Drop bracket back to stock.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 798welder, Oct 21, 2020.
  1. Oct 21, 2020 at 8:02 AM
    798welder
    798welder [OP] New Member
    Oliver
    2015 dbc TRD off-road
    I recently bought a 2015 dbc TRD off-road with a 6 inch lift. I want to take the lift off. I’m aware and capable of doing the welding a fab work required. I was wondering if anyone had a thread showing where to start in the process. Thanks in advance.
    glad to be back in a Tacoma
  2. Oct 21, 2020 at 8:06 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Do you have the piece which was cut out of the cross-member? For the front diff.
    I did that to mine many years ago.
  3. Oct 21, 2020 at 8:24 AM
    798welder
    Oliver
    No I do not I bought the truck this way
  4. Oct 21, 2020 at 8:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well then, being a welder, I am sure that you can fabricate up that section which is missing, with some plate steel.
    798welder[OP] likes this.
  5. Oct 21, 2020 at 8:53 AM
    798welder
    Oliver
    Yea I just wanted to see if anyone had thread to show how they did it. Maybe a better idea than I have. Thank for the help.
