Dropped Crew cab
Discussion in 'Street Trucks' started by 07_prerunner, Jun 19, 2020.
  1. Feb 17, 2021 at 12:00 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Fabquest . Here list of parts . Also shipping price to Hawaii. Coilovers got is for 2in drop . Rear adjustable shocks is xrunner spec .
  2. Feb 17, 2021 at 12:07 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Dropping prerunner anymore than sos height going be more headackes . Would need to notch rear frame , to got correct geometry in front custom chopped spindel and?? Ride quality?
    If you want sos height and going run coilovers just need sos rear drop . Also recomment lower bump stops in front which sos sells
    tinker_troy likes this.
  3. Feb 17, 2021 at 12:18 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
  4. Mar 8, 2023 at 8:55 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Ended up my ride height was actually 18.5 . So coilovers maxed out causing bushing to get damaged .Called viking and replaced eyelet with 1" extended ones and now within safe range . They also had 1 1/4 wide -5/8 ID spherical bearing with 14mm inserts so could use use the 14mm toyota bolts . The C215 coilovers with 17 3/4 to 19 3/4 ride height is the one I should have ordered. :facepalm::facepalm::facepalm:Should have researched better .
    Will take updated pic.
    VPTUNING likes this.
