Drowned my Tacoma help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maricich_d, Jun 12, 2018.
  1. Jun 13, 2018 at 8:53 PM
    #181
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    But a sacrificial junkyard one, it could get smoked if there’s a short in the truck’s wire harnesses or other circuits.
  2. Jun 13, 2018 at 8:54 PM
    #182
    tcjacado
    tcjacado Well-Known Member
    I say use his buddy's that told him "you just got to send it":anonymous:
    Jcyr, Chipskip, Hobbs and 4 others like this.
  3. Jun 13, 2018 at 9:36 PM
    #183
    Grim Reaper
    Grim Reaper Active Member
    Grim
    MD
    09 DCSB TRD Sport
    I'm guessing alcohol was involved
    Hobbs likes this.
  4. Jun 13, 2018 at 9:57 PM
    #184
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Gooood story!!!
    CampTruck[QUOTED] likes this.
  5. Jun 14, 2018 at 12:45 AM
    #185
    lvs2rock
    lvs2rock Well-Known Member
    N. Cali
    96 Taco 2RZ-FE auto
    sorry about the incomplete 'suggestions' - will try to complete now. ....
    o-kay. Back to the passenger cabin. Need I mention that the battery should not be connected while you're doing all this ?oh crikey: And did you disable your airbag system? (gonna have to add/edit above post, this is important!)
    Use that dielectric grease (note: from this point on I'm just going to refer to the dielectric grease as 'grease', ok?) --after ALL is thoroughly dry, mind you !!-use it everywhere there's an electrical connection: In the instrument cluster/display panels pull the little bitty lamps out of their sockets.
    <<d'oh! -I don't even know if your truck uses 'light bulbs' !! Well, whatever it does use, the same principles apply- clean it, dry it, expose it, 'seal' it , put it back together> >
    Use the needle files and/or the emery cloth to expose a fresh metal surface at all points of contact for both lamps and sockets . Apply a dab of (dielectric) grease, re-assemble. I kept a supply of q-tip swabs, popsickle sticks and toothpicks handy to use where the contact areas were small or restricted- behead the swab, put a small dollop of grease on the bare end, apply inside narrow openings, re-assemble.
    This whole 'process' parallels the steps you take when your battery terminals get corroded- I was taught to use Vaseline as the 'sealer'. I'm a little better educated now (I think!) : DON"T do this. Don't use Vaseline- or any!- petroleum-based product. Petroleum and rubber do not play well together- gas or oil will 'melt' rubber, creating a sticky, gluey mess. Ask me how I know. Nah, just take my word for it! OTOH, dielectric grease is silicone-based. It's non-conductive: if you get some where you shouldn't it won't create a path for electricity to travel on and will seal out both moisture and oxygen, thus preventing oxidation (corrosion).
    to be continued.
    (again)
  6. Jun 14, 2018 at 5:45 AM
    #186
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    @Maricich_d I drowned my truck two years ago in 8ft of water. It sat that way over night. Getting the engine flushed out is a great start. What I did was put the truck in a small enclosed garage with space heaters, fans, and dehumidifiers. I let it set that way for a week with as many wires disconnected as possible. I ended up replacing maf sensor, O2 sensors. charcoal cannister, all fluids, passenger occupancy sensor, a catalytic converter, and the radio. You might have water in your gas. Drain that out and add a can of dry gas. Pm me so as to avoid trying to sort through this thread. This is all fixable for a reasonable price.
  7. Jun 14, 2018 at 5:09 PM
    #187
    Maricich_d
    Maricich_d [OP] Active Member
    07 Tacoma trd
    Buddy in another truck threw a tow strap to us to swim across with so the river didn't take us away. Water was moving pretty good
  8. Jun 14, 2018 at 5:39 PM
    #188
    lvs2rock
    N. Cali
    96 Taco 2RZ-FE auto
    ..."continued"
    I 'liked' mightytacoman's post (above) especially for its brevity (!!!)....I should take a lesson there, a fact that was driven home rather painfully when I re-read my 2nd post on this particular thread. Re-iterating points already made is, too often, just a waste of time. Tired, my bad. Sorry!
    ++ @mightytacoman: excellent advice re: changing all fluids: (I was gettin' there, albeit slowly.....)
    @Maricich_d: DO THIS! It's absolutely necessary. Both for the (now and future) functioning of your truck and for your peace of mind. Some key locations: engine oil, transmission or transaxle/transfer case, , differential(s), brakes, coolant,. Your A/C system should be completely sealed (in other words no fluids to drain and replace) however it _does_ have electrical components including switches and relays that will need the kind of attention I've already too painstakingly outlined. Ditto the power (or "power-assisted") steering.
    I am pressed for time so I'll try (for the sake of my, as well as any future readers', sanity! ) to condense the remainder:
    Things to remember as you return your rig to the road: Steering and suspension lubrication/ grease points. These will need your immediate attention .....IIRC your rig was in the current for several hours. Most suspension lubes are fairly 'water-resistant'- this means it won't wash out with a casual wash or rinse-off stream of water (like you'd apply with your garden hose as you wash your rig at home) but when the rate of flow is increased (like the 'high pressure rinse' at a car wash) or continued (while your truck sat in the river for...hours, say) the 'resistance' factor becomes pretty unpredictable. Check your balljoints, tie-rod ends, steering gear knuckles, any and all grease-able bushings, u-joints, suspension points etc etc: Re-grease (or replace!)
    Re: engine bay:
    Same basic steps apply here as do to passenger cabin: Remove every peripheral/accessory/cover possible. Disassemble, clean, dry, seal (isolate). Pay particular attention to the engine wiring harness: use care when unplugging components (don't pull on the wires, pull on the _connections_!)
    And 'ditto' what mightytacoman said, above. ("change all fluids")
    When I performed my successful "resurrections" I was fortunate enough to have a good friend as mentor and guide who had owned a successful auto repair business here in Sacramento for several years prior to his retirement. Looking back, it becomes obvious that I had a lot of luck on my side and in my favor. To wit: my successes are mostly attributable to a couple of key factors: I had my friend Nathan Ervin in my corner to use as 'back-up' when I got stumped; the vehicles I was working on were comparatively primitive as far as tech goes (no OBD, no fuel injection, no ECUs) , and... I'm stubborn.
    If you have further questions or think I can be of any assistance whatsoever please PM me. I am always happy to help if I can-just be aware that I don't check my email as frequently as I should but I do, always, get around to it....I'll try to be better about that in future. In fact I guess I'll _have_ to be better given that I've just made such a public offer!
    Good luck to you. Please keep us posted on your progress, etc. ....We'll be watching you.....
  9. Jun 14, 2018 at 5:42 PM
    #189
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I am curious what an un-condensed version is? ;) Carry on good fellow.
  10. Jun 14, 2018 at 5:59 PM
    #190
    Maricich_d
    07 Tacoma trd
    For real appreaciate all of the help! I'll keep y'all posted!!!
  11. Jun 14, 2018 at 10:08 PM
    #191
    BandanaBerg
    BandanaBerg Yotas Yotas Yotas Pocast
    Phoenix,AZ
    2010 DCLB SR5 4x4
    Up Front; Icon 2.5 Extended w/ Fox 600s, Icon Delta Joint UCAs, Poly Performance Taco Tabs, BAMF Hybrid Bumper, Pelfreybilt Legacy IFS Steel Skid, RCI Transfer Case Skid Out Back: Archive Garage Hammer Hangers w/ High Clearance Cross Bar, OME Dakar Expedition Pack, Icon 2.0 RR, All Pro U-Bolt Flip w/ Super Bumps, All Pro Extended Brake Lines, Trail Gear Rock Assault Bumper w Custom Swing Tire Carrier Wheels & Tires: Pro Comp 5001 Wheels 16" on some 285/75/16 BFG AT KO2, ARB Single Compressor Up Top & Around: RCI 5° Rock Sliders, CaliRaised LED Premium Roof Rack w/ CaliRaised LED Dual Function Light Bar, CaliRaised LED Amber Fogs in CaliRaised LED LED Fog Light Pod Replacement Brackets, Anytime Fog Mod, CaliRaised LED Ditchlight Fogs on CaliRaised LED Low Profile Ditch Light Brackets, Voswitch UV100 Switch Controler, Chineseum Chase Ambers & reverse/camping LEDs Misc Thangs: Tech Deck w Ram Ball Mounts, Expedition Essentials 2nd Gen Rail w/ Ram mounts...
    Tacotards!!! :facepalm::rofl::rofl::rofl::fistbump:
    Skyway and lvs2rock like this.
  12. Jun 15, 2018 at 12:49 AM
    #192
    Whip88
    Whip88 Member
    great late night read! GL OP subbed for a solution!
    someone suggested plugging in another ecu for testing, mb?
  13. Jun 17, 2018 at 10:05 AM
    #193
    Muddinfun
    Muddinfun Well-Known Member
    This thread went down like the Titanic.
    Lost In The Woods and Twizted like this.
  14. Jun 22, 2018 at 5:17 AM
    #194
    lvs2rock
    N. Cali
    96 Taco 2RZ-FE auto
    o shazamit DOES THIS TRUCK HAVE A "CIRCUIT OPENING RELAY?"
    @Maricich_d:
    been trying to track a electric issue my Toy so reviewing wiring schematics- refreshed memory re: why FSM requires the COR be disconnected (as easiest- to me- means of disabling fuel pump).- I mean "hey, there's a fuse AND a relay, why can't I just unplug them?"......further research and careful look at wiring schematics revealed answer.
    worth checking if u r still struggling/////////
    Torspd likes this.
  15. Jun 22, 2018 at 4:38 PM
    #195
    slowkick
    slowkick Member
    PyriteTaco
    NorCal
    Wow'ser… how can one not sub
  16. Jun 23, 2018 at 6:30 AM
    #196
    Phrog Pilot
    Phrog Pilot Active Member
    NOVA
    2014 Spruce Mica SR5 AC 4x4
    Carr hoop steps, Weathertech floor mats, Tow package, ARE topper, Michelin Defenders
    You Army helo dawgs stay over the nice safe ground with all the rocks and trees and wires and stuff. We Navy helo dawgs got this. Now hold my beer...
    BandanaBerg likes this.
  17. Jun 23, 2018 at 7:43 AM
    #197
    la0d0g
    running for the hills
    For crawling not hauling
    Any updates?
  18. Jun 23, 2018 at 7:47 AM
    #198
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Dammit
  19. Jun 23, 2018 at 8:40 AM
    #199
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Holy fuck!!!
    BandanaBerg and JWROSE4 like this.
  20. Jun 23, 2018 at 9:00 AM
    #200
    Muddinfun
    So, either the truck fell on him and killed him, or he gave up and is too embarrassed to admit that he had it towed to the dealer, or he gave up and is selling parts on Craigslist.
    @RedRider133 You're his friend. What's the latest?
