Droning Sound At Highway Speeds
Discussion in 'Technical Chat' started by Yeki, Feb 10, 2013.
  1. Feb 10, 2013 at 5:51 PM
    Yeki
    Yeki [OP] Member
    Ike
    SE PA
    2010 4X4 Regular Cab
    Hello All!
    I picked up my first Tacoma, a 2010 regular cab 4x4, in late October. It's a 4cyl with manual trans. Over the past few weeks I have been noticing a gradually increasing droning sound at speeds roughly between 60 to 68 MPH. The sound can be mild at times or fairly deep with a very slight vibration. It is speed related and only occurs when I touch the gas and while in gear. There has to be a load. If I rev the engine in neutral at these speeds, no droning. Of course the dealership couldn't hear anything. Any ideas???
    Thanks in advance!
  2. Feb 10, 2013 at 5:53 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    flip your driveshaft around
  3. Feb 11, 2013 at 2:37 AM
    Yeki
    Yeki [OP] Member
    Ike
    SE PA
    Thank you 650H1! Could you explain how/why the driveshaft would cause this issue? Is it possibly a balance problem with the shaft? Why would flipping it help? Thanks for your time!
  4. Feb 11, 2013 at 2:55 AM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    drive shafts have weights on them and go on a certain way. if reversed the weight will be off creating a vibration and hum/drone noise.
    does the truck have a lift?
    i am trying to think why the drive shaft would have been taken off.
  5. Feb 11, 2013 at 4:15 AM
    Yeki
    Yeki [OP] Member
    Ike
    SE PA
    Thanks for the input blake5995! The truck doesn't have a lift (yet!). Would the weight be on a particular end of the shaft or would it just depend on its balance needs? Also, being pre-owned, there's no telling what may have been done to it previously.
  6. Feb 12, 2013 at 3:57 PM
    Yeki
    Yeki [OP] Member
    Ike
    SE PA
    I was under my truck tonight having a look. The drive shaft has what looks like a CV boot towards the front. Does it matter which end this boot is on? I was considering flipping the shaft around this weekend.
  7. Feb 12, 2013 at 4:03 PM
    blake5995
    Blake
    Truckee, CA
    can you throw a pic up on here of the driveshaft or just text me one and i can look at it.
    if i am correct the boot looking end should be on the differential side.
  8. Feb 12, 2013 at 4:22 PM
    Yeki
    Yeki [OP] Member
    Ike
    SE PA
    OK, I'll get a pic of it in the morning. Thanks for your time.
  9. Feb 12, 2013 at 6:42 PM
    blake5995
    Blake
    Truckee, CA
    yea no prob always trying to help others out
  10. Feb 13, 2013 at 4:16 AM
    650H1
    NH
    From the factory, the boot end should be at the transfer case. I had the same issue with my reg can, flipped d shaft around and all was good...
  11. Feb 14, 2013 at 2:19 PM
    Yeki
    Yeki [OP] Member
    Ike
    SE PA
    Thanks guys. I was going to take pics but stumbled across the same thing 650H1 is saying. I've decided to give the dealership another shot since I still have a little warranty time left. I'll insist on going out on the road with the tech to point it out. If all else fails, I'll flip it.
    Thanks Again!
  12. Feb 14, 2013 at 4:38 PM
    650H1
    NH
    Have the tech flip it... Toyota tech at the dealership flipped mine...
