DRLs Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jackgoldfon, Feb 11, 2023.
  1. Feb 11, 2023 at 3:14 PM
    jackgoldfon
    jackgoldfon [OP] New Member
    2021 white trd sport tacoma
    Anyone out there know what specific connector to buy for this problem?
    ive got a trd sport 2021 tacoma, and i bought headlights for a SR, i installed them thinking i could find a easy connector. anyone know a specific connector i can buy to get the drls/blinkers to work?
  2. Feb 11, 2023 at 3:28 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
  3. Feb 11, 2023 at 4:01 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    why did you buy SR headlights?
    It is possible to build a harness from TRD DRL + turn to SR but there isn’t any reason to use SR headlights over TRD. Toss the SR’s and you’re all set.
  4. Feb 11, 2023 at 4:27 PM
    daveeasa
    David
    PNW
    And if anyone is curious about specifics, it's nearly the same as the SR to TRD/OEM LED harness:
    https://www.tacomaworld.com/threads/sr-sr5-oem-led-headlight-harness-v2.736263/
    if you ignore the pass through low and high beams (hence the same as the SR to TRD harness which is something I don't make or sell because it's not a worthwhile upgrade).
    The difference being that the task here is to multiplex turn and drl rather than demultiplex the combination of turn + drl. So, timer, relay, inputs on 87 and 87a and output on 30. Timer would fire the relay off the turn or lack of turn, pick whatever you want to do there, same basic idea.
    Roughly the equivalent cost to buying some nice condition halogen TRD takeoffs from someone who has upgraded to OEM LED.
    ktbell444 and Martian__ like this.
  5. Feb 11, 2023 at 6:22 PM
    daveeasa
    David
    PNW
    Explain how diodes will flash turns when DRL is on please.
  6. Feb 11, 2023 at 6:33 PM
    daveeasa
    David
    PNW
    Ah, dumping DRL to tail so low brightness for DRL instead of high.
    I’ll give you partial credit for a halfway answer :)
  7. Feb 11, 2023 at 8:10 PM
    daveeasa
    David
    PNW
    Minus 10 points for wires through the firewall :)
  8. Feb 11, 2023 at 8:44 PM
    daveeasa
    David
    PNW
    Ah killing DRL signal when turn is active?does that cover hazards?
    not to sound repetitive but this isn’t simpler than timer and relay, it’s more complicated and three different harnesses. For the non electrically inclined it’s a lot to deal with.
    people generally want to connect a harness to the truck on one end and another to the headlight. They can generally handle zip ties to secure a relay if needed. But most don’t want to mess around with the in cab signals from what we’ve found. Even if behavior isn’t quite as ideal.
    The easiest straightforward solution is a timer and relay. Gets it done. No add a fuse or messing around in the cab.
    A solid state relay with integrated timer coil would be ideal. It’s tempting to try to design something like that.
  9. Feb 11, 2023 at 8:55 PM
    daveeasa
    David
    PNW
    I’ll give you 3/4 credit for a hacky solution :)
    less good for adding grille lights or anything assuming DRL is DRL rather than DRL when not turning.
  10. Feb 11, 2023 at 8:58 PM
    daveeasa
    David
    PNW
    We can agree to disagree that 3 is more complicated than 2. I’m confident in my math skills :)
  11. Feb 11, 2023 at 8:59 PM
    daveeasa
    David
    PNW
    You’ve changed the behavior of the DRL wire at the OEM connector. Hence my use of hack.
  12. Feb 11, 2023 at 9:00 PM
    caribe makaira
    Caribbean, Puerto Rico
    YOU know what, OP isn't even in the conversation.
    tcjacado likes this.
  13. Feb 11, 2023 at 9:06 PM
    tcjacado
    tcjacado Well-Known Member
    And nobody else.... all comments have been deleted, except @daveeasa
    :rofl:
    mic_sierra and erok81 like this.
  14. Feb 11, 2023 at 9:08 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Did you delete a bunch of posts or did I do something to make most of your posts not show up?
    ktbell444 and tcjacado like this.
  15. Feb 11, 2023 at 9:18 PM
    caribe makaira
    I deleted them.
    erok81[QUOTED] and tcjacado like this.
  16. Feb 11, 2023 at 9:35 PM
    daveeasa
    David
    PNW
    I do owe caribe some beers I think. That much is clear :)
    easiest path for OP is use TRD headlights. The halogens are effectively free in terms of market value.
    ktbell444 and erok81 like this.
