DRL stopped working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by CleanWilly, Dec 22, 2017.
  1. Dec 22, 2017 at 7:11 AM
    CleanWilly
    CleanWilly [OP] Well-Known Member
    2017 Access Cab Offroad
    just recently noticed that my DRL no longer come on when I turn to that first click. They work on the second and third clicks. No mods to lights and they’ve worked fine before. I’ve looked in settings and there’s a check box for DRL but I think that’s if you want them always on and either way it changes nothing.
    It’s not a huge deal and I’ll have them look at it on my next service but thought I might be missing something?
  2. Dec 22, 2017 at 7:15 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    With the handbrake on they won't come on.
  3. Dec 22, 2017 at 10:21 AM
    CleanWilly
    I don’t believe it was on but I’ll look at that when I get off work.
    Ruggybuggy likes this.
  4. Nov 30, 2018 at 12:09 PM
    takosupreme808
    takosupreme808 Member
    Kevin
    2017 taco trd off road
    Stock
    Dame issue.... e break is disengaged
  5. May 1, 2019 at 7:43 AM
    Captbrad88
    Captbrad88 Well-Known Member
    Brad
    2018 Tacoma trd offroad
    Any luck with this. Having the same issue
  6. May 1, 2019 at 8:03 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Have you done any electrical mods at all? I tried using the overhead dome light full-time power lead to run a dash cam, and it messed with the DRL’s. Go figure...
    shakerhood and Ruggybuggy like this.
  7. May 1, 2019 at 1:55 PM
    Captbrad88
    Brad
    Ok, so I know one day someone else will search this same thing as me. Dumb guy I am, well not so much. But looking at the fuses first glance and seen nothing. The little box has a drl relay, replaced that. Nothing fixed. Come to find out there is a drl fuse in the big box. It’s a 10amp, I must of looked over it 4 times. But that is the cause of the issue. It’s funny because I took it to Toyota because I couldn’t figure it out, they tried telling me it’s because of my Switch-Pros and I did something and the ecu needed replacing and it wouldn’t be covered under warranty. That’s what made me really look at my fuses again.
  8. May 1, 2019 at 2:10 PM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    I wouldn't go back to that dealership again. A good tech would have looked up the wiring diagram and checked what fuse powered the drl. You do have to ask yourself what caused the fuse to blown. What else is on the circuit that is causing more than 10 amps to flow?
    gsubioguy and SandyTaco4x4 like this.
  9. May 1, 2019 at 2:16 PM
    Captbrad88
    Brad
    Nothing on it. My switch pros is ran off my ingnition for the power. But I think it was just a freak accident, can’t figure out why it happened. But I agree, I’m not taking it to that dealership again. Still amazed they tried saying that my Switch-Pros would void anything.
    Ruggybuggy[QUOTED] likes this.
  10. May 16, 2019 at 11:47 AM
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Is there one fuse for driver and one for passenger side or one fuse for both? Only my driver side decided to stop working
  11. May 16, 2019 at 3:33 PM
    Captbrad88
    Brad
    The fuse is for both. Then a relay in the smaller cover to the side of the main fuse box.
  12. May 16, 2019 at 4:02 PM
    maximase86
    maximase86 Well-Known Member
    Seattle, WA
    2019 Calvary Blue TRD OR DCSB
    I'd keep an eye on that fuse. Something could be making it pop (like an intermittent short or drawing over 10 amps).
  13. May 16, 2019 at 8:07 PM
    Toynado
    SF Bay Area
    Thanks. Then it must be the LEDs themselves since it’s only the driver’s side
  14. May 16, 2019 at 8:12 PM
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    My driver’s side on my 2019 died and the whole headlight assembly was replaced. Pro Headlight was special order for the dealership and took over a week to arrive.
    Toynado[QUOTED] likes this.
  15. May 16, 2019 at 8:18 PM
    GatorAintBoutDat
    GatorAintBoutDat Well-Known Member
    19 TRD OR DCSB Cement
    My driver's side DRL stopped working about a month ago. I'm taking off the pro grill and raptor lights (not spliced into DRL) and the HID kit before I take it in to avoid any drama, and also get the recall on the radar done. Hopefully they don't try to blame it on the dash cam or the switch pro with the light bar hooked to it.
    Toynado likes this.
  16. May 16, 2019 at 8:22 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    You may want to rewire your switch pro to pull power straight from the battery. That thing can draw a lot of power and can overload the circuit your tapped into
    Chew likes this.
  17. May 16, 2019 at 11:01 PM
    Captbrad88
    Brad
    Should clear that up. The one wire ran to the ignition is just a trigger wire to tell the system to come on. The Switch-Pros has a direct thick battery wire running from the unit to the batttery for its power.
    MOC221_, Toynado and VangaSTL[QUOTED] like this.
  18. May 17, 2019 at 8:20 AM
    Toynado
    SF Bay Area
    Interesting I’m running HIDs and a switchpro as well. Can’t imagine either would have an effect of the DRL LED but yeah putting in the stock bulbs will reduce dealer drama.
  19. May 17, 2019 at 9:25 AM
    therealprotaco
    Gilbert, AZ
    I could definitely see a dealership from any brand blaming HIDs due to heat (although not a real thing) or some other nonsense. Switchpro or Raptor lights, not so much. I did have my Raptor lights installed when the dealer replaced mine. Not spliced into the DRL wire.
  20. Jun 5, 2019 at 7:07 PM
    therealprotaco
    Gilbert, AZ
    DRL on my driver’s side headlight is out again. They just replaced the whole headlight 3 months and 3k miles ago. The whole truck only has 5200 miles on it. Anyone have any thoughts as to a potential cause before it goes to the dealership again?
