Drowned my Tacoma help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maricich_d, Jun 12, 2018.
  1. Jun 13, 2018 at 6:16 AM
    #121
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    subd
    Jc4x4 likes this.
  2. Jun 13, 2018 at 6:37 AM
    #122
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Already stated that the water was cranked from the cylinders, after spark plug removal.
    FirstTimeFirstGen and tcjacado like this.
  3. Jun 13, 2018 at 6:44 AM
    #123
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    @Maricich_d , you mentioned that you replace the fuel pump? Is this correct?
    Ignition powers the relay. You can disconnect a fuel hose, pull the relay and jump out the contacts to make sure fuel is flowing. So that at least the continuity of the pump and its functions are ruled out.
    Quick disconnect line under the truck, right by the tank.
    Then as you stated before it would be tracing where back to where the voltage is.
    When you put the key in the ignition, and turn it to the "On" position, does the Check engine light illuminate? If so that means that you have power to your ecu and it is on some level communicating .
  4. Jun 13, 2018 at 6:54 AM
    #124
    PeterT
    PeterT Well-Known Member
    Peter
    Plymouth, NH
    15 TRD O/R Super White!
    AP APEX aluminum bumper, AP APEX Sliders w/fill plates, Full AP skids, OME 886/ Nitros dakar leaf pack, 33" BFG muds, Relentless 50" curved Light bar, PIAA fog lights, Fog lights anytime, tailgate lock, LEDs inside, tech deck, URD Spec U exhaust
    you, Sir, have won the internet for the day
  5. Jun 13, 2018 at 7:21 AM
    #125
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    I have very little useful to add other than perhaps the obvious observation that there are two EFI fuses, one before the relay and one after the relay. So when you say there is no power at the EFI fuse maybe you are only looking at the second one after the relay and it is the one before the relay that is blown? This dual fuse setup exists on a lot of circuits so it can be very confusing without consulting the wiring diagram.
    Other than that glad you are at least safe, fast moving water in the dark is nothing to sneeze at! Oh and also kudos for being such a good sport with good humor sharing your unfortunate if amusing to others story!
    2Dayvid, Marc70, 12TRDTacoma and 3 others like this.
  6. Jun 13, 2018 at 8:29 AM
    #126
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Very entertaining thread.
    To the OP, good on you for taking it in stride.
    Does insurance cover something like this or are you SOL?
    honda50r likes this.
  7. Jun 13, 2018 at 8:30 AM
    #127
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  8. Jun 13, 2018 at 8:31 AM
    #128
    tcjacado
    tcjacado Well-Known Member
    Pretty sure insurance totaled the truck and paid the claim.:thumbsup: so he isn't SOL.
    TacomaMike37[QUOTED] likes this.
  9. Jun 13, 2018 at 8:43 AM
    #129
    AJH387
    AJH387 Well-Known Member
    AJ
    Pittsburgh, PA
    '19 TRD OR DCLB
  10. Jun 13, 2018 at 8:50 AM
    #130
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Marc70, LocoLocal, lynyrd3 and 3 others like this.
  11. Jun 13, 2018 at 9:08 AM
    #131
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Sub.
    As in Submarine, not that I am subscribing to the thread. :bananadead:
    Biscuits likes this.
  12. Jun 13, 2018 at 9:13 AM
    #132
    Mike714
    Mike714 Well-Known Member
    Cypress, CA
    2013 DCSB Prerunner Super White
  13. Jun 13, 2018 at 9:18 AM
    #133
    Maricich_d
    Maricich_d [OP] Active Member
    07 Tacoma trd
    Thanks for the support! Gotta laugh at it now that it's over! When I turn the key to the on position the check engine light comes on for a bit then disappears like normal.
    Super glad everyone was alright. Was lucky I got it to face upstream so it didn't roll.
    Going to check all the fuses again and potentially through a new fuse box at it. If that doesn't work then I'm assuming I just have to accept it's the ECU. I found a set of refurbished ones for about 400 bucks. Says they are already flashed and they send you an obdII reader to reprogram interrupter. Is that a legit deal or a bad idea?
    Biscuits, henryp and DoorDing like this.
  14. Jun 13, 2018 at 9:26 AM
    #134
    Maricich_d
    07 Tacoma trd
    Engine is cranking but no start. Sounds like a normal engine. Fuel pump just isn't coming on. I should add the I sprayed alittle starter fluid in the intake and it fired and started for a short amount of time.
  15. Jun 13, 2018 at 9:32 AM
    #135
    Maricich_d
    07 Tacoma trd
    Already tried jumping the fuel pump relay and nothing. I don't have any power at the relay at all (checked with test light and voltmeter, in on position and while cranking). Check engine light does come on when key is in "on" position. Stays solid for about 5 seconds, then flashes 3-4 times, then turns off.
  16. Jun 13, 2018 at 9:33 AM
    #136
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Have you tried what @Torspd mentioned above? He's dead on correct. The ECM sends power to the hot side of the coil on the relay only with a starting signal or when the engine is actually running. You can bypass the relay completely just by unplugging the relay and shorting the leads. If you have the same symptoms after bypassing the relay, the problem is downstream of the ECM and relay.
  17. Jun 13, 2018 at 9:35 AM
    #137
    Maricich_d
    07 Tacoma trd
    Yup, tried jumping the relay and the pump didn't come on.
  18. Jun 13, 2018 at 9:41 AM
    #138
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Probably should have had a snorkel.
    12TRDTacoma likes this.
  19. Jun 13, 2018 at 9:45 AM
    #139
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
  20. Jun 13, 2018 at 9:45 AM
    #140
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Shit.....nevermind. Missed it by a minute.
    No power to which part of the relay? There should be 2 potentially hot wires. 1 hot wire comes from the ECM during cranking signal or when the engine is running. This is the one that turns on the coil in the relay and you can bypass. The other hot wire should be ignition controlled. With the key in the on position, it should be hot and is the signal that gets sent to the fuel pump. Upstream from the relay I believe it's the two EFI fuses. The EFI fuse should be hot on both sides of the fuse at all times. EFI2 fuse should be hot on both sides of the fuse with the ignition in the on-position.
