Drt Fabrication
Discussion in '3rd Gen. Tacomas (2016-2023)' started by drtfabrication, May 23, 2021.
  1. Mar 11, 2025 at 6:01 PM
    #281
    Texan161312
    Texan161312 New Member
    2021 trd OR
    Is there like a next order date soon or will it be a while aug/sept?
  2. Apr 8, 2025 at 8:30 PM
    #282
    bryannn
    bryannn Active Member
    The new bumper looks great. This seems like a good alternative to the c4 rock runner. Is the only welding required for the support plates?
  3. Apr 9, 2025 at 10:00 AM
    #283
    bryannn
    More questions for the new bumper!
    Is there an optional license plate mount that could be made available? Or has anyone figured out a license plate solution already?
    Any issues with sway bar clearance?
  4. May 11, 2025 at 8:06 PM
    #284
    drtfabrication
    drtfabrication [OP] Well-Known Member
    Derik
    Welding isn’t required but recommended
  5. May 11, 2025 at 8:07 PM
    #285
    drtfabrication
    Derik
    They’re live now and orders with a bumper + skid plate/crossmember delete get free squadron pros
  6. Jul 19, 2025 at 11:52 PM
    #286
    desertpinstripes
    desertpinstripes Member
    Was there ever any further development or updates to this? Also, what was the split between up and down?
  7. Jul 20, 2025 at 12:04 AM
    #287
    drtfabrication
    Derik
    I have made some changes to the hangers to optimize longer leaf packs like all pro, deaver and mine. There is now another set of bolt holes that moves the hanger back. Deavers are still only going to yield around 12.5-13” travel depending on bump set up and how negative you’re okay with your leafs going.
    I set my truck up with about 2” of negative arch and got to that number. The 16” measurement would be metal to metal bumped and strapped I do think 15-15.5” is possible but haven’t tested it yet. It would only be possible with my spec leafs or a custom set of leafs similar in design. The Deaver and Allpro packs won’t cycle that much.
    I was sitting at about 5-5.5” up from ride height once the leafs broke in.
  8. Jul 20, 2025 at 12:29 AM
    #288
    desertpinstripes
    Your setup caught my eye as I'm trying to decide on how I'm going to build the rear end. I'm trying to optimize it for crawling and I'm deciding whether I stay with leafs or go with the MarTech kit. I know the 3-link will provide more travel and probably yield it more smoothly, however, if I could get a solid ~15" of travel out of leafs I'd probably just stick with them.
  9. Jul 20, 2025 at 7:52 AM
    #289
    drtfabrication
    Derik
    Honest answer with two things to consider 1) If you feel like you’re at the point with your build where you’re considering links. Go with links. There’s really not a comparison. That’s not to say this set up doesn’t perform extremely well but links will always out perform.
    2) ask your self if it’s a want or a need. Are you really at the point with your build where links are the answer? There is a long list of things I would do before linking the rear. 35+ tires, LT, cmr, skids, sliders, steering upgrades. Etc. supporting mods.
    if you’re build isn’t at the point where you can use the link kit to its potential and hitting difficult trails then go with the leaf, hanger and shock relocate . One of the biggest pros of this is you can do it over time and like I said it does perform extremely well but it’s hard to compare because I think they cater to two different types of builds and people.
    lamjam likes this.
  10. Jul 21, 2025 at 6:48 PM
    #290
    drtfabrication
    Derik
    You might not NEEED it. But you know you want it
    The DRT Billet Hawse Fairlead is 5th axis machined from a solid block of 6061 aluminum and finished in raw, grey, or black Type III hard anodize. Perfectly radiused and ultra-smooth to protect your synthetic rope from wear—because function and finish should go hand in hand.
    • CNC machined 6061
    • Type III hard anodized
    • 10” bolt spacing
    • Grade 8 hardware included
    • For synthetic rope only
    • Made in the USA
    For the ones who are a little extra
    Pre-Orders available on the site
    https://www.drt-fabrication.com/product/billet-hawse-fairleadIMG_9658.jpg IMG_9655.jpg
  11. Jul 22, 2025 at 1:36 PM
    #291
    desertpinstripes
    Thank you, this is exactly the input I'm looking for. Besides sliders, my truck is currently completely stock, I plan to keep it this way for the next year or two and then I'll be completely overhauling it. I'm taking this time to do all the necessary research so I can make sure I have everything as well thought out and setup as possible. My thought process behind going links in the rear was I know I'll be pushing the truck and I typically just spend the extra money upfront because I know I'll upgrade in the future, however, in this case I think I'll stay with leaf's and see whether the upgrade to links will be necessary. If I went with your hangers and relocation, what leaf setup should I be looking at to maximize my travel numbers?
  12. Jul 22, 2025 at 9:41 PM
    #292
    Chrisx8182
    Chrisx8182 Well-Known Member
    Los Angeles
    2022 Tacoma 4x4 sport
    Looks awesome!
  13. Aug 7, 2025 at 8:17 PM
    #293
    370HSSSV
    370HSSSV Active Member
    Any one know how do I get a hold of these guys, sent two emails Aug 4th and Aug 6th following up from previous email, nothing. Emailed to info@drt-fabrication.com.
    Did I get the wrong email address? Or should I message here for a response?
  14. Aug 7, 2025 at 8:22 PM
    #294
    desertpinstripes
  15. Aug 7, 2025 at 8:23 PM
    #295
    370HSSSV
    lmao, I did not know that, was that on Instagram? Thanks for the heads up!
  16. Aug 7, 2025 at 10:08 PM
    #296
    drtfabrication
    Derik
    Hey dude! Bump your email and I’ll get back to you. I’ve got a few hrs I’m spending catching up currently
    bonnfabrication, Kefka and TACOTU3 like this.
  17. Aug 8, 2025 at 7:00 AM
    #297
    Kefka
    Kefka Well-Known Member
    01001010 01101111 01101000 01101110
    2019 MBM TRD PRO
    Congrats, Derik!!
  18. Aug 8, 2025 at 5:42 PM
    #298
    370HSSSV
    Enjoy the days off, i will send another follow up after the 12th. Congrats!
  19. Sep 5, 2025 at 4:13 PM
    #299
    drtfabrication
    Derik
    New website is live! Its been a long time coming but finally have a website that i feel better aligns with the quality products we make. Old one was a bit dated and lacked a lot of functions.
    https://drt-fabrication.com/
  20. Sep 7, 2025 at 10:00 AM
    #300
    drtfabrication
    Derik
