Drowned my Tacoma help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maricich_d, Jun 12, 2018.
  1. Jun 23, 2018 at 9:26 AM
    #201
    Aerose91
    Aerose91 Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    Jeeeeeezus. Houston hurricane?
  2. Jun 23, 2018 at 10:25 AM
    #202
    Kotah
    Kotah Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    I wander how many cold ones he consumed if it was 3:00 am in the morning when he started that crossing, he must of forgot the part about parting the water first. Or it could be here i sit and my truck want start, but it dont matter cause im a trucker ill take 2 more pills and push the fucker.
  3. Jun 23, 2018 at 10:36 AM
    #203
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I hope he didn’t just purchase floatation tires and thought they weren’t just for sand.
  4. Jun 24, 2018 at 11:14 PM
    #204
    Slamuel
    Slamuel Well-Known Member
    Sam
    Tacoma
    This needs to be stickied.
  5. Jun 25, 2018 at 7:39 AM
    #205
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    10/10 for renaming your truck to "1995 Toyota Submarine" :bananadance:
  6. Jun 25, 2018 at 8:30 AM
    #206
    Pigpen
    Dan
    Northwest Montana
    This is a great thread!
    OP, you're doing it right. All of it.
    BandanaBerg, 2Dayvid and Aerose91 like this.
  7. Jun 25, 2018 at 11:57 AM
    #207
    Muddinfun
    Muddinfun Well-Known Member
    I'm curious. @Jamesboy2233 Why did you open the hood? And why are you still standing in that nasty water? And where was the person that took the pic? On higher ground, where you should have been?
    JWROSE4 and Running Board Man like this.
  8. Jun 25, 2018 at 1:01 PM
    #208
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    When my truck was drowned, I popped the hood immediately after to rip the battery wires off. Maybe he was trying to save electronics from frying too? Its kinda like a phone that fell into a toilet. You and a buddy can own the same phone and both drop them in a toilet. One might work after and the other might not.
  9. Jun 25, 2018 at 1:20 PM
    #209
    Muddinfun
    But if your phone fell into the port a potty, would you jump in feet first, and start feeling around for your phone? At some point, you just have to say, "screw it, I'm outta here"
  10. Jun 25, 2018 at 6:18 PM
    #210
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I get the whole crossing a river challenge. Google 'Bridge'. It worked for me.....
  11. Jun 29, 2018 at 10:32 PM
    #211
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    When a water hazard becomes a moral hazard...
    Naveronski, PzTank, TacoZim and 3 others like this.
  12. Jun 30, 2018 at 12:34 AM
    #212
    RedRider133
    RedRider133 Member
    Brandon
    2014 TRD Offroad
    Supercharged, Kings all around, Total Chaos control arms.
    Screw insurance companies, I’d take the $8k in a heartbeat.
  13. Jun 30, 2018 at 1:39 AM
    #213
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    We’re gonna need a bigger boat, I mean.....tacoma
  14. Jun 30, 2018 at 1:44 AM
    #214
    Muddinfun
    So... Is that $23k and he kept the truck? If so, did he ever get it running?
  15. Jun 30, 2018 at 6:14 AM
    #215
    DVexile
    Ken
    Wasn’t saying he shouldn’t! He paid for the insurance after all. The term “moral hazard” is from economics and despite having the word “moral” in it isn’t particularly about morals at all.
    From an online dictionary:
    moral hazard - noun
    1. lack of incentive to guard against risk where one is protected from its consequences, e.g., by insurance.
    In this particular case it was even more extreme - he wasn’t just protected from the risk but he made a significant profit!
  16. Jul 4, 2018 at 10:42 AM
    #216
    WNYTACOMA
    Clarence, New York
    The unfortunate thing is that we all pay more in premiums to compensate for the imbeciles who make monumentally stupid decisions.... Insurance companies are in business to male money. We all pitch in when idiots are compensated for doing dumb shit.
  17. Jul 4, 2018 at 12:38 PM
    #217
    LRT56
    LRT56 New Member
    2009 Toyota Tacoma DBcab, red
    Yes as newbie to TW I would like to know the rest of the story...I would like to avoid this off road experience.
    DoorDing likes this.
  18. Jul 4, 2018 at 1:23 PM
    #218
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    I don't think the OP is an imbecile. He made a bad decision, like we all have. But I agree, we all pay.
  19. Jul 4, 2018 at 2:16 PM
    #219
    RedRider133
    RedRider133 Member
    Brandon
    2014 TRD Offroad
    Sorry bro, some of us don’t mall crawl and actually use our Off Roads to off road. Shit happens. That’s why there’s insurance :thumbsup:
    BandanaBerg, Biscuits, Marc70 and 5 others like this.
  20. Jul 4, 2018 at 4:02 PM
    #220
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I probably could
