DRL/Head light column switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cosmicdebris, Jun 18, 2020.
  1. Jun 18, 2020 at 7:11 PM
    cosmicdebris
    cosmicdebris [OP] New Member
    Ahmet
    2019 Super White Tacoma TRD OFF ROAD
    Replacement rims and tires
    Does any else has an issue when you turn on your headlights switch on the column from off to DRL to parking lights to head lights, the center console display, audio, home navigation, buttons are so dim you can hardly see them?
  2. Jun 18, 2020 at 7:13 PM
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    Might want to navigate to the display options and enable day time mode, it should keep the display (radio/headunit screen) fully lit regardless of light setting.
    If you're referring to the back lighting on switches and dials, also try turning your odometer dial to raise the brightness.
