Drove truck for a few miles severely overheating, how bad did we mess up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by drewskie, Dec 18, 2017.
  1. Dec 26, 2017 at 3:49 PM
    #41
    Muddinfun
    Muddinfun Well-Known Member
    Pull the fuel pump relay out. Fill the radiator full. Have someone crank the engine while you watch the coolant. If it goes like this, ___-___-___-___-___-, you have a leaking head gasket. If it shoots up and hits the hood, you REALLY have a leaking head gasket.
    drewskie[OP] likes this.
  2. Dec 26, 2017 at 4:03 PM
    #42
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I knew a guy that drove his 500 cubic inch 1970 Cadillac El Dorado (the 6 years I knew him) with zero engine coolant (and he was proud of that fact). Maybe engine coolant IS overrated. I dunno
  3. Dec 26, 2017 at 4:32 PM
    #43
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
  4. Dec 26, 2017 at 6:07 PM
    #44
    drewskie
    drewskie [OP] Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    I said the same, but he was changing the oil and saw a bunch of white/pink crust underneath. We traced it back to the WP and leaking weep hole. Truck never lost coolant though, so I think we both wish we just left.
  5. Dec 26, 2017 at 6:14 PM
    #45
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    If it was coming out the weep hole the seal was starting to leak, it was probably due for a new one. Its a shame this happened, you've just gotta deal with it and move on. If it warped the head, it might be cheaper to find a good used engine and swap it, if you have the skills, tools and time.
  6. Dec 26, 2017 at 6:17 PM
    #46
    drewskie
    Drew
    Burbank, CA.
    That's what I hear, especially with aluminum. Hopefully it's neither the gasket or heads and was just the air bubbles.
  7. Dec 30, 2017 at 3:20 PM
    #47
    drewskie
    Drew
    Burbank, CA.
    This is the last time I'll bug everyone about this, but I have another question.
    In the manual, it makes it sound like there are 2 different temperature gauges in the truck, one for the radiator and one for engine temp. Is this true? If so, what are the chances the gauge was indicating that the truck had no water in it rather than the engine actually overheating? Just foolish wishful thinking on my part?
  8. Dec 30, 2017 at 3:23 PM
    #48
    markus30
    markus30 Well-Known Member
    mark
    Florida
    2009 tacoma dcsb trd
    king 2.5 coils with resi in the front, dirt king lca, TC uca, archive towers, 14" rear kings, shackle flip, dakars HD. pelfreybilt front bumper, sliders and skids, brute force rear bumper, method nv 17" wheels, 35" ko2s, 4.56 gears locked, EBC brakes,TC spindle gussets, dual batterys, arb fridge, bunch of other crap..... more to come
    so i dont have a wiring diagram infront of me so dont take this as gospel but..... typically the gauge on the dash is for your coolant temerature. so if your radiator is empty it will read hot. The cylinder head temp sensor is what the engine computer uses to adjust A/F ratio/ and timing.
  9. Dec 30, 2017 at 3:28 PM
    #49
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    As was mentioned overheating is bad for uneven expansion. Overheating an iron block/aluminum head engine will likely stress the HG and a good way to crack the head. But it's also true these engines are tough and ruining a head gasket isn't the worst outcome.
  10. Dec 30, 2017 at 7:35 PM
    #50
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Usually, if a temp sensor is exposed, it will not read hot but will actually read cold or won't read at all. That is what can be so ''dangerous,'' your engine is getting toasted but your gauge isn't telling you that expensive damage is occurring. A gauge that goes to cold means stop immediately and check your coolant level.
  11. Jan 1, 2018 at 8:23 PM
    #51
    drewskie
    Drew
    Burbank, CA.
    Probably a stupid question, but if I can get the wiring diagram (which I may have) what would I look for to determine which sensor it is? Thanks for all your help btw.
  12. Jan 1, 2018 at 8:37 PM
    #52
    markus30
    mark
    Florida
    you would just be looking to see if the coolant temperature sensor was wired to the instrument cluster and the cylinder head temp sensor would be wired to the PCM. whats the latest with the truck? still having to add coolant?
  13. Jan 2, 2018 at 2:39 AM
    #53
    drewskie
    Drew
    Burbank, CA.
    No, last time I saw him it seemed to be fine, the coolant has stayed the same the last few days.
  14. Jan 2, 2018 at 2:46 AM
    #54
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    It is a coolant sensor
  15. Jan 2, 2018 at 4:12 AM
    #55
    markus30
    mark
    Florida
    may have just had a bunch of air in the system. keep a close eye on it. If you can get your hands on a coolant pressure tester it would be a good idea to put it at 15-20 psi and leave it over night. if its the same in the morning you should be ok.
    toyodajeff likes this.
  16. Jan 2, 2018 at 4:51 AM
    #56
    EL BOOGIE
    EL BOOGIE Well-Known Member
    Robin
    Sacramento
    2012 TRD Offroad
    my right foot
    Not sure if it applies as I overheated my 4.0 to the red. And drove for about 10 miles before I realized it... Anyways... it also caused my transmission to overheat also and according to Toyota, the transmission is designed to purge itself of fluids/ pressure to protect itself (automatic not sure on manual) probably a good idea to have it checked out too especially if it starts to clunk when going into gear or seems to hunt more on the highways.
  17. Apr 1, 2018 at 6:02 PM
    #57
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
  18. Apr 1, 2018 at 6:05 PM
    #58
    drewskie
    Drew
    Burbank, CA.
    Seems perfect now. He drives it all the time with no issues, so either got lucky or something will come up soon.
    07 sport 4x4 and b_r_o like this.
