Drove in 4H in rain - slow turn
Discussion in '3rd Gen. Tacomas (2016-2023)' started by parkw86, Feb 14, 2019.
  1. Feb 15, 2019 at 6:43 AM
    #81
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    He just Trying to decide between 265’s and 285’s
    Mushu likes this.
  2. Feb 15, 2019 at 6:47 AM
    #82
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I'd recommend a thorough cleaning of the battery posts
  3. Feb 15, 2019 at 7:00 AM
    #83
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    My work buddies passed around an old front wheel drive only Toyota pickup commuter for several years, it had over 300k miles on it and was always in 4H or it wouldnt go anywhere.
  4. Feb 15, 2019 at 7:15 AM
    #84
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    wrong
    Jaque8 likes this.
  5. Feb 15, 2019 at 7:18 AM
    #85
    Alnmike
    Alnmike Well-Known Member
    PNW
    '21 4R
    That's exactly why. You want to mesh the gears, not slam them into each other going different speeds. It's the same difference between standing behind someone pushing them on a swing, vs jumping into the path of the swing on the way back. Might be able to get away without a trip to the dealer/hospital, might not.
    For the highway 4wd, I think some people are confusing 4wd with diff locks. Please do not engage your diff locks and 4wd anytime you have good traction then decide to start making turns... Or do, then tag me in your new TW thread complaining that the dealer won't honor their warranty.
  6. Feb 15, 2019 at 7:18 AM
    #86
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Wrong. It was mostly right.
    xxTacocaTxx likes this.
  7. Feb 15, 2019 at 7:31 AM
    #87
    commbubba19
    '23 TRD PRO
    i'm so fed up with morons.
    seriously use common fucking sense people.
    if it's dry, don't use 4wd. if you accidentally leave it on, you'll know it when you turn. the harder and faster you turn in the dry with 4wd the more likely you will cause damage. if you're driving straight, all wheels are driving at the same speed therefore there is no damage occurring to the TC.
    you can use 4wd in any condition other than dry roads without issue or worry about damage to the transfer case.
    you can engage 4wd up to 55ish (some say 62). Once in 4wd, you can drive up to any speed you wish without damage.
    if you still have questions, watch some youtube videos on how a transfer case and differential work.
  8. Feb 15, 2019 at 7:35 AM
    #88
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Toyota says 62.
  9. Feb 15, 2019 at 7:36 AM
    #89
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    The reason you don’t want to drive it 4wd with good traction is the front and rear driveshafts are locked together at the transfer case. If the driveshafts are both turning the same speed everything is ok. If they are not turning the same speed like when turning a corner something has to give. If your on a loose surface this will be a tire slipping. If your on a high traction surface what gives could be anything from the transfer case to the tires slipping, it just depends on what the weakest point is.
    AWD systems don’t have a transfer case they have a center differential so the drive shafts are not lock together.
  10. Feb 15, 2019 at 7:38 AM
    #90
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Don't worry about it. My wife drove from Idaho to CA in 4wheel drive and complained about how crappy her gas mileage was to me in her truck. 125K miles later, still no problems.
  11. Feb 15, 2019 at 7:40 AM
    #91
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Are they full time 4 wheel drive?
  12. Feb 15, 2019 at 7:42 AM
    #92
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    Thank you for the explanation! Makes perfect sense.
    Running Board Man likes this.
  13. Feb 15, 2019 at 7:44 AM
    #93
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    What does this mean ? My truck radius is the same right or left .
  14. Feb 15, 2019 at 7:45 AM
    #94
    Mully
    CA
    Don't care, it's her truck.
  15. Feb 15, 2019 at 7:46 AM
    #95
    Alnmike
    PNW
    '21 4R
    Thank God transfer case gears usually aren't made of copper or aluminum...
    https://en.m.wikipedia.org/wiki/Fatigue_limit
    Read up on that, then keep a straight face saying that any highway use will eventually destroy your truck no matter how little you turn.
    TLDR: Highway use is fine. Tight turns is not. No highway that I know has tight turns on it.
  16. Feb 15, 2019 at 8:28 AM
    #96
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    A left turn at an intersection is generally a longer, shallower turn when compared to a right turn from an intersection.
  17. Feb 15, 2019 at 8:41 AM
    #97
    OnHartung'sRoad
    Yup, it was a beater and they passed it around for free to whoever needed a commute vehicle at the time.
    It lasted for years that way! :rofl:
  18. Feb 15, 2019 at 8:43 AM
    #98
    Bleep100
    17 Sport
    Got it . Thanks .
  19. Feb 15, 2019 at 8:45 AM
    #99
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    I think people are confusing using front and rear differential lockers and what using 4x4 does...
    https://youtu.be/4-Wy5ENm_lM
    Here a good quick video on the subject.
  20. Feb 15, 2019 at 8:50 AM
    #100
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    Pssshhhh... like they know anything. :rolleyes:
