drove through a torrential rain and now an odd sound appears
Discussion in '1st Gen. Tacomas (1995-2004)' started by donlogan, Jun 23, 2015.
  1. Jun 23, 2015 at 5:30 PM
    donlogan
    donlogan [OP] Well-Known Member
    95 DLX Taco.
    My commute home from work was through very heavy rainfall.
    As I near home my Taco suddenly starts to make a high pitch whirrring sound when I accelerate. I also smelled some fuel/exhaust in the cab to accompany the high pitch whirring.
    My initial thought was that water got into the muffler. Any ideas of what it could be?
  2. Jun 23, 2015 at 5:48 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    that wouldn't cause you're symptoms. sounds like water on the belts/pulleys. as for the smell no clue.
    take a recording of the sound if you can (have someone drive or have someone record)
  3. Jun 26, 2015 at 6:35 PM
    donlogan
    The problem was my O2 sensor had fallen out and hanging there.
  4. Jun 26, 2015 at 6:43 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That would do it.
  5. Jun 26, 2015 at 6:53 PM
    donlogan
    I'm assuming it's an easy fix. I didn't bother to look into a DIY fix because of time/energy. I paid $145 to get it fixed. Mechanic said they put a new gasket in as well.
  6. Jun 26, 2015 at 7:05 PM
    koditten
    Kirk
    Central Michigan
    It's called the dollar vs the hassle factor. Yes, it can be an easy fix or it can be major pain. Many of us have twisted a bolt off, thus requiring a welder to do the job.
    You did good.
