Drowning sound around 3-3.5 rpms
Discussion in '1st Gen. Tacomas (1995-2004)' started by southerman21, Oct 24, 2011.
  1. Oct 24, 2011 at 4:31 PM
    southerman21
    southerman21 [OP] Well-Known Member
    Dylan
    Corsicana,TX
    00 Tacoma SR5 V6 few mods
    3" Pro Comp Lift,K&N Intake,Offroad Tires & Rims, Stickers, 2 12" Kicker CVT's, Halo Projector Headlights w/ 35W H.I.D. Ballasts 6000K (low beam) Narva Rangepower 55W (high beam), 20% Tint, LED Dome Light, Led Marker Light, Relentless Fabrication Front Plate Bumper, PIAA 510 Ion Yellow Fog, KC Apollo Pro 5" Driving Lights, Black APG Billet Grille, Flowmaster Delta 50 Muffler, Low Profile Toolbox.
    I recently put on a K & N intake hoping that it would make my truck run better. However it did not. It made it sound like its drowning at 3-3.5 rpms when over 1/4 throttle and it barely keeps accelerating.
    I've already checked vacuum hoses, cleaned my Maf, changed my fuel filter, and have (currently) running injector cleaner (sea foam).
    Any help would be greatly appreciated!
    I know i said 3-3.5 rpms but its actually 3-4.5rpms
  2. Oct 24, 2011 at 4:34 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    try disconnecting the battery, push the brake pedal to the floor for a few seconds and letting it sit for a few minutes to reset the ECM.
    Although i doubt something so severe is from the ECM/ECU not catching up yet.
    How did the truck run prior to the intake?
  3. Oct 24, 2011 at 4:53 PM
    southerman21
    Dylan
    Corsicana,TX
    i'll try that, and it was throwing the PO171 code before then i put a new o2 sensor on
    , and it was still throwing the code after i reset it,
    but other than the check engine light it didn't run like there was a major problem it just didnt run very good
  4. Oct 24, 2011 at 6:01 PM
    TacoMX
    Jonathan
    Deltona, Florida
    get it rescanned or scan the codes if you have an OBD scanner. Maybe something new? And when is the last time you changed plugs/wires?
  5. Oct 24, 2011 at 6:24 PM
    southerman21
    Dylan
    Corsicana,TX
  6. Oct 24, 2011 at 7:55 PM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    hmmm thats really weird, im kinda glad i didnt order this last week...subd to see what could be the problem good luck tho!!
  7. Oct 24, 2011 at 7:58 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
  8. Oct 24, 2011 at 8:04 PM
    tc98tacoma
    Nik
    San Antonio, Texas
    98tacoma4x4
    was the vid with WOT ??
  9. Oct 24, 2011 at 8:06 PM
    southerman21
    Dylan
    Corsicana,TX
    Ya it sounds great! But it just won't go, it takes likes 20 seconds to get to 60 with a v6? Idk what the deal is, it runs a little better in overdrive I'll put up a video tomorrow.
  10. Oct 24, 2011 at 8:08 PM
    southerman21
    Dylan
    Corsicana,TX
    Yes it was 1/4 at first till it got to like 15 then it was WFO
  11. Oct 24, 2011 at 8:08 PM
    TACOMABOSS
    96 SR5 4x4
    ohhhh i see. huh. that is weird
  12. Oct 24, 2011 at 8:08 PM
    TacoMX
    Jonathan
    Deltona, Florida
    watch from :15 to :26. It takes over ten seconds to get from 3000rpm to 4000rpms...not right.
  13. Oct 24, 2011 at 8:10 PM
    TACOMABOSS
    96 SR5 4x4
    yeah i get it now. i thought the OP was talking about the sound of the engine
  14. Oct 24, 2011 at 8:11 PM
    TacoMX
    Jonathan
    Deltona, Florida
    seems like an ignition problem to me :confused:
    does the CEL flash when it does it? (dont know if its in the view frame in the vid)
  15. Oct 24, 2011 at 8:45 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Put your seat belt on.
    Then try some seafoam. Directly inject a bottle into engine and put a bottle in your tank to clean your fuel injectors.
  16. Oct 25, 2011 at 10:37 AM
    southerman21
    Dylan
    Corsicana,TX
    The CEL doesnt flash it just stays illuminated.
  17. Oct 25, 2011 at 10:38 AM
    southerman21
    Dylan
    Corsicana,TX
    I haven't put seafoam directly into the engine put i have a can in the gas tank currently.
    Where do you directly inject it into ur engine?
  18. Oct 25, 2011 at 10:41 AM
    xroller
    xroller Blowin by em sideways
    Ramon
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    So your check engine light is on?..... Get that fixed first....
  19. Oct 25, 2011 at 11:58 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Break booster vacuum line? Do a search, lots of threads on this.
  20. Oct 25, 2011 at 12:20 PM
    TacoMX
    Jonathan
    Deltona, Florida
    Speaking for the OP...I dont think your paying enough attention the the video, ignore the sound. Watch from :15 and on... after it shifts...it takes over 10 seconds to get from 3k to 4k rpms...something not right.
    OP also said he cleaned his MAF.
