Dropped a Cylinder, after start, goes away. Good one!
Discussion in '1st Gen. Tacomas (1995-2004)' started by krlang, Nov 15, 2009.
  1. Nov 15, 2009 at 5:06 AM
    krlang
    krlang [OP] NewEnglander
    Commonwealth of Massachusetts
    03 2WD 2.4L Tacoma Reg Cab
    Chrome Bumpers F&R, Grille & Corner Lights, Wheel Skins, Red/Clear LED taillights, Remote start, PDL, Cruise, K&N, All Kenwood, DNX-5120 6.1" NAV/TRAFFIC/DTV/DVD/XM/BLUETOOTH/USB/IPOD/SUB/rear cam, Tint, Air Band radio, Class 3 Hitch with 4/7 pin harness, Transmission Cooler, Red Top Battery, "Deck Plate" mod.
    Heres a good one,
    My Tacoma has 123k on it and it has aquired a new problem.
    I was away and my GF was driving, it dropped a cylinder and was shaking badly. From 1500 miles away I decided I would do a little troubleshooting when I got home.
    I got home, bought new plugs, drove it for 5 miles and shut it off. When I restarted it while warm, the problem happend. I was able to peddle it home and enroute it went away. I swapped out the plugs, which looked good, then I rotated the coils, and continued. A couple of days later it happened again, after a 50 mile ride and a stop. Once again I was able to peddle it back to normal.
    During the event, it flashes the check engine light, after you rev it a bit and it sees a problem. It doesnt log a code everytime. It is a bit confusing.
    In the middle of all this I blew out the muffler, so the skip and the loud exhaust in a hospital parking lot was not fun. I had a lot of dirty looks.
    I dropped it off to a friend, told him the scenario, this time it logged a code on the way there. :) He scanned it and found it was the #4 cylinder again, so we know it was not a plug or coil issue. He pulled all of the injectors, cleaned the screens, replaced an o-ring on the #4 that was split, and put it back together with the nozzles rotated to see if the problem follows. He installed a new muffler and sent me on my way.
    The ride home was interesting, got an engine light after 10 minutes, checked and cleared it with my new scangauge, it was the rear O2 sensor. It was just installed into a new pipe, so I figured it was disturbed and not happy. No skipping problem though.
    Last night, I got it again, same scenario, it came back after a warm restart. Just a flashing light, no logged fault. Then it went back to normal. I need to make it happen and log a code to see if it moved, if it did, I have a bad injector. If not, then what could it be?
    More to come!
  2. Nov 15, 2009 at 5:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Could be a fuel filter, or vacuum line.......Sounds like a bad injector, but without the code, Im just guessing.
  3. Nov 15, 2009 at 5:40 AM
    krlang
    No FF, just a screen in the tank.
    I going out in a little bit to see if I can get it to log a fault.
  4. Nov 15, 2009 at 5:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Your fuel filter is under the air intake manifold.
  5. Nov 15, 2009 at 8:33 AM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    My taco did this. Cylinder 2 shit the bed so I replaced plugs. That solved it for 2 days, than it would work fine cold but then run on 3 again once warmed up.
    I replaced the ignition wires. Solved the problem. Check those and see if the insulation is ok. But I would recommend that.
  6. Nov 15, 2009 at 8:46 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    What he said. I think the wires should be changed.
  7. Nov 15, 2009 at 8:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    For some reason, I was thinking the wires were already swapped....Do what these guys suggest. :)
  8. Nov 15, 2009 at 1:38 PM
    krlang
    Wow,
    I looked for the filter in the wrong place I guess. Now I see it, with a Banjo fitting on the front end. Suppose I better change that too. I asked at 90k as to where it was, and the two people I asked said there wasnt one.
    There are no Ignition Wires though, Its Coil on Plug, and I rotated all of the coils in the first attempt to t-shoot. The FF has probably been bypassing for years. :(
    Thanks
  9. Nov 15, 2009 at 1:39 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Ah, a Cali emissions vehicle.
  10. Nov 15, 2009 at 2:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah. Seems alot of Toyota "Techs" think there is no FF on the 2.7 or 2.4.
    Yeppo.
  11. Nov 15, 2009 at 2:36 PM
    krlang
    Cali/Mass Emissions, unfortunately.
