Dropped off my truck to be re-geared
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Aug 26, 2012.
  1. Aug 26, 2012 at 1:15 PM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    So I finally got the chance to drop off my truck and have it re-geared. So looking forward to the improved acceleration and power.
    I had bought used, a set of 4.10s for the front and back.
    I know that the rear should be a straight swap, however I've heard in some places here that I need a new carrier or something for the front.
    Can somebody explain to me what this is and if it's necessary?
    The guy doing the work has the front gears and they are only the ring and pinion. I don't want to have to find out I'm missing something while he has my truck in pieces.
    Also he quoted me for 2 days of labor. Does that sound reasonable?
  2. Aug 26, 2012 at 2:24 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    2 days of labor? That does not sound right to me. Especially if the rear is a simple process.
  3. Aug 26, 2012 at 4:59 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Curious to see what kind of gas mileage gains you get :popcorn:
  4. Aug 26, 2012 at 5:11 PM
    jandrews
    '09 FourDubDee TRD OR
    Two days of labor is almost certainly correct if it's one person working alone.
    There is indeed a carrier break on 2gen Tacos...one carrier for 3.73 and down, one carrier for any ratio higher. You will need a new carrier or the appropriate ARB locker.
    Sorry man. I don't think he's going to be able to do your front end. You might have 4x4 out of commission for a while whilst you get your hands on a 4.10 front carrier.
  5. Aug 26, 2012 at 5:17 PM
    Turd Herding Jim
    Turd Herding Jim What's wrong bro, DERPes flaring up?
    Big Jim
    Everett, WA
    07 SR5 4x4
    3" Icon Stage 3 lift, All Pro Off Road APEX front bumper, Amor Tech Off Road high clearance rear bumer, Armor Tech Off Road rock sliders. URD Short Shifter, HID Headlights, Level 8 Guardian Wheels, 285/75-16 Falken Rock Mountain ATS tires, 4.56's with front and rear ARB air lockers, BesTop Soft Cover
    I got front clamshell with 4.10's :D
  6. Aug 26, 2012 at 5:25 PM
    jandrews
    Easy sale right here...PM him yet? :D
  7. Aug 26, 2012 at 5:27 PM
    Turd Herding Jim
    Big Jim
    Everett, WA
    07 SR5 4x4
    well it's supposed to go back to ECGS...but if the price is right he can have it(greedily rubs hands)
  8. Aug 26, 2012 at 7:22 PM
    huntman92
    huntman92 Hunter
    hunter
    chattanooga tn
    06 tacoma
    6 inch fabtech. budbuilt bar. trd intake and exaust. 2 jl 10's. train horn and more
    2 days of labor sounds a little long.
  9. Aug 26, 2012 at 7:26 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Have you re-geared a truck before or been around a truck being re-geared? To PROPERLY set everything up, I agree that 2 days is a good amount of time. You also do not want to promise a customer a shorter amount of time, what happens if something goes wrong or whatever?
  10. Aug 26, 2012 at 7:30 PM
    jandrews
    I'm not sure you quite understand what's involved in a proper gear setup...
    Some light reading:
    http://www.gearinstalls.com/
  11. Aug 26, 2012 at 7:40 PM
    Turd Herding Jim
    Big Jim
    Everett, WA
    07 SR5 4x4
    Guys..."2 days" in labor really is only 12-16 hours of actual wrench time. So a quote like that is absolutely correct
    Haha, light reading...
  12. Aug 27, 2012 at 10:34 AM
    huntman92
    huntman92 Hunter
    hunter
    chattanooga tn
    06 tacoma
    yes i have actually.. regeard a 91 toyota crawler and a jeep..
  13. Aug 27, 2012 at 10:43 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    were those crawlers solid axels in the front by chance? if so its easier
  14. Aug 27, 2012 at 11:07 AM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
  15. Aug 27, 2012 at 3:25 PM
    MikeyLikesIt
    MikeyLikesIt Supercharged Mileage Master
    That sig is hilarious!!
  16. Sep 1, 2012 at 6:47 PM
    BarefootBandit
    Looks like I need a 3rd member for the front
  17. Sep 1, 2012 at 8:34 PM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    does your shop typically work on customers cars in the parking lot? :confused:
  18. Sep 1, 2012 at 8:58 PM
    badger
    badger Well-Known Member
    07 SR5
    My regear took one very long day, but that was because we already had a second front differential prebuilt. The front was just a swap and the rear required a full set-up.
    It's actually not hard to do a regear in less than 2 days, if you are not particular about how it goes back together. I wouldn't want anyone even attempting to rush gear work on my truck.
  19. Sep 3, 2012 at 7:58 AM
    BarefootBandit
    Yes and even worse, he couldn't finish the job so now the rear end is open exposed to the rain and shit.
  20. Sep 3, 2012 at 8:08 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    :popcorn: hopefully he does it right the first time and you don't have to go back to him
