Drop in fuel mileage.
Discussion in 'Performance and Tuning' started by luk8272, Feb 6, 2009.
  1. Feb 6, 2009 at 7:09 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    All the numbers here have been corrected for tires. I have a 3" lift with 33" tires. 4dr V6 4x4. As per Janster the lift and tires have been on for a while and this is not related to that.
    On my drive to work today I used 6.5 gals and went 101 miles, that comes to 15.5 average mpg. Using my scanguage, At 70mph-13.3mpg-1976rpm-82.6hp. This is very unusual for my truck normally seeing 16+mpg at 70. Now at slower speeds it was normal 48mph-23mpg-1376rpm-33hp. Could some of yall chime in and let me know what yall are seeing. Thanks.
    My air filter is clean, tires are at proper psi. If it were the fuel filter wouldn't I see the low mpg at all speeds?
  2. Feb 6, 2009 at 7:13 AM
    Ghost96Romeo
    Ghost96Romeo What is the Search Tab for????
    Texas
    06 TRD Off-Road D-Cab
    3" Pro-Comp Suspension Lift AAL Rear w/TSB, All-Pro Plate Bumper, Lightforce 240 Blitz lights, Lund Genesis Roll-top Bed cover, K&N Filters, Spidertrax Wheel spacers, Built-by-Me Rock Sliders, Jeep Tow-Hook, Black Leather seats, 48"Hi-Lift Jack mounted in the bed, Blacked out TRD Rims, BHLM, FLM..... and Awesomeness
    Dry air?
  3. Feb 6, 2009 at 7:20 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I traveled in both directions and achieved the same readings, barely any wind. Temp today was 54* maybe a little colder as I left at 2:30am.
  4. Feb 6, 2009 at 7:27 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    how cold was it?
  5. Feb 6, 2009 at 7:30 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I tanked up at a place that I use when I pass by it. I normaly avoid stations that use ethonal this one does but I still have never gotten these low numbers. When I avoid the ethonal I get 19+ mpg with the ethonal I get 17mpg on average.
  6. Feb 6, 2009 at 9:11 AM
    Ghost96Romeo
    Texas
    For some reason vehicles get worse gas mileage in colder weather with dry air. Something about the gas mixture not burning completley I think.
    Chris4x4 has some knowledge on the matter I believe.
  7. Feb 6, 2009 at 9:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    Could just be a flook. Avoid the ethanol at all costs. It is not an efficient fuel source.
  8. Feb 6, 2009 at 9:15 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You have 3" lift and 33" tires...gas mileage is gonna drop. That should be a no-brainer.
  9. Feb 6, 2009 at 9:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Colder air = denser air, thus the ECU adds fuel to maintain the propper air/fuel ratio. Cold moist air (high humidity) has even more oxygen (Water is H2O), so less mpg can be expected from it.
  10. Feb 6, 2009 at 9:33 AM
    Ghost96Romeo
    Texas
    Bingo Baby!!!! Here to save my ass!:D:D:D Thanks Chris
  11. Feb 6, 2009 at 9:56 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    yeah but the lift is far from new. Been on the truck almost a year this is something I noticed today. As the numbers I have been posting are with the lift and tires.
    Thanks Chris and Ghost. I will be keeping an eye on it.
  12. Feb 6, 2009 at 10:03 AM
    Janster
    Jandy
    Lancaster, PA
    You should've mentioned that in your first post.
  13. Feb 6, 2009 at 10:30 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I fixed to for you!:D
  14. Feb 7, 2009 at 1:25 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    maybe an older batch of gas. I know my first tank of gas on my truck myst have been sitting in there for a bit as the mileage was 2 3- lower than normal. I attributed it to bad gas
  15. Mar 2, 2009 at 6:28 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Well I am back from work been in for about a week. Use all the gas in the tank until the light came on twice. I know that is bad practice but I have 2 new fuel filters for incase. I didn't need them my fuel is back to normal as of this new tank. The numbers are right back to where they used to be. After I used all the bad gas the first fill up was better but not as good as norm. But this here fill up was down right exciting even my buddy who was riding with me was like damn look 26.5 mpg at 42mph. Previously he saw 42mph and 13mpg.
  16. Mar 2, 2009 at 6:35 PM
    2009tacomav6
    phx AZ
    2012 4x4
    good to hear
  17. Mar 3, 2009 at 7:04 AM
    TRYMY4.0
    TRYMY4.0 SuperMod of IA.com
    Exactly. Also, colder air is more dense meaning your truck is having a harder time pushing through it all which = in more gas consumption.
    -Ant.
