DRL always hot?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HellinaHelmet, Aug 25, 2018.
  1. Aug 25, 2018 at 3:09 PM
    HellinaHelmet
    HellinaHelmet [OP] Well-Known Member
    Nick
    N GA
    2017 SSM DCLB TRD OR 4x4
    I installed a set of raptor lights. Used an add-a-fuse and tapped my DRL fuse. To my surprise the raptor lights are on even with truck off. Can anyone shed some light onto this?
  2. Aug 25, 2018 at 3:10 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You tapped into a always hot line.
    Taco_Coma and Clearwater Bill like this.
  3. Aug 25, 2018 at 3:16 PM
    HellinaHelmet
    Nick
    N GA
    I tapped into my DRL fuse and I don't understand why it is hot when the truck is off, the DRL LED strips are off, but my raptor lights remain on.
  4. Aug 25, 2018 at 3:36 PM
    Chito354
    Chito354 Member
    2017 DCLB SR5 4X4
    Complete speculation but perhaps the drls are switched on and off at the ground side.
    emacTR4 and PvilleJohn like this.
  5. Aug 25, 2018 at 3:48 PM
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    Did you try turning off your DRLs though? Like not on auto, but off?
  6. Aug 25, 2018 at 4:25 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Did you tap the + side..?? :facepalm:
    BlackGT99 likes this.
  7. Aug 25, 2018 at 5:58 PM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    DRL fuse is battery powered and supplies the DRL relay, which is ground switched. You need to find a switched fuse or tap into the DRL after the relay.
    emacTR4 and HellinaHelmet[OP] like this.
  8. Aug 25, 2018 at 6:03 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    That DRL circuit is wacky and there’s more to it than shown above. I posted a mod for a switched power and a always on lead to power a dash cam. It used a lead in the overhead console for a switched hot wire from the mirror compass, and that works great. But the always on tap to the cabin light switch made the DLR’s stay on too. Anyways, I gave up and just posted recommendations to run a hot up the A-column for always on power.
  9. Aug 25, 2018 at 7:09 PM
    HellinaHelmet
    Nick
    N GA
    Thanks that clears things up. Back under the hood in the AM.
  10. Dec 24, 2018 at 8:36 AM
    bottlecap
    bottlecap Well-Known Member
    Eric
    Philly/SJ
    2017 DCSB TRD OR
    Resurrecting this - I was curious what you ended up doing? I am in the same predicament and was surprised by the always hot DRL circuit.
    I was going to trace the circuit out to find the switched side but if you already found the solution, would love to hear it!
    Thanks!
    SeattleTRD17 and PvilleJohn like this.
  11. Dec 24, 2018 at 10:21 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    The DRL fuse is the power to the relay, not power for the actual DRL’s themselves
  12. Dec 24, 2018 at 10:50 AM
    bottlecap
    Eric
    Philly/SJ
    2017 DCSB TRD OR
    Yep. Got that part. I was interested in the options on where to tap to accomplish this. Switched options for low draw lighting under the hood seem limited. I was going to break out the meter to track it down but I figured OP might have solved it and was trying to save time. :cheers:
  13. Dec 24, 2018 at 12:47 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    I tapped my raptor lights into the wiring for the parking lights on the drivers side...purple is positive and white is negative. The red and black wires are coming from the raptor lights.
    vuTron, helix66 and Davi trd pro like this.
  14. Dec 24, 2018 at 12:58 PM
    Davi trd pro
    Davi trd pro Member
    David
    2019 Tacoma TRD Pro
    Raptor Lights, bed mat
    I have the same issue. Installed these lights yesterday and could not get the DRL and raptor lights to work together. Raptor lights on all the time. I ended up using the low beam fuse.
  15. Dec 24, 2018 at 1:27 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I'd like to get some small leds and do nothing like this as we'll.
    For the cam could you have tapped into the feed for the map lights? They can be turned on with the tuck off.
    And which cam did you get?
  16. Dec 24, 2018 at 1:31 PM
    bottlecap
    Eric
    Philly/SJ
    2017 DCSB TRD OR
    Ok. That makes sense. I hadn’t thought of doing it that side of the circuit. This solves my issue! Thanks so much for the pic and explanation!
    Same here David. I think I am going to try Ronzio’s method and tap into the light. I was looking in the fuse box for a solution but this will do the same thing and I can just use an add-a-fuse to protect the circuit although probably isn’t necessary as it is just a few LED’s and already off a fused link.
    helix66 likes this.
  17. Dec 24, 2018 at 1:44 PM
    helix66
    DPRC
    2017 DclB TRDor MgM
    Can you post back if it works?
    I was thinking of tapping into the wire at the DRL's....when and if I ever get to this.
  18. Dec 24, 2018 at 1:49 PM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    I tapped my raptor lights into the fuse for the EFI circuit. This was good with me as I wanted my lights on anytime the truck was running. Only issue I noticed was that after x amount of hours after the truck turns off, the fuel circuit performs a self pressure test which turns the lights on during that time lol. So I had people coming to me at work saying hey your lights are on. Lol doesn’t hurt anything.
  19. Dec 24, 2018 at 2:43 PM
    OnHartung'sRoad
    Here’s the map light switched tap I posted:
    https://www.tacomaworld.com/threads/overhead-cluster-12v-ignition-switched-power-pin-outs.512640/
    Lots of cameras out there- I have this for it can GPS tag my location and MPH on the video too (I know not everyone wants that, but I did):
    WHLZD 2K Super HD Car Dash Cam... https://www.amazon.com/dp/B074MNK9R1?ref=yo_pop_ma_swf
    helix66[QUOTED] likes this.
  20. Dec 24, 2018 at 5:14 PM
    Rewilliams
    Rewilliams Well-Known Member
    Robert
    2017 Tacoma
    I know this sounds funny but used a add a fuse on my vleds switchback. I tapped into my a/c fuse and when I turn my off the a/c the white leds turn off but if you leave them on low they work just fine.
