Dropped / lost bolt on radio install?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spine Shank, Feb 20, 2012.
  1. Feb 20, 2012 at 2:00 PM
    Spine Shank
    Spine Shank [OP] Member
    Still Stock
    Need some help. I am at my witts end.
    Dropped bolt when mounting new radio that went down... where I don't know. I just heard it tumble. Thought it would fall through but it didn't.
    Now every time I drive, I hear that bolt rolling back and forth somewhere. It's been like that for three weeks now!
    It's rollig on something plastic. It is not visible from behind the panel.
    I have partially dismanteled my dash / panel with no luck on finding bolt. I cannot find a logical place where it would be. I don't see how it could've fallen into vent system because there is no opening below where the blot dropped.
    Any suggestions?
    BTW - I've used magnets, air hoses with no luck.
    Spine Shank
  2. Feb 20, 2012 at 2:01 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Trade it in
  3. Feb 20, 2012 at 2:02 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road Vendor
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Let me know if you find it, I'm sure mine is in the same hiding place
  4. Feb 20, 2012 at 2:04 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Just consider yourself lucky. Usually you end up with extra bolts left over.
  5. Feb 20, 2012 at 2:21 PM
    jang
    jang Member
    cincinnasti
    06 tacoma
    tie a magnet to a string and drop it in there with it
  6. Feb 20, 2012 at 2:28 PM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    You'll have to pull the center console. That's where I found mine.
  7. Feb 20, 2012 at 2:30 PM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    As I recall I may have had to pull my cup holder. You are not alone in this my brother..... Lol
  8. Feb 20, 2012 at 2:31 PM
    Aw9d
    Aw9d That one guy
    Az
    Here is my trick for issues like this.
    Find an old dead hard drive from a PC (Laptop is fine as well) Open it up, in there you'll find 2 magnets, both are Rare Earth Magnets. Take them out, tie a string to one of them it and keep feeding it down where you dropped the screw. Sooner or later you'll snag it with the magnet.. I'm sure you'll get caught on other metal about 500000000 times before you get the screw, but you will get it sooner or later..
    Don't use normal magnets, not powerful enough..
    Good luck.
  9. Feb 20, 2012 at 2:37 PM
    MXscott14
    MXscott14 Bartle Do Member
    Keith Stone
    In Front Of You
    2006 2nd generation antique
    Black Headlight, Foglight always on,
    Auto tranny where the stick comes up, unthread the shifter and pop off the plastic trimming around it should be sitting right there
  10. Feb 20, 2012 at 2:50 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    How are the magnets attached to the metal plates? Can they come off?
  11. Feb 20, 2012 at 2:58 PM
    Spine Shank
    Still Stock
    Thx guys for the advice. Still no luck.
    I've tried a super strong magnet, tied to a string, zip tied to a snake, fingers so sore now from sticking them in every nook and cranny. It's so frustrating because it's not that big of a space to be hiding. I can hear it as if it's right there. NOTHING!!!
    MX - good idea, but already exhausted it. I have the center console off, the lower steering panel, and the entire radio console. There's not too much further to break it down. One would think he should be able to see it this far exposed, but nope, nada.
    Keep the ideas coming though. Thanks
  12. Feb 20, 2012 at 3:02 PM
    Socalduckslayer
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Try driving around with the dash taken apart and look for it since its moving. Next step is to have someone else drive or shake truck while you get in there with a stethoscope and see if you can pinpoint it. If either of these work let me know, then I'll do it too
  13. Feb 20, 2012 at 3:04 PM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I came up one short during re-install the other day as well. Lousy f&(*! design flaw! Fortunately, mine hasn't dislodged itself from wherever it's jammed just yet. I figure the first time I hit a good bump or leave the pavement, I'll be reminded of it from then on. ...must remind self to buy a magnetic 10mm nut driver just for this... Lost one of the stupid yellow plastic clips too so I'm sure I'll hear them both eventually.
  14. Feb 20, 2012 at 3:11 PM
    Aw9d
    Aw9d That one guy
    Az
    Yeah they are glued on, you can use a flat head screw driver and razor to cut them off but be careful not to bend them too much.. They will snap.
  15. Feb 20, 2012 at 3:46 PM
    Spine Shank
    Still Stock
    Got it! MX was in the right direction.
    As I resigned myself to defeat, I thought gravity has to work here. Sure enough.... it was under that little yellow box at the very bottom of the console.
    Thanks MX and everyone else. Even the funny ones!
    Spiney
