drizzohs '21 off-road build
Discussion in '3rd Gen. Builds (2016-2023)' started by drizzoh, Dec 17, 2021.
  1. Jul 1, 2024 at 7:14 PM
    #261
    beatadrum
    beatadrum Well-Known Member
    Jonathan
    Charleston, SC
    2023 Off Road 4x4 1999 Reg Cab 4x4
    Sub'd, great build!! I might just reach out to ADS and request the Drizzoh tune ;)
    drizzoh[OP] likes this.
  2. Jul 1, 2024 at 9:51 PM
    #262
    drizzoh
    drizzoh [OP] itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Do ittttt.
    And thanks! It needs some more new parts but I've been too busy with the Supra.
    beatadrum[QUOTED] likes this.
  3. Jul 1, 2024 at 10:13 PM
    #263
    Xsjadows
    Xsjadows Well-Known Member
    Josh
    South Bay Area
    2020 Quicksand Tacoma TRD Off-Road DCSB
    King 2.5 Front/Rear Method 701 17s w/ Geolandar M/T g003 33s
    Great build!
  4. Jul 8, 2024 at 11:39 AM
    #264
    drizzoh
    Andrew
    Arizona
    Most of my time lately has been spent getting that 80's car to be trustworthy, but this weekend I washed the truck and swapped in my spare K&N air filter (I have 2 that I rotate while one is getting cleaned). Also spent some time doing a much needed retune on the VX700/5i in the truck. This is the 4th time I've retuned these Focal's in 1.5 years. Have the frequencies dialed by now, but they continue to break-in and were super overpowering the sub by this point. It's bliss in there again now, hopefully was the last time I'll have to do so.
  5. Jul 27, 2024 at 9:28 AM
    #265
    Polythemus
    Polythemus Well-Known Member
    B.C. Canada
    2023 MGM Tacoma Trail Edition
    Toyo Open Country 265 75 r16 tires FN Countersteer Type X, 16x8, 0 offset Front clip PPF, ceramic coated.
    Love this build! everything feels balanced.
  6. Jul 27, 2024 at 3:42 PM
    #266
    drizzoh
    Andrew
    Arizona
    Appreciate it dude! It's been a lot of work to get dialed in but it's so worth it. Hopefully it will get something new soon.
  7. Oct 5, 2024 at 5:27 PM
    #267
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    I always find myself coming back and looking at this build.
    Not sure if I missed it somewhere but how much lift did you end up settling with?
  8. Oct 5, 2024 at 6:27 PM
    #268
    drizzoh
    Andrew
    Arizona
    Hey me too haha.
    I wasn't actually sure on the lift so I checked right now and it looks like I'm ~22.5" hub center to fender up front and ~23.25" rear, so I guess that's ~1.6" or so of suspension lift up front and ~1.25 in the rear. I pretty much set the front as high as it would go without the ribs on the cv boots touching. I still wish it was a little bigger because it seems like every Tacoma I park next to is the same size, but the ride quality is so much better with less lift. Will just wait until I go to 34's to get the rest of the stance I want.
    Edit: went and measured the truck and updated the numbers. Pretty close to my guess.
    Also, finally have a new mod to add to the list :cool:
    xp0nex[QUOTED] likes this.
  9. Oct 7, 2024 at 8:54 AM
    #269
    drizzoh
    Andrew
    Arizona
    It's been a while since the Taco got any money spent on it, but happy to finally update this thread with a new mod.
    I have been looking for a clean way to display the trans temp for a while since the iDatalink Maestro annoyingly will not display it. The ScanGauge II doesn't have a clean mounting option that keeps it visible at a glance, and the ScanGauge III is too big. I forget how, but I found out about this Banks gauge and A pillar pod a while back and have been wanting it ever since. My MK3 Supra has been demanding my funds lately but that's finally paid off and running again, so decided to treat the daily to some new stuff. Pumped to have a Banks part, even if it's not performance-based, just always loved their stuff.
    Enter, the Banks iDash SuperGauge. It displays way more parameters than I'll ever need and is super customizable, but the big thing is I can monitor the trans temp finally and can see if it will be worth adding a trans cooler to this, pinning the thermostat open, seeing when it's at the right temp during fluid changes, etc. Everything about this gauge and pod is super clean and I love the placement of it. The color and finish of the pod also matches perfectly. I figured the truck has everything else already, so the gauge is a nice, functional, finishing touch. With the OBD2 daisy chain splitter I have, the connection does support readings going to both the SuperGauge and the headunit simultaneously, but only if I manually enable the HU each time. I have an OBD2 Y-splitter I still need to experiment with to see if it will enable both automatically. I won't really need the display on the headunit anymore, but I like to have everything functional. Pretty happy with this little mod, I love interior stuff that you can see every time you're behind the wheel.
  10. Oct 8, 2024 at 9:01 AM
    #270
    drizzoh
    Andrew
    Arizona
    So far I'm pretty happy with this little gauge. Also happy to report that the trans temps are nowhere near as high as I expected them to be based on this forum. Below are the numbers after I got home from work last night while it was still 106° out. For now, I don't think it needs a trans cooler but we'll see how it does with longer drives and 4x4ing.
    Another thing I can now keep an eye on are the AFR's from my tailored KDMax 10 tune. They're a hair lean, but that's probably why it's a bit more efficient. Good stuff.
  11. Jan 30, 2025 at 7:20 AM
    #271
    drizzoh
    Andrew
    Arizona
    Finally have a new part to install. :hearteyes: I just need to get these PPF'd so the AZ sun doesn't kill them in 2 years like it did with my gen2's.
    The build quality on these Evo's is wayyyyyyyyyy better and these are a much cleaner design that will have people questioning if they're aftermarket. Very much more my style of an upgrade. I'm pumped to get these on.
    T-rev, McPickle, Polythemus and 4 others like this.
  12. Feb 6, 2025 at 7:38 AM
    #272
    drizzoh
    Andrew
    Arizona
    Picked up the Evo's from Hyer Quality Detail yesterday. They are now PPF'd with XPEL and ceramic coated with Ceramic Pro and somehow look better than they did before the protection went on. After bringing them home I got them prepped for the install - plastic trim from the factory lights transferred over, Superchargers installed, wiring harnesses connected and the chosen DRL configuration modules (amber with sequential turn signals) plugged in.
    I've been playing in the dirt too much lately and the truck is in desperate need of a wash so I'm thinking this weekend will be a good time to get them on. Hopefully I'll have a rad update here at the beginning of next week. The truck is going to look so much better with these than the gen2's.
    RoostrC0gburn, Broheim and Polythemus like this.
  13. Feb 10, 2025 at 7:12 AM
    #273
    drizzoh
    Andrew
    Arizona
    Well.. they are real, and they're fantastic.
    To say these are an upgrade is an understatement. Every aspect of the Evo is better than the Gen2. Overall construction is OEM quality, fitment is OEM quality, output is OEM+. Extremely happy with these and the truck looks sooooo much better.
    Sun-baked Gen2 vs Evo. This is why the Evo's got XPEL PPF'd before install.
    RoostrC0gburn, Polythemus and Broheim like this.
  14. Mar 28, 2025 at 7:28 PM
    #274
    justinlovetice
    justinlovetice Well-Known Member
    Justin
    Kaneohe, HI
    2019 TRD Off-Road
    Any chance you could get your valving specs from ADS? I've been having the same issues you were but haven't been able to get any good setups from other companies. Thanks!
  15. Mar 28, 2025 at 10:19 PM
    #275
    drizzoh
    Andrew
    Arizona
    I've asked before but never got the specifics. I didn't think too much of it as they'll likely be the only ones servicing it in the future and at that time I'd just let them know of any changes I want done. Would be cool to have the info but I'm not sure if they even logged it anywhere.
  16. Apr 8, 2025 at 9:47 AM
    #276
    Camps
    Camps Well-Known Member
    Greg
    Bay Area
    21 TRD DC
    Fox, BR6, BAMF, SSO...
    How are these brake drums holding up? any flaking or peeling?
  17. Apr 8, 2025 at 9:50 AM
    #277
    drizzoh
    Andrew
    Arizona
    No issues so far. They look like they have faded a little but zero issues with the coating coming off. Could also be that I have not really cleaned them since install, but they don't really stand out for any bad reasons anymore.
    Camps[QUOTED] likes this.
  18. May 29, 2025 at 8:47 AM
    #278
    drizzoh
    Andrew
    Arizona
    No major updates lately to the truck, just have been doing some standard servicing on it lately but figured the thread could use a bump.
    Was just about at 16k miles so I figured it was a good time to do some fluid changes. First up was to change the oil, and it was my first oil change since adding the Fumoto quick valve. Maaaan if it wasn't the smoothest oil change I've done to date on this thing. So much less mess when draining the pan. Still have absolutely no idea why Toyota decided to put the drain plug directly on the bottom, but whatever. This was also my first oil change with the metal filter cap and it was shocked at how easily it unthreaded from the engine. Another small upgrade I am very happy about. Cleanest oil change to date, but once my stash of discontinued TRD filters runs out I'm thinking it will get the spin-on conversion.
    Next up was changing out the fluid in the diffs and transfer case. I've had good luck with Redline fluids so their 75w85 went into both diffs and MT-LV went into the transfer case. I did not expect the truck to feel any different after this, but I swear it's rolling down the road with less resistance and it definitely shifts into 4WD easier and drives smoother in 4WD than before. There was more break in material on the diff magnets than I was expecting, but nothing to worry about. The transfer case does not have a magnet in the fill plug for whatever reason, so I added this one from Trail Toys when I sealed it back up. I believe there is a magnet inside the transfer case itself but it's much easier to tell the health of a sealed system based on what you find on an easily accessible plug. The good news is the TC fluid that came out so looked fresh that I would almost feel like I wasted money if it 4WD wasn't so much smoother afterwards.
    That's all for now. I have a couple parts to install still, but I've been spending all my time lately doing maintenance upgrades on the Supra and getting rid of 38-year-old rubber. I'm very excited to get that thing back on the ground and have it stay on its own 4 wheels for a while instead of living on jack stands.
    Camps likes this.
  19. Jun 6, 2025 at 9:20 AM
    #279
    drizzoh
    Andrew
    Arizona
    Had a few extra GrimmSpeed urethane exhaust hangers leftover from upgrading the setup on my Supra so threw em on the truck. I didn't expect them to do anything, but they actually stopped the exhaust from contacting the spare tire so I'll take that as a win. Might have to order a few more and do the rest of them.
  20. Jun 11, 2025 at 8:33 AM
    #280
    drizzoh
    Andrew
    Arizona
    So after swapping to the urethane hangers and driving for a few days I have noticed that they have added a decent amount of exhaust volume both inside the cabin and out. I've only ever installed urethane hangers before when installing a new exhaust system, so I haven't noticed the differences just based on the hangers themselves and I am pretty surprised at the change (though, now that I think about it, I did notice the same change on the Supra after adding the other one of these). I really didn't expect them to do much except be red, so this was kind of a shock to me. I am really liking how much more aggressive it sounds outside, but not loving how it sounds inside, just a little bit too noticeable and I really don't like having a truck that is annoying to be in. My options were to revert the hangers back to stock or install the Helmholtz chamber that MF includes with the kit that was sitting on the shelf. It seemed faster and easier to install the chamber than to wrestle with removing urethane hangers (even with the fancy Lisle pliers), so last night I threw that on and then went on a test drive to see how it was. As advertised, this addition cancelled out about all of the new droney frequencies, but I can still hear the exhaust at startup and while accelerating. The truck is much nicer to be in with that extra resonator in place so I think this is how it will stay. I really like having a quiet and comfortable cabin, and it might even be quieter at cruising speed than before which is a welcome change. I am still on board with swapping out the last few hangers, but still on the quest to find a 3-hole hanger that will be suitable for the rear as it is a somewhat unique design.
