DRL on with headlights
Discussion in 'Lighting' started by R09ster, Oct 16, 2013.
  1. Oct 16, 2013 at 5:50 PM
    R09ster
    R09ster [OP] Well-Known Member
    Josh
    OK
    06 SSM DCSB TRD Sport
    debadged, Bilstein 5100 all around (fronts at 1.75" sport coils), Skyjacker softride 1.5" AAL, 17X9 XD CRank, 265/70/r17 Terra Grapplers, US Offroad hidden winch mount, grillcraft grill, Sypder Auto projector headlights, blackedout LED taillights, bed extender, bedrack w/CVT Mt Shasta tent,
    Any wiring gurus out there know how to keep my DRL's on even when my headlights are on? i've got some halos and LED's hooked up to my DRL. i know i could have tied them into the parking lights or something, but the DRL actually flows into the LED's like this
    so i'd like for them to all stay on all the time. (that and i heard in some states, it's technically illegal to run around with your parking lights on, i.e. tail lights on without headlights...kinda weird)
    i feel like there should be a relay i can cut a wire to, but i can't find it. i think the <05's had a regular relay under the hood, but the 05+ don't
    Thanks in advance
  2. Oct 21, 2013 at 11:25 PM
    jaikster1986
    jaikster1986 New Member
    07 v6 trd
    where can i find those lights? i want them on my taco
  3. Oct 22, 2013 at 12:31 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    spyder.......... ebay
    be warned......... typically they are dimmer than stock unless u use HIDs, and then the pattern isnt usually clean and u may have a bad cutoff.
    Before putting them on a truck, I highly suggest lining the seams with GE silicone II (clear). They have a tendency to leak.
    OP, sorry I am not 100% sure how to wire them...... since I dont have DTRL.
    hopefully someone else can chime in.
    I usually suggest ppl tie the halos into the parking lights on the corner, but it sounds like u dont want that.
  4. Oct 22, 2013 at 9:26 AM
    R09ster
    Josh
    OK
    yeah, i might end up doing that anyway.... or making up my own separate switch (more work, but more like what i want)
    siliconing the headlights area good idea. that being said, i've done plenty of offroading (with water and mud) and have had no issues. (i never saw your warnings until after i had already installed them). They are slightly dimmer. but i've got some of the high end, super bright sylvania H1 bulbs and that brings it back to about stock brightness (but they are like $22 a piece...) i really like the look of them though.
  5. Oct 22, 2013 at 9:27 AM
    R09ster
    Josh
    OK
    also i made sure to buy them from Spyder, not through some other seller. it was a little more $, but i think the quality is a bit better...
