Drl and tail lamps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lwwilson52, Mar 3, 2020.
  1. Mar 3, 2020 at 7:26 AM
    lwwilson52
    lwwilson52 [OP] New Member
    Larry
    2019 Toyota Tacoma TRD Off Road XSP
    None
    Just wondering. Is there any way to have tail lights on with drl 2019 tacoma
  2. Mar 3, 2020 at 7:26 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Turn on the headlights
  3. Mar 3, 2020 at 7:28 AM
    GreyBaldTaco
    GreyBaldTaco Well-Known Member
    2019 F150 5.0
    That's not how drl's work
    Lt. Dangle likes this.
  4. Mar 3, 2020 at 7:33 AM
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    That's not how any of this works.
  5. Mar 3, 2020 at 7:35 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Parking lights on is a better option.
    tcjacado and Clearwater Bill like this.
  6. Mar 3, 2020 at 7:39 AM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
  7. Mar 3, 2020 at 8:40 AM
    MESO
    State of Jefferson
    I am passionate about lighting and safety, so here is my .02. Take it for what it's worth.
    DRL(DAYtime running light) Are Typically forward facing, BRIGHT emitting lights(no cutoff, no specific location) in order for YOU to bee seen and recognized on the street(on coming). Yes, you can run headlights but typically they are aimed/cutoff and are not as visible in all directions as a DEDICATED and properly made DRL.
    As for TAIL LIGHTS being on DRL.. here's why I advise against it. In the day time, you want the brake to be a nice and bright ON factor when they are applied. When you have them half lit(ghetto DRL) when brake is applied, the brightness is barely noticeable and not as DISTINCT enough in the day time.(at night..they are fine. running and brake brightness differences are MUCH more noticeable).
    Keep the tails how they are wired from the factory IMO.
    Dtax, ShawZ, AMC_Unlimited and 7 others like this.
  8. Mar 3, 2020 at 10:34 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Here's where I see some people getting confused, in California since 2016, it is illegal to drive without your headlights on. Some folks think they can drive in blinding rain with their DRL's on, but not knowing that their taillights are off. What ends up happening is "Bam!" someone gets rear ended because they didn't have their tail lights on. So, word of caution, DRL's don't cut it in the rain. There was some statistic back before we had DRL's that Canadians had 50% less accidents because they drive around all day with their headlights on (including taillights). :notsure: By the way, Mr. passionate, your LED side markers take away the 3-1/2" sq. amber reflector SURFACE AREA on the front of the vehicle which is required to show direction of travel. :evil::D
  9. Mar 3, 2020 at 10:48 AM
    MESO
    State of Jefferson
    Yes, DRLs are so bright now a days..drivers may think their headlights are on in lower light conditions/dusk/etc. And not having tail illuminated is a recipe for disaster. All of my above views are pertaining to DAY clear conditions. If raining/overcast/etc.. revert to headlight/night settings.(truck may have AUTO sensor on the dash) which will help do this automatically. But at the end of the day, it comes down to the end user doing their due diligence in adjusting the stalk setting for the proper conditions.
    As for my side maker..yeah I know it's lacks the requirement. This is one product exception. My thought process was the led strip would make up(and be actually more visible) than a passive reflector. So, technically by the rule book I am in the wrong, But Day and night time are 100X more visible.:notsure:
  10. Mar 3, 2020 at 10:54 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yeah in the daylight, u want a drastic change, something to grab a distracted drivers attention, not a subtle change from on to slightly brighter.
    MESO[QUOTED] likes this.
  11. Mar 3, 2020 at 11:00 AM
    RyanDCLB
    4/19 DCLBOR
    :thumbsup: I think for the passive reflector side marker, the point is to show direction of travel while parked, or possibly after an accident in night conditions. An LED marker may not be lit, so all that a LEO or witness can distinctively see is the RED reflector in the rear, hence, not knowing which direction the vehicle is pointed towards... :notsure: It may not be a big deal to some, but direction of travel could make a difference to first responders, or to a train conductor for example, etc. :rolleyes:
  12. Mar 3, 2020 at 11:05 AM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
    I also like having the rear lights on. I leave stalk set to "parking lights" all the time. That way I have the front DRLs and rear lights and they go on/off with the ignition, so I don't have to mess with them.
    I have Meso's stage 2 wiring in the back, with bright LEDs, so I don't have concerns about the brakes not being distinguishable. They are plenty obvious.
  13. Mar 3, 2020 at 11:07 AM
    MESO
    State of Jefferson
    Yup, I agree. When the truck is is off..that's where a passive reflector will be critical in that certian situation. Until I can mold my own reflectors..this will have to be the caveat of my LED side markers..and why I mark them for "OFF ROAD USE ONLY":D
  14. Mar 3, 2020 at 11:10 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That’s honestly why I didnt opt for those with my retrofit. I wanna be seen from the side, even if the truck is off.
    RyanDCLB[QUOTED] likes this.
  15. Mar 3, 2020 at 11:15 AM
    MESO
    State of Jefferson
    :p
    Skydvrr[QUOTED] likes this.
  16. Mar 3, 2020 at 11:17 AM
    RyanDCLB
    4/19 DCLBOR
    Sorry to bust yer balls! They work awesome regardless! :rofl: Can't wait for you to come out with a real off-road product, like a MESO flag whip with a built-in chase light. :thumbsup: :threadjacked: OFF.
  17. Mar 3, 2020 at 11:31 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    All over my fenders, you're a genius!
  18. Mar 3, 2020 at 12:22 PM
    lwwilson52
    Larry
    None
    Thanks to all. Lots of useful info that I can and will certainly be aware of.
