Drum brake pads/adjustment?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1TUFFTRD, Apr 28, 2010.
  1. Apr 28, 2010 at 10:16 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Dont know if this has been posted yet but i was wondering how long do the rear drum brakes last before needing replacement? And is there any way to adjust them or do they adjust themselves?
  2. Apr 28, 2010 at 10:22 PM
    Triumph843
    Triumph843 Well-Known Member
    South Carolina
    I have 50k miles on my truck now and they looked pretty good still. They auto adjust, and the auto adjust on them looks like it works pretty well compared to my old honda.
    It really depends how you drive though, best bet is to pull them off and there is a wheel you adjust using a screw driver to bring the shoes out if needed.
  3. Apr 28, 2010 at 10:26 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Do they have the knock out tabs that you can put the rubber plugs back in to? That way you can use an adjustment tool w/o removing the drums.
  4. Apr 28, 2010 at 10:27 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    So there is a way to adjust them if the auto adjust doesnt. thanks for the info im gonna pull mine off tomorrow they started to squeak today:confused:
  5. Apr 28, 2010 at 10:28 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    i looked and didnt find any:confused: did i miss it?
  6. Apr 28, 2010 at 10:31 PM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Mine has one on each side, but the wheel isn't behind it. I'm hoping someone that has removed the drum can help us out. How do the drums come off? Do you need a puller?
  7. Apr 28, 2010 at 10:34 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    No puller needed. take your wheel off and bang the drum with a hammer to loosen it and with a little elbow grease and finess it will pull off!
  8. Apr 28, 2010 at 10:37 PM
    Black Taco
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Cool. Once I remove it, I'm going to see if thers is a knock out tab behind it for future use. Good luck w/ yours.
  9. Apr 28, 2010 at 10:37 PM
    Triumph843
    South Carolina
    there are two screw holes you use... putting in bolts in both holes and screwing them in will push out the drum.
    just don't go too far or else you'll knock a retainer off a spring and its a PITA if you don't have the little push tool to put them back on.
  10. Apr 28, 2010 at 10:42 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    There is a rubber elongated plug on each side and you can get a adjustment tool in there, You may need to look in there with a flashlight first to see the sprocket, its a little offset. I have done mine a couple times. As far as pulling the drums there are two threaded holes in the drum, I don't know what thread they are but they push the drum off with little effort. I just happened to have a couple bolts in my spares that fit. I am sure they were metric and left over from on of my other projects. Good luck
  11. Apr 28, 2010 at 11:08 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Drum brakes generally last way longer than Disc brakes. A basic rule is that you can usually expect 2-3 front disc brake jobs before you have to do the rear brakes. Most of your braking power comes from the front brakes. On my old 89 4Runner, I had it for 115000mi, and NEVER did a rear brake job to it, but I did about 3 front brake jobs. I know the Tacoma's will be different but just to give an example.
    MTopp likes this.
  12. Apr 29, 2010 at 3:38 AM
    pauldotcom
    pauldotcom Well-Known Member
    Paul
    MA
    2012 Toyota Tacoma 4x4 TRD Sport Quad Cab
    OEM Roof Rack, Bilstein 5100's @ 1.75", Rear 1" block, TRD 17' Wheels
    You should remove your drums at LEAST every 10,000 miles. Use a quality brake cleaner and spray them down. Once completed, apply a little bit of greese to the hub so they come off easy next time. Then, adjust them from behind. There is a small rubber plug covering the adjustment star wheel. They are self adjusting, but they still require a manual adjustment at 10,000 mile intervals.
  13. Apr 29, 2010 at 12:50 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    alternating the screws, turn in screws untill drum wiggles off
    Dont ask the screw size, have had these since my 1st truck - 88
    how some things never change.
    igno1tus likes this.
  14. Apr 29, 2010 at 4:45 PM
    1TUFFTRD
    1TUFFTRD [OP] WTF
    06 AC with a skewp
    06 With a Skewp.
    took mine off and used some supertek brake cleaner(walmart:cool:) threw em back on and no more squeak and the pads looked good!
  15. Apr 29, 2010 at 7:29 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I'm on my fourth set of disc pads and I looked at my drum brakes today, they still look good. Triumph843 is right on how you pull the cover off and Timber is right on the adjustment.
  16. May 11, 2010 at 11:47 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    I was getting some bad squeal last weekend going down a hill at gorman
    just popped my drums off today, 1st time for me on this truck:D
    I have about 92k and from the looks of it the rear pads have never been changed. About 2mm left of pad.:eek: and real dusty
    so, what drums and pads are people using?
    im searching around
  17. May 11, 2010 at 12:16 PM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    It's likely you may never have to replace them on the rear. I put 150,000 on my first gen truck and they were fine when I sold it.
  18. May 17, 2011 at 7:28 AM
    KBToyota
    KBToyota Well-Known Member
    Kurt
    Spotsy, Virginia
    96 Tacoma V6 4X4
    OME 883, 5100 all around, Wheelers 3 leaf progressive aal
    Good trick/tip that most people dont know. I had to do this on the 1990 Toyota pickup to get the drums off.
  19. May 17, 2011 at 11:08 AM
    hwysrfr
    hwysrfr Well-Known Member
    Dennis
    SoCal
    2008 TRD Sport Access Cab
    2" lift Raceline Renegades 17x9, BFG All Terrains 265x70x17 Billet grill with USMC emblem, Redline hood struts
    what size bolts?
  20. May 17, 2011 at 3:09 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    I'm not sure on the thread size but pull any 12mm head bolt off the truck and it'll fit.
