9 gallons)
    1/4 = 8 GAL (down 13 gallons)
    LIGHT = 4 GAL (down 17 gallons)
    E LINE = 3 GAL (down 18 gallons)
    I would pop into a gas station if one was very close when my gauge needle reached these points. It was very consistent within 1/2 gallon +/-.
    ConcreteTRD and tonered like this.
  7. Mar 9, 2018 at 8:39 AM
    #67
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Fractions of a PSI in suction should not be a large consideration when pushing almost 100x that on the pressure side. It's pretty much splitting hairs.
    Edit: also, anytime the fuel filter is changed, there is going to be an amount of time when the pumps will be sucking air to prime.
    All good discussion though.
    dynamicweight likes this.
  8. Mar 9, 2018 at 1:34 PM
    #68
    CanuckBlueLine
    CanuckBlueLine Active Member
    2018 Cement DCOR
    Black TRD rims
    You think people haven’t been saying that you shouldn’t drive with low fuel in your tank before 3rd Gen Tacoma came around? It had always been presented to me as a common precautionary measure not to do that in all cars. I am sorry you are offended by my post.
  9. Mar 9, 2018 at 1:39 PM
    #69
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    I've run my last 3 trucks to 200K (2 Z-71s and a Toyota Pickup). Only replaced 1 fuel pump and that was on the 97 Chevy at about 80K miles. Ran all 3 trucks out of fuel at least once. I have a tendency to ride on excitement more than I should and I always fill up after the light has come on.
    jtmiller2011 likes this.
  10. Mar 9, 2018 at 1:50 PM
    #70
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
  11. Mar 9, 2018 at 3:48 PM
    #71
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    The manual says the low light/warning comes on with approximately 3.2 gallons. Mine just came on and thruck is reporting 3.3 (SGII) and 24 miles remaining. (The reported gallons starts going silly below 1.9 and will not go below 1.1 IIRC.)
    I've been getting higher than 24 MPG; but, based on the DTE and low warning I've concluded that it will never predict more than 24 MPG.
    That would mean "please refuel" happens with about 2.2 gallons remaining.
  12. Mar 9, 2018 at 4:03 PM
    #72
    echomonkey
    echomonkey Active Member
    TRD Taco
    I've had the light come on a few times now, and gotten gas within a few miles. It always takes between 18 and 18.3 gallons, so the 3 gallon figure on that original link plays right with my experience.
  13. Mar 9, 2018 at 4:05 PM
    #73
    Lost In The Woods
    Lost In The Woods 4 out of the 5 voices in my head say go for it!
    Eric
    Buckley, WA
    21 Gladiator Rubicon Diesel
    An unusually high amount of pinstriping.
  14. Mar 9, 2018 at 5:15 PM
    #74
    David K
    Instead of believing your onboard computer, would any 3rd Gen owner simply pop into a nearby gas station (if there is one near where your light come on), and fill it up... then tell us how many gallons?
    A second gen light comes on when there is 4 gallons (+/- 0.5) in the tank... and 3 gallons when the needle is on the E Line (as the web link says in the 1st post).
    tonered likes this.
  15. Mar 9, 2018 at 5:16 PM
    #75
    David K
    I don't care who you are, that's funny!
  16. Mar 9, 2018 at 6:16 PM
    #76
    Clear7
    Clear7 Well-Known Member
    Ontario
    2017 SR5 2.7L - tried tested & proven
    Lol.. I can personally attest to that...
    Dirty Harry[QUOTED] likes this.
  17. Mar 9, 2018 at 11:20 PM
    #77
    Tharris242
    Houston, TX
    I've run mine nearly empty and everything checks out like it should and like I said... fuel light at ~3.2g; please refuel / 0 miles to empty ~2.2g; the volume reported by the OBDII vs the gas pump while filling (within its reliable range ~1.9-19.1). At the first pump shut-off it was 21.236g, and filling it to the top of the neck was 23.554g. I figured I had about 0.2g left based on what the OBDII said vs various increments I stopped at while filling.
    I'm currently on my best MPG tank ever, I'm going to go for 600 miles. It showed please refuel at 556 miles or so with 26.7 MPG for the tank (lately it's been reading about 0.2 MPG high). Stock OR V6 4WD AT w/Tonneau.
    tonered likes this.
  18. Mar 10, 2018 at 11:51 AM
    #78
    David K
    Again, you are not 'nearly empty' when the light comes on, so it sounds like you are just saying what the computer is telling you is in there when the light is on?
    I don't trust the computer's estimates... Making this a science experiment using actual observations.
    When anyone has a desire to and will share, please pop into a gas station when your light just comes on by a station. Tell us how many gallons fills it up... and not much beyond the normal click off point, just the typical rounding-off. I know you guys in Oregon cannot help because they won't let you fill your own tank there and they won't round up are see if it was a false fill.
  19. Mar 10, 2018 at 11:59 AM
    #79
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Its no myth. Pumps dont like running when there is not enough fluid/ pressure head going through them. Fluid dynamics 101.
    Eventually it will cause early wear out. Depending on how the pump is situated in the tank and how the remaining fuel sloshes around there really is no garuntee, other than its "reccomended" you dont run it low (height of fuel is less than height of pump intake).
  20. Mar 10, 2018 at 12:52 PM
    #80
    Tharris242
    Houston, TX
    If it sounds like I am just telling you what the computer is saying you are not listening. I'm telling you I've done that. There are ~2.2 gallons left when it says please refuel (~3.2 at fuel light). I know this because I drove ~50 miles past please refuel.
    Like I said, when I was nearly empty (yes, really) I pumped 21.236 gallons to the first shut-off into a "21.1 gallon" tank. I then filled it to the top of the neck, a total of 23.554. The only way to get a consistent fill is to fill it completely due to the fact that every pump will shut off differently.
    If I would have refueled when it said, it would have been ~19.2 gallons to the first shut off and ~21.3 completely (or 18.2/20.3 at fuel light).
